Question about HP PSC 950 All-In-One InkJet Printer
I need to replace both the blk and color cartridges in my printer. How do install these. I can't figure out how to do this! Please help me!!!
    An expert who has written 3 tips or uploaded 2 video tips.
  • 82 Answers
If you can access the Internet, go to the hp website and type in the model number of your printer. They have online step by step to show you how to replace both of our ink cartridges.
Please rate, Thanks.
Posted on Feb 17, 2009
Why wont my printer print in blk?
take the black cart. out and dab on a wet paper towel, unplug printer and use q tip to clean the print head where the cartridge goes with alcohol, if that doesnt work you have a bad cartridge
Nov 09, 2015 | Office Equipment & Supplies
Have a Konica Minolta 2430 DL and it ask me to install blk toner after install toner it has error line 2408. can you help me?
2408 means that the toner cartridge you are trying to rotate to is already in the top position or you need to install another toner cartridge before you can rotate to the color you want to replace.
To fix the toner not installed message clean the three contacts on green chip on the right side of the toner cartridge. You may see black lines on them. Use an eraser or rubbing alcohol.
Nov 11, 2010 | Konica Minolta magicolor 2430 DL Laser...
I installed a new black cartridge and now it is not printing. I need the installation guide for allignment
Please follow below instruction. Otherwise, visit this link. Link
We hope we have provided you a solution to your problem.
Thank you.
The Canon Pixma Mp160 is an all-in-one printer, scannermag-glass_10x10.gif and fax machine. Replacing the cartridge in the printer requires little effort. Make sure to use the correct replacement cartridges for your MP160; installing the wrong cartridge type could prevent your printer from working or cause it to fail. Use caution to prevent ink spilling or dripping on you.
Step 1 Identify the cartridge that requires replacement. Press the "Copy" button to display the ink level. "BLK" indicates your black ink cartridge; "COL" indicates your color cartridge. If the display is only one bar (or none), then the cartridge should be replaced.
Step 2 Open the top compartment (scan lid) on your Canon printer. Pull back the compartment support legs to hold it open.
Step 3 Put on gloves, and then push the cartridge down to unlock it. Pull it toward you to remove it from the printer.
Step 4 Remove the tape strip from the replacement ink cartridge. Insert the new ink cartridge (black on the left, color on the right) at an angle, with the gold circuit facing down and towards the front of the printer. Push the cartridge up to lock it in place.
Step 5 Repeat the process if you are replacing multiple cartridges. Close the scan lid when you are finished. If the "Low Ink" warning does not go away, then turn the printer off, wait a few minutes and turn it on again.
Aug 01, 2010 | Canon PIXMA MP160 All-In-One InkJet...
My Samsung clp 510 printer won't print in color. How can I fix it??? I just installed a new black ink toner cartridge and now it's not letting me print in color. About a month ago I replaced the color...
I had a similar issue with my 510. My printer would only print in b&w regardless of my settings in the printer setup. I uninstalled my printer driver and reinstalled a fresh one from disk. This cleared up my issue.
Mar 26, 2010 | Samsung CLP-510 Laser Printer
Canon MP500 error message
If you're using Canon OEM (branded) cartridges you're going to need to ID the problem chip/cartridge so I'd try and get hold of some empty originals from somewhere (CartridgeWorld or similar perhaps?) and put those in as replacements for one cartridge at a time until you ID the problem cartridge/chip
If they're non-branded then chances are you do have more than one of the same chip but the solution is much the same...
If all else fails, take the printer to a friendly retailer who sell Canons and ask them to help you ID the problem cartridge.
Jan 19, 2009 | Canon Pixma MP500 All-In-One InkJet...
Display shows: printer cartridge incorrect
It seems like you are using incorrect printer cartridges.....
Make sure that part number on ink cartridges should be :
MK990 Cartridge, Ink, Standard, Series-9, Black CTRG,INK,STD,SERIES-9,BLK 0 1 0 Yes 1 N MK991 Cartridge, Ink, Standard, Series-9, Color CTRG,INK,STD,SERIES-9,CLR 0 1 0 Yes 1 N MK992 Cartridge, Ink, High-Yield, Series-9, Black CTRG,INK,HIYLD,SERIES-9,BLK 0 1 0 Yes 1 N MK993 Cartridge, Ink, High-Yield, Series-9, Color CTRG,INK,HIYLD,SERIES-9,CLR 0 1 0 Yes 1 N MK995 Cartridge, Ink, Series-9, Photo
Nov 10, 2008 | Dell 962 Photo All-In-One InkJet Printer
New Cartridge error message
Follow the steps below to remove and replace the empty ink cartridge.
  1. Turn the printer on.
  2. Open the ink cartridge door. Figure 1: Opening the ink cartridge door c00819080.gif
  3. Squeeze the gray tab below an ink cartridge slot to release the gray latch and then lift the latch. Figure 2: Lifting the latch c00819081.gif 1 - Ink cartridge latch for the black ink cartridge 2 - Ink cartridge latches for the color ink cartridges
    NOTE: Theink cartridge areas are color-coded for easy reference. From left toright, the ink cartridges are black, yellow, light cyan, cyan, lightmagenta, and magenta.
  4. Pull the ink cartridge toward you out of it's slot to remove it. Figure 3: Removing an ink cartridge c00819082.gif
  5. Remove the new ink cartridge from the packaging.
  6. Hold the ink cartridge by the handle and then slide the ink cartridge into the empty slot.
    NOTE: Makesure that the ink cartridge is inserted into the slot that has the sameshaped icon and color as the ink cartridge. The copper-colored contactsshould be facing the printer as the ink cartridge is inserted. Figure 4: Inserting an ink cartridge c00819083.gif
  7. Press down on the gray latch until it clicks into place. Figure 5: Closing the gray latch c00819084.gif
  8. Repeat steps 3 through 7 for each ink cartridge that needs to be replaced.
    NOTE: All six cartridges must be installed. The printer will not work if an ink cartridge is missing.
  9. Close the ink cartridge door.
after Doing this all Follow the next step :-
Please Try This, I am sure it is going to workout.
Resetting the All-in-One
Press the On (fa37665.gif) button to turn off the unit.
  • Disconnect the power cord from the back of the unit.
  • Connect the power cord to the back of the unit.
  • Press the On (a477fdf.gif) button to turn on the unit.
Oct 21, 2008 | HP Photosmart C5180 All-In-One InkJet...
Error 2408
Jul 11, 2008 | Konica Minolta magicolor 2430 DL Laser...
Colored Ink problem
Make sure you are using the correct cartridges for the Z35. They should be #26 (color) and #16 (black).
Make sure the contacts are clean where the cartridge connects to the printer electrically. A little alcohol wipe is good for this. Clean contacts on both the cartridge and the carrier in the printer.
Nov 19, 2007 | Lexmark Color Z35 InkJet
HP PSC 950 All-In-One InkJet Printer Logo
29 people viewed this question
Ben Johnson
