Question about NEC MultiSync LCD1810X 18.1" LCD Monitor
My MultiSync LCD1810 Monitor stays on only for only 1 Second.
My MultiSync LCD1810 XtraView Monitor is connected to my Laptop PC and its Power Button is on with a green light, but it does not show anything (screen is blank). If I turn off and then on the Monitor by pushing its Power Button, then I have a display for one second before it goes off again.This monitor has been working great until now and I don't know what's wrong.Can you help?Thanks,Sean
  • Lou Ebert May 11, 2010
    Sean, Your monitor has a problem with one or possibly both power supply boards inside and in back of the LCD screen. You will need to find someone that is equipped with troubleshooting knowledge of cold cathode fluoresecent backlights. The digital part ( ones and zeros) works fine. You just don't have any "WHITE LIGHT" to show what is on your screen. The light is produced with the same technology that the new low power "screw-in" light bulbs use. Your best bet would be to check and see if MULTISYNC has some kind of a $30 to $50 swapout program where they give you a working monitor and take your monitor and repair it for the next guy that comes in with same type of problem. Also you might want to look at some of the other solutions/ problems that are posted at FIXYA that have the same type of complaint as yours. Good Luck Guy! I'm just waiting for the CCFTubes in this Gateway 17" to die or the HV power supply to go out. I'm lmistyrel @ aol or louie12fix at Fixya
The Capacitor on the Inverter Circuit Board has gone bad and needs to be replaced. That's it.
Posted on Feb 19, 2009
My NEC multisync lcd1735nxm desktop display (monitor) is dark. When you initially turn it on it flashes the desktop for less than a second then goes dark. The power button stays on and if the image on the...
The problem is definitely with your monitor. Yes, you can have it fixed but with the price of parts and labor it is not cost effective and it will be cheaper for you to get a new unit with a warranty to boot!
Apr 07, 2017 | NEC MultiSync LCD1735NXM (Silver, Grey)...
My averatec lcd won't stay on
Can you try your monitor on another computer to see if it does this there as well? Usually this happens only when video is not detected coming from the PC. It could be as simple as a short in the monitor cable. If you have it connected to a laptop you'll also want to check you control panel power setting rules and then the screen saver under display.
Apr 14, 2010 | Averatec D1133 (D1133AH1E-1) PC Desktop
How do i get power to the multisync lcd 1565 monitor
The power button is the top button on the right side of the monitor.
Nov 17, 2009 | NEC MultiSync LCD1565 (Black, Silver)...
Multisync LCD 1700V turns on then screen goes blank and shuts off
Does the power light stay on? If so, you have an inverter problem. If the power light goes off, you have a power supply problem.
Sep 02, 2009 | NEC MultiSync LCD1700V 17" Flat Panel LCD...
Multisync 1735nxm screen dosent work
Your video card may be the issue. Can you try another monitor or try this one on another PC? This will eliminate or verify the monitor.
Mar 18, 2009 | NEC MultiSync LCD1735NXM (Silver, Grey)...
DISPLAY STAYS FOR 2 SECOND ON NEC MULTISYNC LCD 1760V
the inverter board has a problem. this is the small pcb that sends high volts to the backlights you will need to change it
Jul 12, 2008 | NEC MultiSync 1525X 15" LCD Monitor
Monitor displays breifly then goes to blank screen
F1 = Fuse 1
You should be able to locate a surface mount fuse at your local electronics store.
Apr 12, 2008 | NEC MultiSync LCD1830 18.1" LCD Monitor
NEC MultiSync LCD1810X 18.1" LCD Monitor Logo
282 people viewed this question
Top NEC Computers & Internet Experts
parusdi rusdi
Level 1 Expert
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
