Question about Kenmore 63942 Dryer
Remove blower wheel
How to remove blower wheel on Kenmore model 11060802990 electric clothes dryer, 80 series. thank you
  • William Stallard Feb 20, 2009
    You were right on. Thank you for your quick attention to this matter for me. Again, many thanks.
  • Kenmore Master
  • 8,220 Answers
Put a good fittting wrench on the blower nut and hit it with an impact wrench(left handed threads righty lucy). OR do it the tried and true redneck way get a friend to hold a pipe wrench on the pulley inside the dryer, around the back slide a small hammer handle or piece of wood in between two blower blades at 3 o'clock position and slam downwards to pop that mutha loose. The threads are left handed(backwards). That blower does not wanna go easy.
Posted on Feb 18, 2009
My gas kenmore 80 series is not heating?
ELECTRIC Dryer no heat or little heat:
Check your venting and lint basket. Check blower for lint build up and blower wheel obstruction., test by trying to turn the wheel manually by hand (should be easy) May have to remove cabinet or front/back plate to get to it)
Next check the heating element itself with a meter for continuity OHMS CLOSED CIRCUIT. If not its defective.
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage. 220 because if u only get half or 110 volts you will be able to run the machine which uses only 110 to run motor but not the heater which uses a full 220,
Check the thermal cut off, the cycling and the hi limit thermostats.
For continuity or OHMS. If no ohms or resistance they need replacement.
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
May 20, 2014 | Kenmore 80 Series Heating Element -...
Kenmore dryer 80 series does not heat
May 17, 2014 | Kenmore Dryers
Kenmore 80 series electric dryer. metalic sound/burning smell
drum bearing on the rear has gone making the front of drum rub on the caseing re metalic sound
Aug 17, 2012 | Kenmore Dryers
I have a Kenmore 110 60812990 80 series dryer
bad heater box fuse,get the model number from inside the dryer door,and go to your local appliance parts store and give them the number and they will get you a thermal fuse kit,remove the back of dryer and you will see the heater box on the right side
Feb 02, 2010 | Kenmore 64742 Electric Dryer
I have a kenmore 80 series electric dryer. It gets
If your dryer doesn't tumble, check these: Belt Motor Door switch Belt Dryers have a drive belt that turns the clothes drum. If the belt breaks, the drum stops rotating. Then you need to replace the belt, and often the idler pulley, because the pulley tends to wear out at the same time. Click here for a belt installation diagram Motor If the dryer motor only hums when you press the Start button, the motor may be burned out. Here's how to test the dryer motor: Remove the belt. Check for obstructions in the blower fan housing. Manually rotate the shaft of the motor. If the motor is very stiff, or impossible to rotate manually, and the blower fan housing is clear, you need to replace the motor. If the motor rotates freely, run the motor momentarily with the belt removed and the blower in place. If the motor runs fine with the belt removed, there may be a problem with the idler pulley or the clothes drum. Try to rotate the drum by hand. If it is very difficult to move, correct any problem with the rollers or pulley, and then reassemble the dryer and try it again. If the motor hums but doesn't rotate on its own even with the belt removed--yet you can turn it freely by hand--you usually need to replace the motor or the motor start capacitor. Door switch Your dryer can't operate at all if the door switch is defective. It's inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. If it's defective, you need to replace it.
Thanks for choosing fixya...Regards, Joe
Nov 13, 2009 | Cars & Trucks
Kenmore Electric Dryer Series 80 Model
Disconnect the dryer from your vent completely,. pull dryer out 3 ft. from wall and test to see if the smell continues, You have to test for a few minutes to clear out any burning lint from vent restrictions. If the smell hoes away then you know you have venting problems. Also check on the grate that covers the element( the part you look through when you see the orange glow from the element) sometimes plastic or clothing burns onto this grate and needs to be cleaned off. I the smell remains, you will have to tear down the dryer to see if you can find the cause of the smell.
Sep 21, 2009 | Kenmore 62802 Electric Dryer
Kenmore 80 series dryer no work
bypass door switch , if that doesnt work and you have replaced start switch already. then i would unplug unit remove back panel and look for the blower housing , on the blower wheel housing or to the right should be a white thermostat with 2 wires going to it.round shaped and it mounts to the blower housing by pass it and it should work however dont leave it bypassed. hope this helps
Sep 19, 2009 | Kenmore 60832 / 60834
Trying to access the blower fan on a Kenmore 80
Remove the rear panel.
Then remove the screws that secure the blower fan vent on the left side to access the blower wheel.
Mar 08, 2009 | Whirlpool LER4634J Electric Dryer
Location of the thermal fuse on the kenmore gas dryer 80
Feb 03, 2009 | Dryers
Kenmore 63942 Dryer Logo
137 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
