Question about Sharp VC-A554U VHS VCR
Vcr will not tape
When programming and push set the program disappears so i push menu.Is this the right way to program.The time is set right so i can't understabd what I am doing wrong pl4ease advise.
Sandy Ley@ east
link.ca My vcr is a sharp H810
    Guru:
  • 832 Answers
Hi there!
thanks for using Fixya.com!
You want to program? May I ask, what programming you wanted to do? I just want to clarify.
Thanks!
Posted on Feb 18, 2009
  • 544 Answers
Hi thank you for choosing Fixya.com.
log on this site and all of your question with your vcr will answer.
just follow the instruction very carefully..
hope i help you to soled your problem
  • Mark Milan silaran
    Mark Milan silaran Feb 18, 2009
    hello their again..
    Got a question? It’s probably been asked before. We’ve got answers to your most Frequently Asked Questions right here. Questions about product operation, features, troubleshooting and more. Check here first and help yourself.
    follow this link..
    http://www.sharpusa.com/products/Functio...
    Brigadier General:
  • 8,619 Answers
Hi!
Please see tape sppeds before taping. It would be like SP (standard play) LP (long play) and EP or SLP (extended play). For a normal size tape SP provides 2 hours, LP four hours and EP six hours
  • 1 more comment
  • Rylee Smith
    Rylee Smith Feb 18, 2009
    Please tell me from which source do you want to record? Like coaxial input for cable television or sets of three RCA jacks, red for right audio, white for left audio and yellow for video.
  • Rylee Smith
    If you are recording it from a cable box, you may need to set the VCR to channel 3 and then select the desired channel on the cable box.
    If you don't have a cable box but instead hook up your cable directly to the VCR, you may need to set the TV to channel 3 and the VCR to the channel you want to record.
  • Rylee Smith
    For programming it first press the program button and then the set button. You will need to tell the machine---
    1. The channel
    2. The day of the program
    3. The time to start and end, including hour and minute
    4. AM or PM
    5. Which of the three speeds to record at.
    So there is a lot of things you have to tell your VCR. As you are dealing with a machine you will need to tell it 05 rather than 5 for five o'clock.
    If you are reusing an old tape, wind it back to the beginning and check that the erasure-prevention tab is still present. If it's been broken off, you can't record.
  • 10,594 Answers
Do you want to tune stations in VCR or trying to record a program. Please give bit details.
    Top Expert:
  • Sharp Master
  • 66,126 Answers
Do u have the VCR seup for the right input source? this info is in the main menu.
    Genius:
  • 1,550 Answers
First turn off the unit for 10 minutes .
  • SAM ANDERSON Feb 18, 2009
    If you are trying to record a program than you need to hit menu option .
    And record the program .
    Yes it is the right way to record a program.
I have a Goldstar VCR and I want to record a tv program using it. How do I do it?
Most Goldstar VCRs only have an analog tuner. (TVs do not often have an option to output their video to another device.)
So first what is the source of the TV program? If it is an OTA analog or CATV cable. Set up the VCR normally by connecting the incoming signal cable to the VCR and then use the coax out to the TV. Scan for channels and set the VCR to record the desired program. (Either use the timed record or one touch record method.)
If your source is digital, you will need a set top box (either a digital to analog converter or cable box). To split an incoming OTA signal between your TV and the converter box, you can use a switch or a splitter. (A splitter will give lower signal strength to both the TV and the converter box.)
Depending on the box, you can either connect a coax cable from the box to the VCR and then to the TV or composite video from the box to the VCR. If you use coax, set the converter to channel 3 or channel 4 and record that channel. Otherwise set the VCR to record Line 1.
To record, put in a tape with sufficient space available with an intact safety tab. For One Touch Recording, set the VCR to the desired channel and tape speed. Then press Rec. Press several time for a timed recording. For Timed recording, press Menu > Program. Press Select and move through the list to program day to record, the start/stop time, and channel, etc. When done, press Menu to save the setting. The timer light should come on (most VCRs will turn off).
I hope this helps.
Aug 05, 2011 | Goldstar GBV241 DVD Player/VCR
How do i record a show onto a tape?
lets say you are hooked up correctly (cable to VCR in (from cable/sat box) & cable to TV from VCR out) and the VCR is set to Ch 3,, (PLEASE NOTE THE TV MUST BE ON CH 3)
program a recording
the VCR clock / date must be set and not flashing 12:00
then you go to menu, program a recording by imputing the start time / end time of the show and the date it will be recorded and Ch 3...(you might have to set your cable box for the same date/time as the VCR or manually turn to that ch you wish to record that morning or before you go to bed) put a new tape in the machine....
manual recording
a show,game or special comes on and you sitting and want to watch and record and even edit (no commercials) put tape in... press record button get the remote so you can pause (on commercials) and press pause again to resume recording
HAVE FUN
Dec 26, 2010 | Sony SLV-678HF VHS VCR
Lost manual. Cannot get HR A591U JVC VCR program to record a future cable tv program. Seems I have tried everything but it does not record as I set up. It will record an existing show by pressing...
Timer Recording JVC VCR HR A591U
Timer recording can be programmed on-screen with
the remote control. The built-in timer allows automatic
unattended recording of up to 8 programs within 1
month.
EXAMPLE: Program a timer recording for the 26th day,
channel 125 (CATV), 11:00 - 11:30 PM on timer program
number 1 (Tape speed: EP).
When a TV is connected with an audio/video cable, turn the
TV and this VCR on and select the video input mode on the
TV.
• After timer recording is completed, the VCR turns off
automatically.
• You can program the timer recording while a regular
recording is in progress; the menu screens will not be
recorded.
• The timer recording will start at 20 seconds before the time
you predetermined.
Press MENU on the Remote.
Check the “TIMER REC SET”
option is selected, then press
ENTER.
Press SET –/+ to select one of
the program lines, then press
ENTER.
Press SET –/+ to select the
date, then press ENTER.
Set the start time, end time,
channel and tape speed as in
step 3.
NOTE: To record from external
source, press SET –/+
and set the channel to
"L". "L" will appear next
to CH 125 (or 69).
To enter other programs,
repeat step 2 through 4. Or,
press MENU twice to return
to the normal screen.
Press TIMER on the Remote.
The power will go off, the
TIMER REC indicator ( ) will
light and the VCR stands by
for recording.
To cancel a program:
Press the SET –/+ to select the
“TIMER REC SET” option in the
MENU. Then press SET –/+ to
select the unnecessary program,
and press CANCEL to cancel the
program.
Aug 28, 2010 | JVC Televison & Video
I would like to tape my programs on the vcr(goldstar) I am not used to this product
do you wish to record while watching or while away.....while watching make sure your vcr is set to CH 3...when the show comes on press record
(a blank tape should be inserted) the red button on most vcrs.......while away the channel selector must be on the ch you wish to record...using the remote for the vcr press menu/program a event (this is where your vcr most have the correct date / time and not flashing 12:00)..set the day..time to start recording and time to stop recording..your ch will always be 3..now that vcr is set the main thing is make sure that cable channel selector is on that channel
happy recording
Aug 08, 2010 | Televison & Video
I need help programming vcr to tape show
Since the V9800 has no built-in tuner, your TV set must be set to the channel your show to be taped is on. There is no way to tune it to any particular channel. Now, isn't that convenient?
Feb 16, 2010 | Samsung DVD-V9800 DVD Player/VCR
Pre-Set Timer program not recording
Just a hunch, but did you check the clock settings after the time change?
Nov 08, 2008 | Samsung DVD-V3650 DVD Player/VCR
Digital TV Converter Box
I have a Panasonic TV with built-in VCR, I had Comcast put in a converter box and was given instructions on how to set up the system to record my wife's programs, I had to select the program (in advance of scheduled time) to be recorded through the TV & converter box to the VCR. Next styep- select "Show" and I received a menu the first of which was "R" I clicked the "R" and a menu for selecting Repeat record start/stop times appeared Click OK and was then directed to to set up the VCR according to Panasonic VCR instructions. Worked for a day then the "R" menu on the converter box disappeared. Both the VCR and TV had to be set to Ch 3 to get it to work, But that's history. When it quit working ("R" menu), I had Comcast come get their box . PS The tech who showed up to pick up the converter box knew nothing about any "R" (record) menus except on the most ecpensive converter box. That cinched my decision, Oh Wel!. Sign me Tom with less trash to watch.
Jul 29, 2008 | Toshiba MV19N2 19 in. TV/VCR Combo
Easy one: how do you set the time on the panasonic DMR-ez47v dvd?
OPEN CENTRAL PANEL,PUSH THE 'CLOCK 'BUTTON.IT BLINKS THE PRESETED YEAR.PRESS '-/+' BUTTONS TO SET THE YEAR.THEN PUSH 'NEXT' FOR '"MONTH ,DAY,HOUR,MIN".FOR EACH TIME PRESS NEXT BUTTON & +/- KEYS.
YOUR PROBLEM MAY SOLVE.
Feb 24, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Set vcr to record a program later
The VCR has to be off for the timed record to work.
Oct 30, 2007 | Mitsubishi HS-U510 VHS VCR
Toshiba VCR auto clock does not work, not way to set it. Please answer right away
you know it would be easier to help you if we knew what Toshiba vcr it is. it is usually easy to set clocks now. you push menu or setup on the vcr remote and there s usually a option to set the clock. only thing i can tell you right now is look here and type in yoru modle number on the vcr and see if ther eis a oweners manual on the site.
Sep 19, 2007 | Toshiba W603 VCR
Televison & Video Logo
70 people viewed this question
Top Sharp Televison & Video Experts
Dave Naylor
Dave Naylor
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
