Question about HP Pavilion dv2000t 14.1" Notebook Laptop PC (Intel Core 2 Duo T5500 1.66 GHz, 1GB RAM, 100GB HDD, D... PC Notebook
Hooking up sony tv to HP laptop
I have an HP DV6000 laptop and I'm trying to find a way or cable to connect to my Sony Rear Projection TV model# KP-61HS30. The S-Video output on the Tv is different from the one on my laptop.
    Problem Solver:
  • 13 Answers
Do you have a HDMI jack on your TV? it looks just like the blue/graphics/monitor jack on your laptop. If so use it to connect and you should be able to use your tv as a monitor. (if you tv came with the HDMI cable?, if not you can purchase one ez enough from Radio Shack)
Check your users manual for directions on how to use the remote to get it to that function. My Hansphree TV I have to put it on AUX to use my laptop hooked to it and see my TV as my lappy monitor.
Hope this helps you and others! Good Luck.
Posted on Feb 18, 2009
I would like to connect my my hp laptop to my Sony Grand WEGA KDP-57WS550 57 in. Rear Projection HDTV-Ready Television to watch netflix
You need to connect your PC to either your TV or your receiver. Also, if you have XBox, you can watch Netflix through it (thought I'd suggest, just in case).
Take your PC (or take a photo of your available outputs from your PC) and a photo of your available inputs (on your TV or receiver) to Best Buy or similar computer store. They can help you learn which connections you need.
Most likely you'll need a DVI to HDMI cable for video, and maybe a separate audio cable from your headphone connection on your PC to your TV (or receiver). You'll only need a separate cable for audio if your HDMI input on your TV does not support audio.
I am going through this same problem with my TV connecting Apple TV. I am checking now whether my old rear projection tv's HDMI input supports audio (same as yours). I've connected Apple TV to my rear projection TV. I have video, but no sound. Either my TV doesn't support HDMI audio, or I need to change a setting on the TV to enable that sound to work. If the TV does not support HDMI audio, I will need to connect Apple TV directly to my receiver via a digital optical cable for sound.
Hope this helps.
Jun 22, 2011 | Sony Grand WEGA KDP-57WS550 57" Rear...
Connect Sony Vaio Laptop to DVI on Sony LCD Projection TV
try to lower the resolution of the display, to know how please visit the following link:
https://www.microsoft.com/windowsxp/using/accessibility/screenresolution.mspx
< Please Rate :) >
Apr 12, 2009 | Televison & Video
PIP and direct tv
Can you provide the exact model, i work for 8 years With Sony.
Oct 18, 2017 | Sony KP-65XBR10W 65" Rear Projection...
Wiring problems
Not certain if HDMI can be used in a setup like this. I'd try it from the home theater (HT) to the TV, and other wiring for the other components.
For video:
All of these should have component connections (Y/Pr/Pb). You'll only need the video cables for each device:
  • Video out from cable, HT, and combo player.
  • Video in to TV. Your choice of inputs.
For audio:
Hopefully, the two output devices (the combo player and the cable box) have digital audio (fiber optic, or RCA coaxial). Otherwise, you'll only get stereo sound. VHS is stereo only anyway.
  • Audio out from cable box and combo player.
  • Audio in to HT.
The TV won't have anything to do with audio in this setup. Alternatively, you could try hooking up all inputs to the TV, and connecting audio out from the TV to the HT. Works best if this connection is digital, for surround.
Jan 01, 2009 | Sony BRAVIA DAVHDX275 Theater System
Connecting the laptop VGA output to my Sony-KP-53HS30
There are products such as VideoSecu PC to TV Presentation Converter. I haven't used them. I'm not sure you are going to get the resolution that you want. A DLP projector does a pretty good job. I know that is not what you are looking for.
Type "PC to TV Converter" in Google. They are about $40 to $60 bucks. Before you buy one, read the reviews.
Dec 27, 2008 | Sony KP-53HS30 53" Rear Projection...
NO SOUND FOR TV BUT I HAVE SOUND ON DVD
the bose has to be hooked up to the cable box output and video 1 on the bose. This is the only way it will work
Nov 14, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
Hooking up my hp laptop to a sony trinitron tv
Let me explain on how to connect the TV to HP notebook.
There are two ways to connect the TV to the notebook. One is with the S-Video cable and another one is HDMI cable. (If you computer had HDMI port)
Connecting notebook and TV with S-video cable:
You need to get the Svideo cable and connect it to the notebook Svideo port to TV Svideo port and press Fn+ F4 to get the notebook display on the TV.
For the first time pressing the Fn+F4 keys, you will get the display on the TV and there will be no display on the Notebook.
If you press the Fn+F4 for second time, you will get display back to the notebook and Tv screen becomes blank.
By pressing the same keys again will show the display on both the screen.
Samething connecting with the HDMI cable, if your computer had HDMI port.
If you won't get the display on the external screen even after following the correct process, then once you need to reinstall the display driver.
If the issue persists, then you have to check with another cable.
Note: No need to install any software on the notebook to connect the TV to the notebook.
Aug 01, 2008 | HP Pavilion dv6000z Notebook
Connect SONY VAIO VGN-CR23G to tv
it's only a partial solution but channel 3 or 4.... or your tv may have settings for dvd or other. look at the remote. try hooking it up again and changing from regular cable to dvd or the other setting (can't think of it at the moment)
Robert
Jun 27, 2008 | Sony VAIO VGN-N130G/W Notebook
Sony TV Screen
Is you model listed below?
Sony wega blue dot or star pattern on screen
http://esupport.sony.com/perl/news-item.pl?news_id=206&mdl=KDF42WE655
Models: KDF-42WE655, KDF-50WE655, KDF-55WF655, KDF-60WF655, KDF-55XS955, KDF-60XS955, KF-42WE620, and KF-50WE620
Jan 15, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Hooking up my new PS3 to my five year old 55" Mitsubishi HDTV.
The Sony outputs 180P, not 1080i. There is a difference. I don't know what exactly, but Sony says 1080p is for superior.
Dec 31, 2007 | Mitsubishi WS-55809 55" Rear Projection...
HP Pavilion dv2000t 14.1" Notebook Laptop PC (Intel Core 2 Duo T5500 1.66 GHz, 1GB RAM, 100GB HDD, D... PC Notebook Logo
206 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
