Question about Canon imageRUNNER 5000 Copier
I have a cannon imagerunner 3570 when i print the paper gets jamm
Can u help me solve this problem please
  • Chris Coughlin
    Chris Coughlin May 11, 2010
    I can Help only if I have a question to answer. I only see IR-3570 when i print the....
    Sergeant:
  • 199 Answers
Try with another driver like pcl 6.41 and use lan cable
Posted on Feb 27, 2009
Ir 3530
please cleen your scanner home position sencor
Jun 30, 2013 | Canon ImageRUNNER 3570 Copier/Printer
Cannon ir 3530 all error code and solution
Code Error name/description
E000 fixing overheating
E001 fixing assembly overheating
E002 fixing assembly low temperature
E003 post-standby fixing low temperature
E007 fixing film rotation error
E010 main motor rotation error
E014 fixing motor rotation error
E019 waste toner case full, waste toner case full sensor error
E020 toner clogging between sub hopper and developing assembly
E024 developing assembly connector disconnection
E025 hopper motor, bottle motor error
E032 NE controller counter error
E064 power supply voltage error (high-voltage)
E100 BD interval error
E110 scanner motor error
E191 communication error for high voltage power supply
E202 CIS home position detection error
E225 CIS light intensity error
E227 reader unit power supply error
E248 backup memory error
E261 zero-cross signal error
E315 image data error
E400 feeder communication error
Mar 03, 2011 | Canon ImageRUNNER 3570 Copier/Printer
Where can i find the waste toner in on this machine cannon ir 3570 copier
The waste toner is located on the front of the machine. You first want to lower the cover that allows you to insert the toner, then locate two rather large, silver screws that connect that front cover assembly to the copier. After removing the two screws, the toner bottle will be exposed.
If you need any further assistance, please let me know.
David R.
Dec 10, 2010 | Canon imageRUNNER 3570 Copier
I can't get my Canon ImageRunner 3570 to print in color, how do I get to that setting?
The Canon IR-3570 is a black and white copier, printer only, it's is not a color printer. sorry
Dec 25, 2009 | Canon ImageRUNNER 3570 Copier/Printer
Getting the ip address of a cannon imagerunner 3570 copier
first check your m/c having fiery ( Network Card )
then go to additional features function
you have to set ip address like 192.168.36.10
then configured with your pc
restart m/c
your pc in network connection click on view workgroup
you will see a new group
double click on it to install your pc
Feb 20, 2009 | Canon Office Equipment & Supplies
Print Jobs from our IBM Unix System Reports creates Ghost Jams
The answer to our problem ended up being a firmware upgrade to the Canon iR7095. I would look into that as your possible solution.
Oct 10, 2007 | Canon ImageRUNNER 3570 Copier/Printer
Facsimile Paper Size
TRY TO GO ON PAPER TRAY AND LOOK THE PROGRAM IN PAPER TRAY...IF U SEE CHEK THE PAPER SIZE THAT U WANT TO USE...
Jun 11, 2007 | Canon imageRUNNER 3570 Copier
Canon imageRUNNER 5000 Copier Logo
73 people viewed this question
old marine
old marine
