Question about LG RUMOR Cellular Phone
Reset factory settings
I have the LG Scoop and need to send it back, but before I do that I have to reset it to the original factory settings, but can't find directions on the alltell website of how to do that.
  • rohonius May 11, 2010
    reset just the settings or wipe out the whole phone?
Try going to your menu. then go to settings. after that, go to security and type in ur security code in. then go to reset default then press ok... i had to do this once b4 & im prob gonna have to do it again.. i hope this helps
Posted on Aug 05, 2009
How do you hard boot into recovery mode,volume down and power then release both and press again on lg screan dont do it both ways only factory reset
Do not forget to backup your phone’s data before doing a factory data reset. Here’s our guide.
Performing a Factory data reset restores your device to the original factory settings as it comes out of the box. It also deletes the data like installed apps, contacts, messages, images, etc. present on the internal storage. It does not, however, affect any data stored on the external SD card. Now here is how you can hard reset your LG G2/G3 from device Settings:
Tap the Menu key from Homescreen.
Select System settings> General.
Now scroll to PERSONAL.
Select Backup & reset option.
Tap Factory data reset> Reset phone.
Select Erase everything.
When the warning window prompts, tap OK.
Hard Reset LG G2 with Hardware Keys
If you unable to perform a factory data reset on your LG G2/G3 using the device settings for some reasons, you can try the hardware key method. Just follow the steps given below:
Turn off your LG G2/G3.
Now press and hold the Power + Volume down buttons simultaneously for about 8 seconds.
When the LG Logo appears, release and then immediately re-hold the Power button.
Release the Power key as soon as you see the ‘FACTORY HARD RESET’ screen.
Press the Power key to reset your device.
Press the Power key again to confirm factory data reset.
Wait till reset is done.
Boot LG G3 /G2 into Safe Mode
To fix an issue caused by a 3rd-party app, you can boot your LG G3/G2 into Safe mode and delete the suspect app. You can turn on Safe mode by following these steps:
Jan 06, 2016 | LG Cell Phones
How do I get into my lg phone when I forgot my pin/password
The only way to get back into your device is to do a factory reset. Keep in mind, Google has an activation lock to prevent theft of your device. With that being said, after you factory reset your phone it may ask you to login to the original gmail account that your device was set up with.
To do a factory reset, you need to boot the phone into recovery mode:
  1. Power down the device
  2. Hold down the following keys:
    Volume Up + Home + Power
    or
    Volume Up + Home + Search
Nov 14, 2015 | Android LG Optimus Dynamic II LG39C...
I have an LG Optimus TMOBILE phone, and the talkback is on, I can't get to the Assisablity screen in the settings. How can I disable this?
get your manual here,
LG Support USA Customer Service and Technical Support LG USA
1.From the Home screen, touch the Menu Key .
2.Touch Settings > Privacy > Factory data reset.
Read the warning and touch Reset phone
If your phone does not restore to the original condition, use a Hard Reset (Factory Reset) to initialize it.
When the phone is turned off, press and hold the
power/lock key and down volume,after 5 seconds, keep pressing the previous keys and touch and hold the Menu Key + Back Key (must be done before the touch key LED lights turn on). When the LG logo appears, release the Power/ Lock Key but keep pressing the rest of the keys. The phone will perform a factory reset immediately. WARNING: If you perform a Hard Reset, all user applications, user data and DRM licenses will be deleted. Please remember to back up any important data before performing a Hard Reset
May 14, 2015 | LG Cell Phones
Need to hard reset my LG.l34c Mobil phone
To hard reset your LG I34c mobile phone, follow below instructions.
Note: Back up all your important and personal data before factory restore. Factory restore will erase all your data and restore device to its original manufacturer settings.
1. Turn the phone off, hold the Home and Volume Down button and then press and hold the Power button too until the device turns on.
2. You will get wipe data / factory reset option
3. With VOLUME buttons select wipe data / factory reset
4. Confirm with Menu key.
GuruAid.com
Dec 19, 2014 | Cell Phones
Reset LG 55G2 to factory settings
How to update my LG 55g2
Dec 28, 2013 | LG 55G2
How to reset an lg keybo
From Telus Mobility website at http://mobility.telus.com/en/AB/LG-9100-Keybo/device-details.shtml LG KEYBO 9100 Reset your phone to its original state There are several reasons that you may want to reset your phone to the original factory settings. For example, you may be giving it to someone else, or you may find yourself with no other way to resolve a serious issue such as a frozen screen. CAUTION:
Resetting your phone deletes your ringtones, contacts, pictures, messages, and other downloaded content.
  1. From the Home screen, press the OK key.
  2. Select Settings.
  3. Select Phone Settings.
  4. Select Security.
  5. Type your lock code. This is typically the last four digits of your phone number (unless you've changed it).
  6. Select Reset Defaults.
  7. Press the OK key to confirm.
  8. Select Revert.
Your phone is reset to its original factory settings.
If these steps are unsuccessful, visit a Product Care Centre to have your phone inspected. Use our Store Locator to find the closest location.
Nov 19, 2012 | LG Telus Keybo 2 CePhone Pink - Keybo 2
Reset bios on lg ls670
Factory reset is the only way that there is.
Jan 24, 2012 | LG Cell Phones
I have reset my lg kf700, afterthat only picture is visible
hi
I have an LG KF700 and when I turn on my lg is the written and does nothing
how can I do?
thanks
Jul 28, 2009 | LG KF700 Triband 3G HSDPA 3MP A2DP Phone...
How do you reset to factory settings?
settings>general scroll down when you find restore
Jan 22, 2009 | Cell Phones
Wold clock display
You will need to reset the phone in it's settings
Dec 05, 2008 | LG VX8300 Cellular Phone
LG RUMOR Cellular Phone Logo
1,191 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
