Question about RCA L42WD22 42 in. LCD Television
No picture rca hdtv dlp model number m50wh72s
When I turn on my tv about 3/4 up there is a solid white box with black spots in it and up above it there is a solid black bar then above it there is another white box with black spots in it. The sound is fine but nothing else menu or nothing will show up on screen. You can see the color changes behind it. help!!!!!
  • EG-DLPless Apr 10, 2009
    I have the same problem M50WH187YX1. I have a white screen with stationary black spots or specs and about 3/4 of the way up there is a solid black horizontal bar. Above the bar is the same white screen with black spots. Sound is fine, channels can be changed, but the white screen does not change. This happened interminttently for 6+ months and would come back with a power cycle. Now it will not work at all (only white screen). Any ideas?
SOURCE: "weak signal" on my RCA scenium
Hey! I have the same problem as you. But! this would happen only when I got a power outage. Unplug the TV for a couple of minutesand all was fine. For the last 5 day I have no TV. I have tried everything. All the out on the TV and I still get unusable signal. My rep told me to unplug for 24 Hours. Still didn't work. My menu option work as well and every time I put the TV on, off or if I change the input sound will come on for 2 seconde and stop. If I find the salution I will let you know. Gilles Ottawa
Posted on Apr 12, 2007
SOURCE: RCA TV flickering problem
Help! I have an RCA 40 inch HDTV (Model# D40W20). I've had it since 2005. Recently, the picture will flicker when I turn it on, but will stop flickering after a few minutes. My brother has the 52 inch model and his tv did the same thing before it broke down completely. Does anyone know what the problem could be?
Posted on Jul 24, 2008
  • 18 Answers
SOURCE: dark picture on RCA Scenium 61 in DLP
Yes, the lamp will gradually get darker as it nears it's end. The rolling lines sounds more like the set is on a local channel for the cable hook up. If your local area has a channel 3 or 4 live terestrial broadcast simply tune the cable box output to the other one, the same for the tv.
If this is cable/local broadcast issue it will go away in Febuary when the NTSC broadcast ends.
Posted on Jan 15, 2009
SOURCE: no picture good sound good lamp can change channel
I have the exact same TV and have had the exact same problem. I talked to a TV repairman who said it has to be my deflection board. I just found this out today so I am looking all over the web for a deflection board. I hope this helps! Tyson
Posted on Oct 07, 2009
circuitworld
  • 335 Answers
SOURCE: rca 32 screen turns on but stays black
Theres no start-up signal being encoded, this means the interface board has an offset capacitive value. You need to test and measure the capacitors and npn/pnp transistors, along finding some open diodes too on the main board (interface). You have to test the capacitors under their operating voltage also to see at which point their breaking down. The problem is a 'load' condition on the main board. You can repair the board if your savy and you have test equipment or you can just replace the board. If you want to replace it e-mail me and I'll help you out....
Posted on Nov 25, 2009
Rca dlp model /page-2
White dots on a DLP are ALWAYS a DMD chip problem, you can find these online like at Discount-Merchant, they are easy to replace you can find videos on youtube, they are sometimes called DLP chip.
Easy to do for a fairly experienced or handy person!
Feb 21, 2014 | RCA 50in Tv M50 Wh 92s Dlp Hdtv Works But...
White dots on screen
http://www.metacafe.com/watch/yt-XeIOwN1CIp8/samsung_mitsubishi_toshiba_dlp_hd_tv_repair_tips_black_white_dots_on_tv_problems_bad_dlp_chip/
I believe it is the digital projection chip that is beginning to fail. Causing white and black spots to appear. To repair this may cost more than a new tv. If you want to attempt it yourself check out the above link. Hope this helps
Jan 12, 2014 | Samsung Hl61a750 61" LED Powered DLP HDTV
I have a rca m50wh72s dlp tv was watching the tv one day and then herd a loud pop noise and the tv went black i try to turn it on it makes a funny rubbing noise like plastic on plastic and then the power...
Sounds like the color wheel or lamp I would check the lamp first to insure thats its not broken as they can make a pop when they fail sometime (Breaking) then I would check the color wheel you will be able to tell if the color wheel arear has the noise coming from it. If you need more assistance let me know.
Jun 13, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
When I try to hook up my nintendo wii to an hdtv I get a black and white picture? The RCA cable only has 3 cables and the input on the tv has 5 outlets.. could this be the reason? how can I get it to work?
The RCA cable you are using is meant for standard resolution TV's. There should be a spot on the HD TV for the standard RCA cable. This will resolve the black and white color issue but unfortunately you will not get the benefits of your HD TV. Your best be is to get a composite cable for the Wii. You can get the cable from target or wall-mart but online shopping will typically result in a cheaper price.
I hope the info listed above has helped in some way.
If possible please rate this solution.
Aug 26, 2010 | Nintendo Wii Console
No picture, siren type noise as restarting
My Toshiba dlp 62hm116 was used for 3 months then stored for 2 years, I turned it on yesterday and it makes a loud grinding noise which I think is probably from the exhaust fan area and the picture is black except white at both vertical sides. It worked fine the last time I used it 2 years ago. Any ideas?
Jan 13, 2010 | Toshiba 62HM95 62" DLP HDTV
White spots on Samsung DLP
Hello the problem here is absolutely the DMD Board this is a commune problem with the Samsung DLP
are your spots like this picture?
try this link...
http://www.discount-merchant.com/
Jun 12, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
No picture good sound good lamp can change channel
May 31, 2009 | RCA M50WH185 Television
Online guide to RCA M50WH72S Television
i do not know what happened to my RCA model # M50WH72S
i woke up and went to turn it on and the power was already on and the screen is black and no sound. and the television wont turn off with remote or from front of t.v i have to unplug it. same thing once i plug it back in the t.v power button is on and no picture or sound and wont turn off does anyone know if i need to replace a part ? and where i could find it i dont wanna pay a lot to have someone look at it. i checked the bulb and its in good shape. please help.
Oct 19, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Toshiba 46HM84 DLP Black and white pattern..
contact your dealer for service flashfor this symptom.(light tunnel)
Aug 11, 2007 | Toshiba 46H84 46" Rear Projection...
RCA L42WD22 42 in. LCD Television Logo
278 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
