Question about Labtec 961307-0914 Webcam
I cannot record a video WITH SOUND to send it by e-mail
Hi:
I have been trying to record a video with sound to send it as an e-mail with no success:
When I want to use the audio tuning wizard the indicator bar doesn`t work even if I shout into the microphone, the thing I did is to put the microphone INTO my mouth and uttered a loud sound and the indicator bar showed some volume levels (blue bars), the thing is that I cannot talk with the tip of the mike inside my mouth.
I do not have other application running that records sounds, I tried other head set and still the same problem. I tried the head set with another application that records sounds and it worked.
I uninstalled the labtec application and reinstalled it again from the disk and still the same problem. Can you help me ?
  • bibuad Feb 18, 2009
    I am using Windows XP
  • Roberta Smith
    Roberta Smith May 11, 2010
    vista or xp ?
    Brigadier General:
  • 5,158 Answers
Have you checked to make sure your mic isn't muted ? ... click on the speaker icon in the bottom right of you screen... if microphone is on that list make sure it's not muted... if it's not on the list you can add the control for it... i believe it will say device at the top of that window. add it and make sure it's not muted
Robert
Posted on Feb 18, 2009
Audio recording for toshiba nb520
Troubleshoot: Unless you already did this, go to Device Manager and check the properties of all other hardware involved.
Mar 14, 2013 | Toshiba NB520-11W
Tip
How To Create and Send Video Mail for Free
Today anyone with a webcam can quickly and easily create and send video messages for free. You don't have to record videos with expensive equipment, and you don't have to download software. Best of all no expertise is required. If you can create and send text email you can send video mail.
Most people believe that sending videos means recording very large files with a camcorder, and trying to attach it to an email. It usually doesn't work due to email file attachment size limits. mailVU.com is one solution that doesn't require camcorders or file attachments. They have a free video mail service that doesn't require a software download, and it doesn't require a user account. I tried it and put together this step-by-step process for creating your first video mail.
What do you need for video mail?
  • Computer (PC, MAC, Linux all work)
  • Webcam
  • Microphone, either built-in to your webcam or laptop, or external headset
  • Broadband Internet connection
Begin by opening any browser (Internet Explorer, Chrome, Firefox, Safari, etc.) and going to http://mailVU.com. You will be prompted by the following request to allow access to your webcam. Select Allow.
Now you should be able to see yourself on the left side under Live Camera. If you don't see yourself click on the drop down list of cameras and select the one that works for you. On the Mac it is typically called USB Webcam. Note that until you record a message the deletion options and email option is grayed out at the bottom of the screen.
Click the red Record button above your image to start the 1 minute recording session. This button will change to Stop after you click it, a notification will appear that recording is in process, and a timer counts down from 1 minute. When done click the red Stop button.
Now that the recording is made the information at the bottom of the screen is available to use. You may play back your message before sending it to someone. To play it back simply click the green Play button above your image. Your recording will now play in the right side window while you still see yourself live in the left side Live Camera window.
If you want to record over your message, click the red Record button again to overwrite it. When you are happy with your recording decide if you want to use an auto deletion function at the bottom.
The default deletion time frame is 30 days, but you can change it to anything between 1 and 30 days. And you could also specify the video to be deleted after a certain number of views. If both are checked then whichever event happens first will destruct the video mail.
You can now click Send this as a Video Mail and you will have the following screen to populate:
You fill in the email address fields, and you have the option of adding a text message to your video mail. You can copy yourself if you click the box at the bottom. When done click Send Email. Congratulations! You have now sent your first video mail!
The user will receive an email which is less than 25kb in size that includes a picture of you linking to your video message. They click on your picture and click play and they will be able to hear and see you. To record a video message back to you they can follow this same process.
By using this process anyone can quickly and easily send video messages to anyone in the world.
on May 30, 2010 | Computers & Internet
When I record a video, the camera does not record the sound
This is caused by one of two things.
The first thing is that you might have accidentally activated the mute function and as a result, it cannot record the sound of the environment since the mic has been de-activated.
The second and most likely thing is that your mic is faulty and can also not record the sound in your environment.
You can try to restore the default settings and see if there is any change as the mic settings may have been altered but if it doesn't then you have to send it to an expert technician to help you change the mic.
Hope this solution helped you? Please comment if you need more information and thank you for using Fixya.com
Jan 01, 2011 | Cameras
Sound
To set up Facebook, Log-into
http://www.facebook.com/login.php
and then go to SETTINGS.
Then click on APPLICATION SETTINGS.
Then go down on the left and click on VIDEO.
Welcome to Video
Your life in motion.
Share your personal videos.
Upload and tag videos of you and your friends on Facebook. Upload a new video
Record and send video messages.
Use your webcam to record yourself in a video message. Record a video message
Publish videos from your mobile.
Send your mobile videos via Facebook
Mobile to video@facebook.com
Then click on Record and send video messages. and in the Adobe Flash player click on ALLOW.
This will start your camera to create your video to send to your friend or contact.
After creating the Video, click on ATTACH.
· Then Compose Message
To:
^_^
Subject:
Message:
Attach:
remove
Record Video
Post Link
Hope this is of some help to you. Bud
Jan 18, 2010 | Radio Shack VGA PC Camera Webcam
Cannot E-mail video
Try the free video email service on http://mailVU.com. You can record and send 10 minute videos for free.
Feb 16, 2009 | Genius VideoCAM Messenger Webcam
Lumix LS80 video camera no sound
Hi, i had the same problem 4 ages. every time i tried to playback my videos there was no sound, i did so many videos trying to get the sound going and then i played them on my computer and ther was sound, :) lol i felt like such an idiot when i found out there's no speaker on the camera it self.
Dec 28, 2008 | Panasonic Lumix DMC-LS80 Digital Camera
No sound
Hi , try to play your old video taken if still have no sound , if the same no sound the audeo system has a problem.
If having sound in old video collection , the tape that you are using now are having deffect connot record sound. replace a new tape, and try record again.
Jan 15, 2008 | Sony Handycam DCR-TRV22E Mini DV Digital...
Lcd screen black when recording. vcr playback only sound
I contacted Canon via e-mail and they are going to fix the problem for free and pay the shipping. You should go to www.canondv.com and send them an e-mail or call them.
Oct 31, 2007 | Canon ZR60 Mini DV Digital Camcorder
Labtec 961307-0914 Webcam Logo
35 people viewed this question
Top Labtec Computers & Internet Experts
micky dee
Are you a Labtec Computer and Internet Expert? Answer questions, earn points and help others
