Home | Pioneer | DVD 500M (DVD-500M) Internal DVD Drive | Installing game (Max Pay...
Pioneer DVD 500M  Internal DVD Drive
Problem for Pioneer DVD 500M (DVD-500M) Internal DVD Drive
Installing game (Max Payne 2) on a slave drive
By Putty - usenet poster
Folks,
I just tried to install a game on my new slave IE HD. Is there any
reason why I cant?
During the install, it asks me to install it to a default folder within the
C: (master) drive, but I redirected it to a similarly named directory on my
new D: (slave) drive. It all seemed to install OK, writing the files
successfully. But (the game is the new Max Payne 2 BTW) it wont run, the
.exe is running in task manager, but the game wont start. I know this might
be a game problem/bug, but I just wanted to check that you are actually
allowed to install games on a 2nd drive (silly question maybe, but I
genuinely don't know).
tia
temor
Best Solution
posted on Aug 01, 2007
Helpful)
Charlie
Rank: Apprentice
Rating: 0%, 0 votes
Temor,
I make no judgements about your work-around. I'm just happy to hear you
were able to work-around the issue.
You might offer some help for future news-group posters by starting a thread
listing that MP2 has problems with your brand and model of drive. Maybe
other people with that brand and model are experiencing the same issues.
Thanks,
Nick Kritselis [MS]
This posting is provided "AS IS" with no warranties, and confers no rights.
read more »
Was this helpful?
Yes
No
Solution #2
Not Rated)
Odud
Rank: Apprentice
Rating: 0%, 0 votes
Thanks Nick,
I did try the1.01 patch for MP2, but no different.
Checking some of the game forums it would suggest that the problem lies with
the CD-copy protection code and its unfriendliness? with some of the CDROMS
and DVDROMs firmware out there (dont know how true that is tho'). But I got
around the problem by installing a no-cd crack for the game (not the best
way, but at least it got me around my problem). Just in case you are
wondering, I did BUY the game, I just didn't want a set of $50 coasters !!!!
Hence my mail.
regards
temor
But if it aids you in resolving the problem for others I would be more than
happy to include the DxDiag output
System Information
Time of this report: 10/28/2003, 17:41:16
Machine name: myprivatenamedeleted
Operating System: Windows 2000 Professional (5.0, Build 2195) Service
Pack 4
Language: English (Regional Setting: English)
System Manufacturer: INTELR
System Model: AWRDACPI
BIOS: Phoenix-Award BIOS v6.00PG
Processor: Intel(R) Pentium(R) 4 CPU 1.70GHz
Memory: 512MB RAM
Page File: 197MB used, 1048MB available
Windows Dir: C:\WINNT
DirectX Version: DirectX 9.0b (4.09.0000.0902)
DX Setup Parameters: /PackageInstall
DxDiag Version: 5.03.0001.0902 32bit Unicode
DxDiag Notes
DirectX Files Tab: No problems found.
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Music Tab: No problems found.
Input Tab: No problems found.
Network Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (n/a)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (n/a)
DirectMusic: 0/5 (n/a)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: NVIDIA GeForce3 Ti 500
Manufacturer: NVIDIA
Chip type: GeForce3 Ti 500
DAC type: Integrated RAMDAC
Device Key: Enum\PCI\VEN_10DE&DEV_0202&SUBSYS_53011462&REV_A3
Display Memory: 64.0 MB
Current Mode: 1024 x 768 (16 bit) (75Hz)
Monitor: ImageQuest Q770
Monitor Max Res: 1280,1024
Driver Name: nv4_disp.dll
Driver Version: 6.14.0010.4403 (English)
DDI Version: 9 (or higher)
Driver Attributes: Final Retail
Driver Date/Size: 5/2/2003 14:19:00, 3180171 bytes
WHQL Logo'd: n/a
WHQL Date Stamp: n/a
VDD: n/a
Mini VDD: nv4_mini.sys
Mini VDD Date: 5/2/2003 14:19:00, 1312555 bytes
Device Identifier: {D7B71E3E-4142-11CF-E166-0B7302C2CB35}
Vendor ID: 0x10DE
Device ID: 0x0202
SubSys ID: 0x53011462
Revision ID: 0x00A3
Revision ID: 0x00A3
Video Accel: ModeMPEG2_A ModeMPEG2_B ModeMPEG2_C ModeMPEG2_D
Deinterlace Caps: {212DC722-3235-44A4-BD29-E1652BBCC71C}:
Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,2)
Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
DeinterlaceTech_PixelAdaptive
{212DC723-3235-44A4-BD29-E1652BBCC71C}:
Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1)
DeinterlaceTech_MedianFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}:
Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0)
DeinterlaceTech_BOBVerticalStretch
Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,2)
Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,1)
Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0)
Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,2)
Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,1)
Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0)
Registry: OK
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
DDraw Test Result: Not run
D3D7 Test Result: Not run
D3D8 Test Result: Not run
D3D9 Test Result: Not run
Sound Devices
Description: SB Live! Audio [C000]
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: PCI\VEN_1102&DEV_0002&SUBSYS_80651102&REV_0A
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: ctaud2k.sys
Driver Version: 5.12.0001.0252 (English)
WHQL Logo'd: n/a
Date and Size: 7/19/2002 09:47:52, 837548 bytes
Other Files:
Driver Provider: Creative
HW Accel Level: Full
Cap Flags: 0x0
Min/Max Sample Rate: 0, 0
Static/Strm HW Mix Bufs: 0, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
Voice Management: Yes
EAX(tm) 2.0 Listen/Src: Yes, Yes
I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Registry: OK
Sound Test Result: Not run
Sound Capture Devices
Default Sound Capture: Yes
Default Voice Capture: Yes
Cap Flags: 0x0
Format Flags: 0x0
DirectMusic
DLS Path: C:\WINNT\SYSTEM32\drivers\GM.DLS
DLS Version: 1.00.0016.0002
Acceleration: Enabled
Ports: SB Live! DirectMusic Synthesizer [C000], Hardware (Kernel
Mode), Output, DLS, Internal, Default Port
MPU-401, Hardware (Kernel Mode), Input, No DLS, External
MPU-401, Hardware (Kernel Mode), Output, No DLS, External
SB Live! Audio [C000], Software (Kernel Mode), Output,
DLS, Internal
Microsoft MIDI Mapper [Emulated], Hardware (Not Kernel
Mode), Output, No DLS, Internal
MPU-401 [Emulated], Hardware (Not Kernel Mode), Output, No
DLS, External
SB Live! Sw Synth [C000] [Emulated], Hardware (Not Kernel
SB Live! Synth A [C000] [Emulated], Hardware (Not Kernel
SB Live! Synth B [C000] [Emulated], Hardware (Not Kernel
SB Live! MIDI Port [C000] [Emulated], Hardware (Not Kernel
Microsoft GS Wavetable SW Synth [Emulated], Hardware (Not
Kernel Mode), Output, No DLS, Internal
MPU-401 [Emulated], Hardware (Not Kernel Mode), Input, No
DLS, External
Microsoft Synthesizer, Software (Not Kernel Mode), Output,
DLS, Internal
Registry: OK
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Keyboard
Attached: 1
Controller ID: n/a
FF Driver: n/a
Device Name: Microsoft SideWinder 3D Pro
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x045E, 0x0F1F
FF Driver: n/a
Poll w/ Interrupt: No
Registry: OK
USB Devices
+ USB Root Hub
| Matching Device ID: usb\root_hub
| Service: usbhub
| Driver: usbhub.sys, 6/19/2003 19:05:04, 40176 bytes
Gameport Devices
+ Intel(R) 82801DB LPC Interface Controller - 24C0
| Matching Device ID: pci\ven_8086&dev_24c0
| Service: isapnp
| Driver: isapnp.sys, 6/19/2003 19:05:04, 46992 bytes
+-+ Standard Game Port
| | Matching Device ID: *pnpb02f
| | Service: gameenum
| | Driver: gameenum.sys, 6/19/2003 19:05:04, 9808 bytes
| +-+ Microsoft SideWinder (Auto Detect)
| | | Matching Device ID: gameport\sidewindergamecontroller
| | | Service: msgame
| | | Driver: hidclass.sys, 6/19/2003 19:05:04, 24752 bytes
| | | Driver: hidparse.sys, 6/19/2003 19:05:04, 23056 bytes
| | | Driver: hid.dll, 6/19/2003 19:05:04, 18192 bytes
| | | Driver: msgame.sys, 10/26/1999 14:30:50, 35440 bytes
| | | Driver: sw_effct.dll, 11/30/1999 22:39:48, 45328 bytes
| | | Driver: sw_wheel.dll, 11/30/1999 22:39:48, 60176 bytes
| | +-+ HID-compliant game controller
| | | | Matching Device ID: hid_device_system_game
PS/2 Devices
+ Cherry Universal PS/2 Keyboard Driver
| Matching Device ID: *pnp0303
| Upper Filters: chyunikb
| Service: i8042prt
| Driver: i8042prt.sys, 6/19/2003 19:05:04, 46992 bytes
| Driver: kbdclass.sys, 6/19/2003 19:05:04, 24528 bytes
| Driver: chyunikb.sys, 9/21/2000 14:39:08, 17397 bytes
+ Microsoft PS/2 Port Mouse ...
read more »
Was this helpful?
Yes
No
Solution #3
Not Rated)
Odud
Rank: Apprentice
Rating: 0%, 0 votes
Temor,
If the game allows you to install to a different drive, it should run just
fine from that drive. Since you see the exe running in Task Manager, then
you can actually run the game, but something else is causing it to hang
before you can actually see the window it's supposed to run in.
Have you installed the latest patch for the game? (If not, you can get the
patch from -
If you have the patch already, or you install the patch and still cannot get
Max Payne 2 to run, please reply with a copy of your DXDiag text and we'll
see if we can help you to resolve your issue.
To reply with a dxdiag text:
Click on Start - When the DirectX Diagnostic Tool window appears you will see tabs across the
top click each tab and run the diagnostic tests on each. Then click the
'Save All Information' button, which will create a text file on your system
where you specify, as in My Documents or Desktop. Open that text file, copy
the contents and paste it to a reply.
Thanks,
Nick Kritselis [MS]
Was this helpful?
Yes
No
Popular Solutions for Pioneer DVD 500M Internal DVD
Questions and Unsolved Problems for Pioneer DVD 500M Internal DVD
Do you recommend Pioneer DVD 500M (DVD-500M) Internal DVD Drive?
Answer
Answer
I have Windows XP and i tried to change my monitor's colors. After that the background became black... (More)
Answer
I have a Matsui DVD225 which refuses to eject or respond to the remote control. What do do?
Answer
im looking for softwear for LG gdr - 8162b dvd rom to download for free. can Anyone help pleaseeeeee
Answer
i cannot change the region, it says i have 1 chance left but won't let me change
Answer
my game is igi is not paly.....because some problem... prb.......is D3D drivers not... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Pioneer DVD 500M Internal DVD...:
Top DVD Drive Experts
Rank: Guru Guru
Solutions: 14110
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more DVD Drive Experts
Top Computer & Laptop Repair
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
