Optical engine for akai pt50dl14
Where can I buy an optical engine for akai model # pt50dl14
  • 298 Answers
Here's a link to order the original Akai light/optical engine for this model (PT50DL14) from a major parts distributor:
Akai Samsung PT50DL14 Replacement Part Light Engine / Optical Engine Block
Posted on Feb 18, 2009
PT50DL14 won't turn on,
You need to replace your color wheel.
Aug 21, 2012 | Akai Televison & Video
Pt50dl14 i changed the lamp turned tv on. bulb lit then shut down within seconds. now the lamp and stand by/ temp. are flashing and tv will not turn on?
If Akai brand that is Samsung (they own the name).
I have a simple suggestion-----remove the lamp with cartridge (set unplugged) and look where the lamp faces-----the color wheel this model uses fails--I will attach a photo.
What you are looking for is: are any segments missing or the wheel even shattered?
These fail often and the set if wheel (turns at over 8,000 rpm) slows down, shattered, or missing pieces the set will detect that and turn the lamp off almost instantly.
Let me know as if this is the problem it can be a do it yourself replacement as You Tube has video instructions for this on most models.
Apr 13, 2012 | Televison & Video
Akai DLP projection TV. Picture is fine except lamp is not illuminating a 3-4in area on the left side of the screen. You can see the picture over there but it is dimly lit. I can't seem to find a way to...
The problem is the light tunnel is collapsing. This is a VERY common issue with the Samsung/Akai DLP TV's. It is four mirrors used to transfer the light after it passes the color wheel to the DMD board. When part of it collapses the grey bar that you are seeing is the end result. This is a part that usually requires a technician to replace as there is a little tear down of the light engine itself and you would be handling delicate parts. The part number for the tunnel assembly is BP96-01961A and I have included a link so you can purchase it through the Samsung website. Please take a few moments to rate my answer. Thanks..
http://www.samsungparts.com/part_detail.asp?catalog%5Fname=Parts+and+Accessories&product%5Fid=BP96-01961A&search%5Fmodel=PT50DL14
Nov 20, 2009 | Televison & Video
Rubber band for Akai semi automatic turntable APX1 needs replacing. Where can I buy one in NZ?
Are you sure you have an Akai APX1? I've never known Akai to make turntables. I think you mean AIWA - yes, there is a MAJOR difference.
For the Aiwa APX1 model, you can purchase the belt HERE.
- OPTiC
MasterTech
Digital Analog Therapy
Turntable Parts : Turntable Repairs
Aug 31, 2009 | Audio Players & Recorders
Replaced lamp and still no pic lamp light comes on then lamp light goes out PT50DL14
This Akai TV is actually built by Samsung. You need to count the blinking lights on the front panel.This indicates an error code.With the code I can tell you what circuit has failed in the TV.
Jul 30, 2009 | Televison & Video
Damage lamps interior around the screen AKAI LCT3285TA LCD 32"
You can purchase parts for your television at:
circuitcity.partsearch.com/Model/Akai/Akai/LCT3285TA.aspx
or
www.looking4parts.com/search/?custid=4582&PIndex=47
or
tigerdirect.partsearch.com/Search/Model/Akai/Akai.aspx
or
www.shopjimmy.com/searchparts.cfm?make=Akai
or
www.partstore.com/
or
www.akai.com/
Jan 17, 2009 | Akai LCT3285TA 32 in. LCD Television
Having problems with HDMI connection from COMCAST Motarola HD Dual TUNER DVR HDMI DCH6416 to Panosonic Home Theater system SA-PT660 to AKAI LCD HDTV. There is only one HDMI Output on the COMCAST box; one...
Connect the HDMI outputs on your various components to the HDMI inputs on your receiver. Connect the HDMI output on the receiver to the input on your TV. HDMI incorporates digital audio, so no need to buy optical audio cables. If your receiver does not have HDMI inputs for all your components, you will need to make a choice. HDMI = Best, component video + optical audio = second best, S-video+ optical audio = third best
Jan 01, 2009 | Onkyo TX-SR606 Receiver
AKAI DLP PT50DL14, NO VISUAL OR AUDIO , SOME KIND OF GRINDING NOISE WHERE THE LAMP IS.. I HAVE TURNED IT OFF FOR 5 MINUTES AND STILL THE SAME PROBLEM
This is your color wheel bad it is a moving part please do not use you will damage it more. to fix this you will have to hire a tv repair shop. cost if only color wheel is around 450.00. and in some cases you have to replace the light engine which would be around 950.. to fix.
Thanks doctor video
May 18, 2008 | Televison & Video
Akai PT50DL14
is it in the screen it self ?
Feb 08, 2008 | Televison & Video
Televison & Video Logo
405 people viewed this question
Top Televison & Video Experts
