Question about Samsung Televison & Video
I have a Samsung 50" model HLN5065W. It is about 3 years old. The red color no longer displays - just yellow, green, and blue. I hear no unusual noises that would suggest the color wheel is bad. The quality of the picture seems okay, other than the color problem.
  • cookcook01 Feb 18, 2009
    Right now, I would say the color wheel is bad....  The CRT would not cause this kind of problem....  I am no expert but your answer is incomplete.  I want to fix the problem and for $17.99, I would expect more....
    Okay, I will reexamine what you have suggested. I still think it is the color wheel rather than the crt.
  • 716 Answers
If Qualified You May Wanna Check All The Connections Inside The Television To Make Sure All The Cables Are Tightly Secured. Make Sure You Unplug The Unit And Attempt To Restore Factory Defaults Just To Make Sure Its Not A Hardware Setting That Has Been Adjusted. But For It To Be The Color Wheel The Symptoms You Describe Aren't Of The Color Wheel Going Bad. The Color Wheel Or Engine Going Bad Is Usually Indicated By A Blurred Or 3d Look.
I Hope This Helps.
Sincerely,
Michael Scott
Posted on Feb 17, 2009
  • Michael Fisher
    Michael Fisher Feb 18, 2009
    Please Tell Me The Outcome I Will Be Waiting To Hear From You.
    I Will Do Everything In My Power To Earn You As A Costumer And To Make Sure You Are %100 Satisfied With The Service We Provide.
    Sincerely,
    Michael Scott
  • Samsung Master
  • 19,396 Answers
No it is not the color wheel , probably crt problem.
  • Ginko
    Ginko Feb 17, 2009
    This is not a Crts model.
    When the color wheel is bad you get poor color or areas with very bright colors, if you have faded red, the color wheel can be damaged only on the red area , but that is unusual.
    if you have no red color start checking the cble that connects to the receiver.
    If it is not that it can be a problem on DMD board.
I need to know what the various colored wires connect to since I needed to remove the old amp and install an after market stereo.
Check the speakers connection and that should give you at least 8 of the colors. The ones left then are going to be ground and power and display power. You can figure those out with a meter.
Aug 24, 2015 | 1994 Volvo 940
Contrast really dark but seems to improve after the tv has been on several hours
Hi:
You may have a problem with the inverters in the unit, they are responsible for lighting up the back panel. Check or have checked the power supply voltage to the inverters, should be around 18-24 volts DC. Also leaky capacitors on the power supply will cause this issue as well as leaky or puffy capacitors on the inverter.
Sep 08, 2011 | LG 32LG30 32 in. LCD HDTV
Green tinted people
The only time I have had issues like this was because of the Component Cables not being in the right position (the Red and Blue connections switched), or a bad Component Cable where the Blue Connection is not receiving a signal. Swap out the cable to be sure and double check that it is properly installed. Green to Green, Red to Red , Blue to Blue.
Hope this helps,
skyassoc
Jul 18, 2009 | Samsung HLN5065W 50" Rear Projection...
Screen gone yellow and green
I have a 21'' NEC TV Screen and it about 3 year old. the colour has gone to yellow and green color and the red etc
May 10, 2009 | Samsung PPM42S3 42 in. Plasma Television
1998 dodge ram 1500 4x4 stereo wiring
glad you posted what colors you do have , cause 2 resources didn't match ,actually 3 , i did find a match to your colors was a 97 year model premium radio, so we have a match .....
black/ light green = ground
dark green = left front spkr +
purple = right front spkr +
blue/white = right rear spkr -
brown/blue = left rear spkr -
brown/yellow = left rear spkr +
blue/orange = right rear spkr +
black/yellow = park lamps
brown/red = left front spkr -
orange = dimmer signal
pink = fused battery +
green/red = radio choke relay
red/white = fused ignition
blue/red = right front spkr -
cheers
djmac62 is also an excellent answer
Jan 10, 2009 | 1998 Dodge Ram 1500 4WD
DLP Colors Are Off - Picture Is Mostly Blue and Yellow
Sounds like you've lost your red video signal (chroma) somewhere along the line. This tv has a 3 board video path. Analog main pcb --->Digital main pcb --->DMD pcb. The analog has all your inputs on it, except DVI and RGB which go straight into the digital board. The digital scales (upconverts) the signal to HD (1080 or native) and sends it to the DMD or light engine. See which inputs are distorted. If only DVI is clean then you problem is the analog board. If you menu and everything is distorted then suspect the DMD board. If you run component or DVI through the resolutions (480i, 480p, 720p, 1080i) you can get an idea between the digital board and dmd. The menu is generated on the digital board. Somewhere red is getting lost.
Dec 08, 2008 | Samsung HLN5065W 50" Rear Projection...
Picture calibration settings for 42lg70
Picture Menu
Picture Mode: Expert1
*Backlight: 16
*Contrast: 83
*Brightness: 53
Sharpness: 50
*Color: 55
*Tint: 0
Expert Control
  • Fresh Contrast: Off
  • Noise Reduction: Medium
  • Gamma: Medium
  • Black Level: Low
  • Real Cinema: On
  • TruMotion: Low
  • Color Standard: HD (N/A w/HDMI)
  • White Balance: Warm
  • **Method: 10-Point IRE
    • 10 IRE
      • **Red: 1
      • **Green: 2
      • **Blue: -16
    • 20 IRE
      • **Red: -6
      • **Green: 0
      • **Blue: -7
    • 30 IRE
      • **Red: -5
      • **Green: 0
      • **Blue: -4
    • 40 IRE
      • **Red: -8
      • **Green: 0
      • **Blue: -4
    • 50 IRE
      • **Red: -4
      • **Green: 4
      • **Blue: -4
    • 60 IRE
      • **Red: -6
      • **Green: 6
      • **Blue: -5
    • 70 IRE
      • **Red: -8
      • **Green: 3
      • **Blue: -10
    • 80 IRE
      • **Red: -8
      • **Green: 7
      • **Blue: -16
    • 90 IRE
      • **Red: -9
      • **Green: 5
      • **Blue: -18
    • 100 IRE
      • **Red: -10
      • **Green: 4
      • **Blue: -9
Color Management System
  • Red Color: 0
  • Red Tint: 0
  • Green Color: 0
  • Green Tint: -15
  • Blue Color: 0
  • Blue Tint: 11
  • Yellow Color: 15
  • Yellow Tint: 2
  • Cyan Color: -15
  • Cyan Tint: 0
  • Magenta Color: 0
  • Magenta Tint: -1
lg70 nice tv excellent processor just to bad there is no intensity control on color management oh well still better than what the three s are pushing block out the hype lg will be number 1 in a few years haters are starting to come around and well leds coming,
p.s. i dont work for lg just tired of losers bashing stuff because they dont own it.
im isf certified those settings are right on the money straighter than a ruler
Oct 05, 2008 | Televison & Video
Color problem with Samsung 40 in LCD HDTV
Check your component cables. You have 3 colors coming in. Red,Green and Blue. Make sure the Red cable is good. You can do this by substituting the red cable only, or just change all 3 cables
Best regards
CircuitCity
Nov 25, 2007 | Samsung LE32R41BD 32 in. HD-Ready LCD...
Won't power on , just a click and nothing happens
Bad lamp, color wheel or DMD board. Lamp $199, Color Wheel $350 by professional, DMD/light engine $750 by professional
Oct 25, 2007 | Samsung HLN5065W 50" Rear Projection...
Televison & Video Logo
24 people viewed this question
Henry  Thomas
Henry Thomas
