Remote just died one day, didn't drop it or any physical damage. Tried new batteries, I have voltage throughout the circuit board all the way up to the infrared LED. The backlight LEDs and the DBS LED flash shortly once while I connect B+. Most of the Test Points indicate switch activity, but no switch indication returned to the LED under the switch button Eg: TV, VCR... The crystal looks like it is working just fine. The infrared LED checks OK. I have inspected with a microscope as best as I can for a cracked run, but the switch side is covered by a white coating making it impossible for visual inspection. A replacement remote is right at $50, and I'm not sure if a universal will have all the options. They went to the trouble of putting Test Points on the board, so I figured there may be some info/schematics floating around somewhere.
Jim, While checking the LED with the diode test setting on my multimeter (to supply power), I viewed the light from the LED through my camera on my cell phone.
Hi, A common problem is moisture leachate through the rubber membrane shorting multiple contacts on the board. the micro interprets this as an illegal command and will output nothing. Clean the board and rubber contact pad with isopropyl alcohol and lintfree cloth. If the remote is a universal type, i.e has functions for DVD/TV etc, then pressing those buttons has no output function other that to instruct the micro to output the following commands to drive that device. The crystal will only have signal when a transmitting button is pressed . you can test both the crystal and IR led for activity by setting your DMM to ACvolts range and with the negative probe connected to battery -, test each side of the IR led and similarly the crystal by simultaneously pressing a transmiitting button. you should see some activity namely a volt or two. ideally a scope should be used if available as this will not load the circuit like a multimeter. As stated above, a camera is a quick and ready test to visually comfirm the ability of the IR Led. I have seen many remotes that test electrically good but have no light output
Was this helpful?
Yes
No
Solution #3
posted on Aug 01, 2007
pandamama - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
Not new. Common practice. -- Al, the usual
Was this helpful?
Yes
No
Solution #4
jessie25 - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
LolI learn something new every day...I would have never thought to use a camera to view infrared activity. My hats off to you for your ingenuity.
Jim
Was this helpful?
Yes
No
Solution #5
2Pansy - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
How did you check the infrared led? I have found the even tho the infrared LED can check ok with a voltmeter test, it still may be bad. I always check my remotes with a little card available Radio Shack. If the remote is transmitting the little square on the card will light up. A dim room is better for checking as the card doesnt light up all that brightly.
my Panasonic DVD player remote (EUR722X40) stopped working, then started working the next day, then...
(More)
my Panasonic DVD player remote (EUR722X40) stopped working, then started working the next day, then stopped, then started, and now is stopped. What's the deal?
how do i program my panasonic romote control EUR 7722X40 to operate my panasonic SA-HT740 DVD HOME...
(More)
how do i program my panasonic romote control EUR 7722X40 to operate my panasonic SA-HT740 DVD HOME THEATRE SYSTEM
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
