Question about Frigidaire FRS266ZDSB Side by Side Refrigerator
Water comes out of my frig door dispensor but its not cold?
  • 410 Answers
On most all refrigerators the 1st 2 glasses of water may only be room temperature because of the way the water tubing is routed thru the refrig. if you will notice on your dispenser cover it does not say chilled or ice water. thanks for using  FixYa Peyton
Posted on Feb 18, 2009
Why is the water coming out of the dispensor not cold
Is your fridge compartment temperature in the region of 2 ~ 6 C range. Is your fridge food not going bad. Then dispensor water should be cool. Cool water tank is normally hidden inside fridge compartment. Lowest temp is around 2 ~ 6 C range.
If you keep on taking water rapidly then there is no time for the cooling tank to cool. You are just pushing house water through the water dispensor.
Oct 03, 2014 | Whirlpool Gold Series GB2SHTXTS (219 cu...
Water will not come out of the door dispenser
have you replace water filter ..... an easy test go to back of refrigerator where waterline goes int fridge and revers wires for icemaker and water dispensor and now use water dispensor it should put water into icemaker that will tell u that the switch to dispensor is working and you have a bad watervalve needs replacesed
Feb 03, 2011 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Water won't come out of the dispenser. I Checked to the door and the water works to the door, but won't come from the dispenser.
open the door, place a blanket over the opening to keep yopur food cold, and use a blowdryer on medium to warm up the inside of the door in the area where the water comes out. It should thaw the line.
I had the same problem yesterday, and the water was flowing normally in about 10 minutes.
if you dont have a dryer, it will thaw on it's own, but may take a little longer
Dec 10, 2009 | GE Profile PFS22 33" Artica French Door...
The ice dispensor and water dispensor on my GE Profle side by side refrigerator quit working.
Did you check the filter ? If it has been a few years, the filter can be clogged. Also, the water line connection valve may be internally blocked. If it is a tap-valve I suggest you turn it fully closed and then reopen it; this may break free any deposits that have built-up and clog the small opening. But before you reopen the valve, disconnect the line where it attaches to frig and let the first quart of water flow into a container to fluch away any particles before allowing it to flow into frig system.Can also be that the inlet selenoid valve or its wiring connections and switches are not working. You must hear a click sound when you touch the dispensor handle for water. Good luck, Macgivor
Oct 23, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile Artica - Water & ice dispensor not working.
This could be as simple as the door switch or as complex as the dispenser control board. I would try the door switch first. When the door is close it turns on the dispenser controls. If the contact is defective in the door/light switch then this happens. Unplug remove the door switch and mark wire locations. 1 Powers the lights and the other powers the dispenser. and one is the power itself. Sea Breeze
Jul 26, 2009 | GE Profile Arctica 25.4 Cubic Feet...
Ice tray will not fill with water
you have a bad mixing valve on the back of frig your model should have a duel valve one side for ice maker one side for water replace this valve you will be good to go
Jan 28, 2009 | Kenmore 52632 / 52634 / 52639 Side by Side...
Frig not cold but freezer is ice maker not making much ice either
Is your fan blowing in the freezer? Frost on the back wall of the freezer usually indicates a defrost problem... defrost themostate, heaters, take back panel off and check evap for frost build up and if your fan in working.
Aug 28, 2007 | Amana AFD2535DES French Door Refrigerator
FRIG AFD2535DES FRENCH DOOR BOTTOM FREEZER
Is your freezer fan blowing when the ref. is running, should feel air coming out the vent then,,,when running.
Aug 27, 2007 | Amana AFD2535DES French Door Refrigerator
Frigidaire FRS266ZDSB Side by Side Refrigerator Logo
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
