I can not print at all.
On properties a window says could not detect ink cartridge, but I have ink cartridge inside the printer
  • stephanierwi May 11, 2010
    Could it be the cartridge isn't POSITIONED correctly? Could it be turned the wrong way?
  • 61 Answers
1.please clean the contacts of cartridge and replace
2.turn OFF the power and turn ON then hold Power button on the printer for 2 minutes it will print a test page.
check whether it is printing or not.
let me know the result...
Regards,
Suraj
Posted on Feb 18, 2009
Do I have to have a color cartridge in order to print? Can I just use a black ink cartridge?
The HP DeskJet 6122 can print with both or only one ink cartridge installed. The printer driver includes an option to print in gray scale as a substitution for color. If you choose to print a document that has a color other than black and white with only a black cartridge installed, I recommend you select the gray scale print option. To select gray scale, select the printer properties and check the box for gray scale rather than color printing. This selection can be made either at the time a document is ready to print (ie., a one time selection, using the "Properties" box in the print options window), OR as a permenant setting using the Control Panel, Printers, HP DeskJet 6122, "Properties" window. Once changed in the general printer properties, these settings remain active anytime the HP DeskJet 6122 printer is selected to print a document.
Sep 03, 2013 | HP DeskJet 6122 InkJet Printer
U162 error on black ink cannon printer
This error occurs when printer fails detecting ink level or printer assume that no ink in the cartridge. We cannot use print, copy,scan, and fax function before the problem fixed. It's recommended for you to replace ink cartridge. To continue using the printer without replacing the cartridge we must deactivate ink level detection function. Be aware that printing in this condition can damage the printer while sending fax or scan is not problem.
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Original source: http://ij-forum.blogspot.com/2008/12/error-message-check-ink-u162u163.html#ixzz2Cpr4Be1K
Nov 20, 2012 | Canon PIXMA MX340 Wireless Office...
How let Lexmark S305 only use black cartridge to print black. Now the color cartridges getting empty by only printing black, and with "only use black ink" selected. (Besides that, the cartridge...
Please follow the steps below on how to print using black ink only on your Lexmark S305 printer:
For Windows:
  1. With your document/file open, click File.
  2. Click Print.
  3. Click Printing Preferences/ Properties.
  4. In the Lexmark S300 Series Printing Preferences window, select print using black ink only.
  5. Click OK to save the settings.
  6. Click Ok again to print your file.
For Mac operating system:
  2. Click Print.
  3. Expand the arrow pointing down beside printer name if you're not able to see other options for printing. Look for Quality and Media in a drop down box and select print in black and white.
If you wish to set this as your default print setting, please follow steps below:
For Windows:
  1. Go to Control Panel.
  2. Open Printers and Faxes.
  3. Right-click on Lexmark S300 Series print object and click on Properties.
  4. In the Lexmark S300 Series Properties window, go to Advanced tab. Click on Printing Defaults.
  5. Under Ink Use, select Print using black ink only. Click OK.
  6. Click OK button in the Lexmark S300 Series Properties window to save the changes.
Your printer will print in black only the next time you send a print job to the printer.
For Mac:
  1. With the file (you wish to print) open, click File.
  2. Click Print.
  4. Save this as your default print setting. Click Presets option and choose Save as. You can personalize the name for this default print setting (e.g. Black and White Draft or My Setting).
Select this Preset name every time you print your files/documents.
Note: The 100 standard cartridges yield around 175 ISO Pages. You can also save on ink and stretch your ink investment if you use only 100XL high yield cartridges. These contain almost 3x as much ink as a standard cartridge for a small increment in price.
Aug 07, 2011 | Lexmark S305 IMPACT LEXS All-In-One...
I put a new colour cartridge in to my 810C printer but the colours all came out wrong. How do I clean the ink jets please?
I am not sure what you mean by colors come out wrong. However, if the new cartridges are refills, there is the possibility that the refillers damaged the cartridges.
Try this: remove the color cartridge from the printer and check the bottom of the cartridge for ink blobs. Blot any ink around the silver screen-like area. Try not to touch that silver area. If there is no ink there, reinstall the cartridge and go to the Printers and Devices where your printer should be listed. Right click on the printer and select printer properties which will bring up a properties window where you select the Services window and select "clean the print cartridges" (this is Windows 7 but XP and Vista are not much different) Select ok and wait for the printer to go through its gyrations. Don't select "prime" at this time. When the printer finishes, try printing again. If the colors are still messed up, you could return to the clean selection and select "prime" in the next window (not likely to help).
If these don't work, you can run the clean cycle a couple of times, but chances are the cartridge has failed inside, allowing the inks to run together. Whether it is new or refilled, just return it for a replacement.
Feb 12, 2011 | HP DeskJet 810c InkJet Printer
Impossible print with the black cartridge. the rest of the cartridges print fine. thanks.
Remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and connect the Printer to be detected and installed. Check printer properties to see the ink levels.
Use head cleaning before a test is taken . It is possible that the head is not reacting to the need of the command , can be an issue with ink drying , can also be poor ink cartridge contacts
Sep 28, 2010 | Brother MFC 6490CW InkJet Printer
Re Canon 2600 printer.I recently purchased a black Ink cartridge and replaced the old one. A week later the color cartridge also shows empty even though I hardly use color. Can I not print in greyscale...
Please follow the instructions below from Cannon support page...
Setting the Ink Cartridge When printing, you can specify which ink cartridge to use. This is convenient if one of the ink cartridges becomes empty, you can continue printing by specifying the ink cartridge that still has ink. Note:
  • When the following settings are configured, Black Only is disabled. The color ink cartridge is used to print.
  • A type of paper other than Plain Paper is selected for Media Type on the Main tab.
  • Borderless Printing is checked on the Page Setup tab.
  • Canon recommends that you use the ink cartridges installed in the printer and not remove them until the ink runs out.
You can set the Ink Cartridge Settings from the Maintenance tab in the printer driver.
To access the printer driver from the application software, click here.
To access the printer driver from the Printers folder, click here.
Application Software -
Note: Depending on the application software, command names or menu names may vary and there may be more steps. For details, refer to the user's manual of the application software.
  1. Select the command you perform printing on the application software in use. In general, select 'Print' on the File menu to open the Print dialog box.
  2. Select your printer model name and click 'Preferences' (or 'Properties'). The printer driver setup window appears.
  3. On the Maintenance tab, click the 'Ink Cartridge Settings' icon.
  4. On the Ink Cartridge Settings window, check the 'Ink Cartridge' drop-down to see what it is it set to.
  5. To change Ink Cartridge to Black Only, click the 'Ink Cartridge' drop-down and select the option.
  6. Click 'OK' on the Ink Cartridge Settings window.
  7. Click 'OK' or the applicable button to print.
Printers Folder -
For Windows 7
  • Click the 'Start' button from the bottom left of the Windows screen, and then click on 'Devices and Printers'.
  • Click your right mouse button on the listing for your printer, and then select 'Printing Preferences' from the menu that appears.
For Windows Vista
  • Click / Select 'Start' from the bottom left of the Windows screen, 'Control Panel', 'Hardware and Sound', and then click on 'Printers'. Note: If you are in 'Classic' view, click 'Printers' directly from the 'Control Panel'.
  • Click your right mouse button on the listing for your printer, and then select 'Preferences' from the menu that appears.
For Windows XP Home Edition
  • Click / Select 'Start' from the bottom left of the Windows screen, 'Control Panel,' 'Printers and Other Hardware,' and 'Printers and Faxes.'
For Windows XP Professional Edition
  • Click 'Start' from the bottom left of the Windows screen, and 'Printers and Faxes.'
For Windows 2000
  • Click / Select 'Start' from the bottom left of the Windows screen, and 'Settings,' then 'Printers.'
  • Click your right mouse button on the listing for your printer, and then select 'Properties' from the menu that appears.
  1. Click the Maintenance tab. (The Maintenance window opens.)
    Note: The layout varies depending on the printer and version of Windows you are using.
  2. On the Maintenance tab, click the 'Ink Cartridge Settings' icon.
  3. On the Ink Cartridge Settings window, check the 'Ink Cartridge' drop-down to see what it is it set to.
  4. To change Ink Cartridge to Black Only, click the 'Ink Cartridge' drop-down and select the option.
  5. Click 'OK' on the Ink Cartridge Settings window.
  6. On the Printing Preferences window, click 'Apply'.
Mar 04, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Want to set to use Black Ink only how do I turn colour off
Go to Printers and faxes -> select your printer Canon MP150, right click -> properties -> maintenance -> ink cartridge settings -> select the ink cartridge for printing -> select Black only
Remember printer need both cartridges inside it for initialized and print.You can't print only with black cartridge in printer.
Nov 02, 2009 | Canon PIXMA MP150 All-In-One InkJet...
My cannon printer pixma ip1800 cannot detect ink pls help me...
If after you install the cartridge you get a yellow light and error message:
“The following may have run out of color. The function for
detecting the remaining ink level will be disabled since the
ink level cannot be correctly detected. If you want to
continue printing with out this function, press the printer’s
start button. Canon recommends using new genuine Canon
cartridges in order to obtain optimum quality.”
Do not click “cancel printing”. Press printer start button
to start printing. This action will bypass the ink level
detection from the recycled cartridge. It will not damage the
printer! With a recycled cartridge this action needs to be
done one time.
A full recycled cartridge ink level may not display correctly.
It may show empty.
If you want to check the ink level, you can do a “Nozzle
check” by follow the directions below:
Go to menu File select print click on “Property” click
on “Maintenance”
Click on “Nozzle check” to print out the color check.
Click on “Cartridge Alignment” to align the cartridge.
See pictures for above process at Inktelligent ip 1800 topic
Also the refills refered to above are at the IP 1800 inkfilling page
Sep 23, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
My HP Printer does not show color. When I print black and white, I get a pinkish cast and often pinkish printing.
It is possible you're black cartridge is too low on ink & needs replaced. If you're black ink cartridge is new, there could be small ammounts of sticky tape left over the contacts of the ink cartridge. Please clean the ink cartridge's copper contacts (side only, not the bottom of the ink cartridge), with a cotton swab & a little alcohol. Since the ink cartridge is removed clean copper contacts inside the carriage holder as well. Allow time for the alcohol to dry. All most every printer installs software that monitors ink level's. To check you're printer for this. Click the start button, slide up to & click Printers and faxs. The printer and fax window will open. You're default printer will have a little check mark next to it. Right click once on that printer name, another little pop-up window will open, slide to & left click on properties.
You're printer (It's name) will open. Near the bottom click on Printing Preferences. Another window will open. Click the Services tab. Than click Service this device. You should be able to see the ink levels.
Have more questions? Please feel free to ask.
Hope this has helped.
Luck!
Mike
May 12, 2008 | Office Equipment & Supplies
Refilling Ink in Canon Pixma MP830
Hello, I found this in a repair manual for the MP830. summery is to press and hold the stop/reset button for 5 or more seconds. I copied the info from the manual too. The remaining ink amount unknown. [1683] (Applicable ink tank icon) The remaining level of the following ink cannot be correctly detected. An ink tank which has once been empty is installed. Replace the applicable ink tank with a new one. Printing with a once-empty or refilled ink tank can damage the print head. If printing is continued without replacing the refilled ink tank, press the Stop/Reset button for 5 sec. or longer to record the use of a refilled ink tank. Note: After the above operation, the function to detect the remaining ink amount is disabled.
Jul 17, 2007 | Canon PIXMA MP780 All-In-One InkJet...
jasbo
jasbo
