Question about Vehicle Parts & Accessories
99 astro van. starts but won't stay running for more than a few seconds. security light is on. also middle brake light is on untill fourways are turned on
  • Anonymous May 02, 2009
    Either the computer chip in your key is corrupted and isn't recognized by the ignition switch, and therefore your anti-theft system is preventing the engine from starting. OR Your ignition switch is in need of replacement. Either way, the anti-theft system thinks you're trying to steal your own car.
  • james kappers
    james kappers May 11, 2010
    is this when u start it with the key or a remote start?
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
  • 40 Answers
SOURCE: 1994 camry won't keep running
does the car have an auto start, if so this could be the problem, like a possible malfunction. And yes it would be a security problem. With auto starts there is a small switch installed so you can turn it off, or reset it. Maybe try and find the switch and turn it off. If the problem stops and you can drive it i would look at replacing or repairing the auto start
Posted on Feb 28, 2009
BLAZZ81
  • 281 Answers
SOURCE: chevy astro van turns over but wont start when
Check to see if the fuel pump is kicking in,
when you turn the key on without starting the van you should hear it kick on for about 2 seconds,
It could be...
A clogged fuel filter...
Blown fuse for the pump..or bad pump relay..
No gas
Bad fuel pump
Posted on Mar 07, 2009
  • 16 Answers
SOURCE: HAD FRONT BRAKES ON 2000 CHEVY ASTRO VAN REPLACED
theirs a sensor for the abs light have that replaced the shop should've advise you of that.
Posted on Jul 13, 2009
  • 1608 Answers
SOURCE: 2000 astro van won't start
What you have to do is check and see if you have fuel pressure.You have to remove the engine cover to check it.If you don`t have a pressure tester then remove the air cleaner hose to the engine and spray it with carb.cleaner or brake cleaner.If it starts for a few seconds then it is more than likely a fuel pump.If it does not start then you have to check for spark at the spark plugs.Make sure you check more than one plug.If no spark then you have to check the distributor cap and rotor.Make sure the rotor is good and cap also.Things that can cause no spark are the ignition module,coil,and cap and rotor.Hope this helps.Good luck.
Posted on Jan 29, 2010
  • 3600 Answers
SOURCE: My 1995 chevy astro van shakes every time i break
you either have bad brake pads or the bolts are loose that hold the front steering suspension on.
Posted on Mar 03, 2010
2002 Chevy Astro Van 6 cyl. Was getting progressively harder to start. then would not start at all. Did tune up did not help. Cranks over and runs for 2 secs. then dies.
first check fuel pump and make sure fuel filter is not clogged up. Is your air filter clean? undo all ground wires to shiny clean and screw back tight. good luck.
Apr 07, 2017 | 2002 Chevrolet Astro
Thinking 99 Chevy Astro van security light on solid band starts with cuts down is there anyway to bypass security without spending a lot of money
If the light is on there are code stored ! Not in the PCM/ECM engine computer . In the BCM , do you know what that is ? body control module ! Need a factory scan tool or equivalent to check !
DTC B0688 Security System Indicator Circuit High
DTC B2947 Security System Sensor Power CKT Low
DTC B2948 Security System Sensor Power CKT High
DTC B2957 Security System Sensor Data Circuit Low
DTC B2958 Security System Sensor Data Circuit High
DTC B2960 Sec Sys Sensor Data Incorrect but Valid
DTC B3031 Security System Controller in Learn Mode
DTC B3033 Security System Indicates Tamper
DTC C0559 EEPROM Checksum Error
Why does everyone want to chop up things , by pass etc... The right fix could be cheaper then ruining your vehicle . Chopping up wiring harnesses . Their are by pass module , don't know how much they are . It may or may not fix the problem . Pulling the code and doing the diagnostics is still the best solution .
Jan 07, 2017 | 1999 Chevrolet Astro
Changed steering column security light flashing and will not stay running key with used column
I'm not completely sure how all the chips work, but if the chip is not activated, the engine will run for 3 seconds, then shut down. It will only do this 4 or 5 times, then it will not start at all. If this is happening, then you need to have the key chipped to match the ignition/van.
Feb 15, 2016 | 2000 Chevy Astro - Passenger van, with...
Manufacture alarm on 99 astro van will not let van stay running
go to the drivers door remover the inside pannel and ground the main purple wire that should kill the alarm system
Apr 17, 2014 | 1999 Chevrolet Astro
1999 Chevy astro van won't start
Had the same issue with our 1999 chevy astro van, would crank but would not start. It had been raining and windshield had a leak, after 2 days of no rain it started. Pulled codes and was the Security system in the ignition switch. Hope this helps.
May 04, 2012 | 1999 Chevrolet Astro
99 chevy astro ,lost key replaced steering column. now no start. pass-lock ignition,tried key on position for ten minutes 3 consecutive times, still no start. Got fuel and fire. It actually starts for...
Yes it sounds like a security system problem. Does the new column have pass key? You are leaving the key on until the security light stops flashing? The light is flashing for 10 minutes?
Nov 01, 2010 | Chevrolet Astro Cars & Trucks
Chevy astro van turns over but wont start when
It could be...
No gas
Bad fuel pump
Mar 07, 2009 | 2000 Chevrolet Astro
Vehicle Parts & Accessories Logo
215 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
