Question about RCA 25403RE3 Corded Phone
Headset for rca executive series 4 lines
I am looking to purchase the headset for rca executive series (4 lines) or compatible headsets that work with this system
micromaster
  • 3614 Answers
SOURCE: I HAVE RCA EXECUTIVE SERIES
Until when you had never use the phone?
Posted on Mar 09, 2008
SOURCE: I have RCA Executive Serices
I get the same thing. Did you figure it out?
Posted on Apr 24, 2008
SOURCE: RCA 25110RE3-A cordless headset
Mine was doing the same and I just pressed the "find" button on the wall plug in thing- and the headset started working....you may want to try that.....?????
Posted on Sep 06, 2008
Tom,
I had the "error: inhibited" problem with my RCA 4-line Executive Series phone as well.
When I checked the line from the phone to the wall outlet, I saw that it had come undone.
After I plugged the phone back into the wall, it started working normally again.
I recommend substituting in a different, known-good telephone to see if that works.
If you can't get any phone to work plugged into that extension, then the extension is dead.
If another phone works but your RCA still will not, then the problem is with the RCA phone.
A similar idea is to try moving your RCA phone, substituting it in place of a working phone.
If it works in room X but not in room Y, suspect the phone wiring running to room Y.
This phone employs a common but awkward means of wiring up lines two and four.
Line two is wired to the wall by piggybacking on the patch cable used for line one.
Line four is wired to the wall by piggybacking on the patch cable used for line three.
A phone cord has four wires running through it, but a phone signal requires just two.
The piggybacking technique leverages the cable's free pair to feed a second line.
The upshot is that one can test the wiring for lines one and three with a simple, plain phone.
To test the wiring to lines two or four, some specialized knowledge is needed.
In place of that knowledge, a different two-line phone which also piggybacks might be used.
That's detail you'll need to consider only if your problem is specific to line 2 and/or line 4.
Anyhow, I hope I'm not patronizing by being too simple. But, I had this problem too.
It turned out to have nothing to do with the phone itself; the signal wiring to it was bad.
I realize that this feedback is a bit late and that you've likely already resolved your issue.
Perhaps this feedback will someday help somebody else (since these Q&As are archived).
Regards,
Lincoln
Posted on Nov 18, 2008
SOURCE: RCA Executive Series 4-line model# 25413RE3-A
I was having the same problem...no caller ID. Then I looked up the phone on the RCA site:
http://www.rca4business.com/products/pc/viewPrd.asp?idcategory=22&idproduct=11
Turns out there is no called ID on this model =(
Posted on Jun 17, 2009
The handset lifter works, but no sound can be heard or received by either party
If you have a 510a base, then purchased a Plantronics Voyager Pro headset to replace your old headset, it won't work. Those are two different headsets. The Voyager Pro is not meant to work with the 510a base. The correct headset is this:
Plantronics Voyager 510 Replacement Headset
Good luck from Headsets Direct!
Jan 27, 2011 | Plantronics Voyager 500A Deskphone Adapter...
Is the steelseries 7h usb headset compatable with the ps3
Hello Sixlittledev,
Although the 7H USB headset is not natively supported by PS3, you may be able to get it to work if you have a headphone jack in your TV.
You will need to connect the headset in the following manner:
Headset microphone cable -> USB card -> PS3
Headset audio cable -> 3.5mm extension cable -> TV headphone jack
Although we do not guarantee compatibility and this method is a bit cumbersome, you can get it to work this way.
Mike S
SteelSeries Support
Http://www.steelseries.com/support
Dec 03, 2010 | Steel Series Steelseries 7H USB Headset...
We have RCA executive series 4 line telephones. Is there a juction box that we can install to make this system work?
The RCA 4 line phone uses 2 standard telehpone jacks. Line
1&2 on the first jack and lines 3&4 on the second jack.
Sep 13, 2010 | RCA Lands Phones
My Headset does´nt have dialtone, I was connecting to cisco phone 7941, 7970, 7911, and nothing, not work.
You can use a Plantronics S11 headset with a Cisco phone, however it is not the best compatible solution. To use an S11 with a Cisco phone, you have to make sure that you are plugging it into the handset receiver jack and not the headset jack. You will need to lift the handset receiver, set it off to the side, and then hang it up after each call. If you want a more compatible solution that you can plug into the actual headset jack and just press the headset button on the telephone to answer and hang up, then you would need one of the Plantronics "H-series headsets" with the Plantronics Cisco direct connect cable ( model 26716-01 ).
Plantronics 26716-01 cable
Plantronics H Series Headsets
Aug 12, 2010 | Plantronics S11 Headset
How to get Caller ID
give a application in exchange to activate service
Jul 30, 2009 | RCA 25413RE3 Corded Phone
May 08, 2009 | RCA 25413RE3 Corded Phone
Plantronics 330 bluetooth headset / Nextel Blackberry 7100i performance
After looking through the phones, there many possibilities, wow quite a few. It does not have any recommendations on headsets. The headset is only as good as the the quality you are purchasing. If your phone drops calls it won't be from the bluetooth device. Below is a link to the Explorer Series 300 User's Guide, which may help you.
Plantronics Explorer Series 300 User's Guide
Sep 22, 2008 | Plantronics Explorer 330 Headset
I have RCA Executive Serices 4 lin system Phone and I used to use headset all of sudden I hace message saying " Error: inhibited ". Would you plaese help fix my problem. Thanks for your...
Tom,
Regards,
Lincoln
Mar 09, 2008 | RCA 25403RE3 Corded Phone
RCA 25403RE3 Corded Phone Logo
1,102 people viewed this question
Top RCA Lands Phones Experts
Are you a RCA Lands Phone Expert? Answer questions, earn points and help others
