Question about Sony Ericsson XPERIA X10 Cell Phone
My XPeria X10 needs Hard Reset. How can I do it?
Hey, I tried the usual way of Hard Resetting by pressing the left and right buttons and turning it on. But instead of on-screen instructions, the LED notification blinks green for a moment, and the phone starts in regular mode. I am trying a hard reset because I forgot the password of my phone. I need help.
  • 23 Answers
With the phone on
  1. Start by opening Main Menu next on open Settings folder.
  2. Tap on Privacy and select Factory Data Reset.
  3. Tap on Reset Phone, enter your password (if required) and confirm by selecting Erase Everything.
  4. Let the phone restart and you're done.
With Phone off:
1. Start with the phone off, to do it press Power button.
2. Press and hold both the left and right Action buttons under the display.
3. Press the Power button while the others 2 keys are still held.
4. Follow the on-screen instructions as the phone immediately begins the Factory reset process.
I hope this helps :)
Posted on Jan 01, 2018
SOURCE:
  • 34 Answers
SOURCE: I forgot my sony ericson
The phone needs to be hard reset. The only way to perform a reset on the phone is to download the Sony Ericsson update centre from their website onto a pc, connect your phone to the pc via a USB cable and perform the reset through the software which you downloaded.
Posted on Feb 03, 2011
rizla
  • 1463 Answers
SOURCE: need help..
hi
have checked for this , best to contact you network who will possible reset you codes throught airwave to you mobile
riz.
Posted on Sep 09, 2008
  • 179 Answers
SOURCE: Sony Xperia X10 Unlock Attempt Left
No way of finding out how many times the wrong code has been entered but...
You can still unlock the phone by using
"totalgsm"
software and your data cable that you got with your handset.
You will need to pay for some credits for the software to unlock your phone and your computer needs to be connected to the internet whilst it does it.
It's worth looking around for different prices too. I looked for a c902 and found prices ranging from £25 to £7 after you work out the exchange rate from Dollars to Sterling.
$40 is the starting price see how low you can find it. :)
Posted on Jul 19, 2010
  • 13 Answers
SOURCE: i need to hard reset
Try this method below on how to hard reset Sony Ericsson Xperia X10:
1. Turn the power off first. If the Sony Ericsson Xperia X10 is frozen, take the battery out from the device and then reinsert it back again after a few seconds.
2. Hold the Left and Right Keys located beneath the LCD Display
3. Press and release the Power Key
4. Just then follow the on-screen instructions that appears to hard reset the Sony EricssonXperia X10
Posted on Nov 02, 2010
ejkudelka
  • 1188 Answers
SOURCE: How do i reset unlock
Okay well if you had the unlock code, that would work. Otherwise you need to do a hard reset. Keep in mind that a hard reset will remove the lock, but it also erases all of your content on the phone. It will be set back to factory original settings. The best wait to do so...
To do the hard reset:
1--INSTALL IT,
2--LAUNCH THE SOFTWARE
3--PRESS TOOLS
4--PRESS PHONE REPAIR
5--PRESS CONTINUE
6--WAIT FOR THE SOFTWARE TO DOWNLOAD FILE ONLINE
7--SELECT THE MODEL X10
8--CONNECT PHONE WHILE HOLDING BACK BUTTON AND INSERT USB
9-- LET THE DRIVERS INSTALL AND WAIT WHILE THE FLASHING COMPLETE
ALL DONE PASSWORD REMOVED
GOOD LUCK!!
EJ Kudelka
Posted on Nov 14, 2010
After replacing power supply and resetting tv still only have green flashing light
Remove Mains Plug and press Standby switch from LED Panel for 30 sec. Press Input & Ch Down Switch from LED panel and plug in and start LED LED will start and "K" will appear on screen Press Ch Down & Vol Down switch at same time You will get 1/10 page on screen Go to 9/10 page by pressing left & right button from remote Select EEP and press Ok button from remote After 30Sec remove main plug and restart LED.
Dec 13, 2015 | Sharp AQUOS LC-32D44U 32 in. LCD TV
Tip
How To Reset Your Sony Ericsson Xperia X10
Soft Reset<br /> <ol> <li>Turn off the device.</li> <li>Remove and reinsert battery.</li> <li>Turn on the device.<br /></li></ol>Hard Reset<br /> <ol> <li>Unlock the screen then press and hold the <b>Power</b> button for two seconds. Select the <b>Power off</b> option. If the phone won't turn off, pull and replace the battery.<br /></li> <li>Hold the <b>Left</b> and <b>Right</b> buttons located under the display.<br /></li> <li>Press and release the <b>Power</b> button while continuing to hold the <b>Left</b> and <b>Right</b> buttons until instructions appear.<br /></li> <li>Follow the instructions on the screen.<br /></li></ol>or<br /> <ol> <li>From the Home screen press <b>Menu</b> and select <b>Settings</b>, or tap the application slider and select <b>Settings</b>.</li> <li>Select <b>Privacy</b>.</li> <li>Tap <b>Factory data reset</b>.</li> <li>Select <b>Reset phone</b>.</li> <li>Select <b>Yes</b> to confirm the hard reset.</li> <li>The Sony Ericsson Xperia X10 will then go through the process of formatting the memory.</li> <li>Wait for it to restart and factory default settings will be restored.</li></ol>or<br /> <ol> <li><a href="http://www.sonyericsson.com/cws/support/softwaredownloads/detailed/pcsuite/aino?cc=gb&lc=en">Download and install PC Suite</a><b>.</b></li> <li>From the PC Suite software, select <b>Tools</b>.</li> <li>Select <b>Phone Repair</b>.</li> <li>Select <b>Continue</b>.</li> <li>Wait for the download to complete.</li> <li>Press and hold the <b>Back</b> button while plugging the phone into the computer via the USB cable.</li> <li>The phone will be flashed with the software and complete the hard reset.</li></ol>
on Feb 15, 2011 | Sony Ericsson XPERIA X10 Cell Phone
How to set led watch
What make and model of watch is this?
Sep 08, 2011 | Watches
I can't remember my gmail account information and I am locked out of my xperia phone from too many pattern attempts. No combination I try will work.
Try to enter password as null. If didnt worked means do a hard reset . You will get factory settings enabled after resetting.
  1. Turn the power off. If your Sony Ericsson Xperia X10 is frozen, pull the battery out and reinsert it
  2. Hold the Left and right buttons located beneath the display
  3. Press and release the Power button
  4. Follow the on-screen instructions to hard reset your Xperia X10
All data including third-party applications will be deleted from the Sony Ericsson Xperia X10. Once the wipe is complete, the phone will reboot to its factory fresh state.
Mar 06, 2011 | Sony Ericsson XPERIA X10 Cell Phone
Help? Magnification on an Acer laptop.
You pressed the Alt Gr button along with the down arrow, Try, the same but use the UP arrow instead, usually the "Opposite" last key, usually reverses the action, up, down, left, right etc...
Mar 01, 2010 | Acer Aspire One PC Notebook
How to reset absober full mp198
PLEASE TRY THIS, Probably your waste ink counter. Should be cleaned or replaced before resetting but usually you can get away with resetting once.
1. Start with printer OFF
2. Hold down RESUME and then hold down POWER
3. Release RESUME
4. press RESUME twice, then release POWER
5. let green light blink until printhead has finished moving.
6. Select functions below with RESUME, execute with POWER
0 presses - green light - Test Print (exit service for i960)
1 press - orange light - EEPROM info print
2 presses - green light - EEPROM initialise
3 presses - orange light - reset waste ink counter
Feb 26, 2010 | Canon PIXMA MP160 All-In-One InkJet...
I need to know how to unlock my tmobile vario device without using the touch screen because it has cracked. I can press a button to 'unlock' then it displays 'tap unlock or press *' However I cannot...
Phone Lock Reset Wizard Mda Vario T Mobile
instructions for
hard resetting a wizard, which is resetting the phone
thus the phone lock as well.
Dead easy really
1. Press the Comm Manager button (top left)
together with the Voice Activation button (top right)
for 2 seconds.
2. Keep holding the 2 buttons above and press the soft reset
(middle right little hole) with the stylus for another 2 seconds.
3. When the black screen appears it'll ask you to click Send
That's it All done !!
The wizard's going to reboot and reset himself.
Good Luck.
May 17, 2009 | T-Mobile MDA Vario Smartphone
In AUTO mode, pictures are all dark!
Yes you definitely can,
Turn on the camera.
The mode dial can be turned to any setting.
2. Press the button for longer than 5
seconds.
The message “Reset settings to default?” appears on the
LCD monitor.
3. Select [OK] using the left and right
buttons, then press the button.
The normal screen resumes when resetting is complete.
To cancel resetting, select [Cancel] instead of [OK].
Dec 09, 2007 | Canon PowerShot A70 Digital Camera
Canon BJC 8500 WASTE INK FULL
How to Reset Waste Ink Protection Counter Canon Pixma IP8500 Printer
Instructions:
Resetting Waste Ink Counter Canon Pixma IP6000, Canon MP450, Canon Pixma IP8500
1. Turn off the printer.
2. Whilst pressing Resume button also press on POWER.
3. Then Press RESUME button and release POWER.
4. Then Press RESUME button again .
5. Then release all buttons.
6. Led Indicator should be green and stay green.
7. Click RESUME button 4 times if you wish to try again.
Then See Table Below:
Orange - Service test print ONCE - Orange - Service test print.
Green - EEPROM information TWICE - Green - EEPROM information print.
Orange - EEPROM initialization 3 TIMES - Orange - EEPROM initialization.
Green - Waste ink counter resetting 4 TIMES - Green - Waste ink counter resetting
Orange - Destination setting (Press Power then Press Resume 3x) 5 times - Orange - Destination setting (Press Power Press Resume 3x)
Green - Print head deep cleaning 6 TIMES - Green - Print head deep cleaning.
Orange - Green, Orange - Return to menu selection 11-13 TIMES - Orange, Green, Orange - Return to menu selection.
Green - Left margin correction 14 TIMES - Green - Left margin correction.
8. Turn off printer.
9. Restart Printer.
Good Luck!
Tinteiros - Magic Inkjet Flush (Ebay)
Nov 07, 2007 | Canon BJC 8500 InkJet Printer
I can't even set my Casio Marine Gear watch.
Go to this link and with the four digit module code from the back of the watch you should be able to get a manual; http://world.casio.com/wat/download/en/manual/ Hope this helps :)
Jan 15, 2007 | Casio Marine Gear MTD1042A-2AV Wrist Watch
Sony Ericsson XPERIA X10 Cell Phone Logo
64 people viewed this question
Top Sony Ericsson Cell Phones Experts
Damen Wong
Damen Wong
Marvin
Marvin
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
