Question about Kenmore 43142 Front Load Washer
The washer was running and it stoped, it didnt drain and the door is locked.
  • 360 Answers
Press/hold stop/clear
then select drain/spin
press start
allow unit to complete cycle, door will unlock.
Posted on Feb 17, 2009
Door open wont washer
Possibly some foreign object has worked it's way down into the drain pump, preventing the washer from draining. all the way. (If the washer doesn't drain properly, the door will remain locked).
One way is to take the drain hose out of the wall connection, lower it to floor level & allow it to gravity drain. (Be sure to catch the water in a pan or something). Once the washer has drained, the lid should open.
If this fixed the problem, the pump still has something in it. You will need to remove the back of the washer and check to see what's blocking the discharge pump.
Remove the back of the washer, remove the hose running to the drain pump, remove the pump itself & remove and debris clogging the pump.
Otherwise a service call runs somewhere between $100 - $175.
Apr 16, 2014 | Washing Machines
Washing machine washes then will not spin HELP HELP dirty clothes
When you set "the timer to drain and spin only". After "drain" program finished - not pump or motor sound or all sound stoped, the machine is freeze?
The meaning is sometimes, the sensor of water level doesn't working properly. The "drain" program is keeping running.
May 27, 2017 | Washing Machines
My frontloader washer stoped during a cycle and got locked and I dont know what to do with it. can you give me any sugestions?
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Remove the 3 screws at the bottom of the front panel under the washer door. Your filter door will be light brown. If you find a hose there it is to drain out excess water (water that could not be drained by your pump) After you hv drained unscrew the cap and remove all the junk inside. Have a large plastic bag to catch junk and water. Refit carefully after cleaning out. If not solved, something shd be blocking your pump, check this out. F-21 filter blocked.
How abt a nice rating for the free help?
May 22, 2010 | Whirlpool GHW9300 Duet Washer
I have a two-year old Frigidaire GLTF2940FSO front loader washer that has stopped in the middle of a load leaving water in the drum and will produce a buzzing sound no matter what cycle you put it on. We...
did you try unplugging it and plugging it back in to see if you can get it to reset? Would it buzz when you try to drain it? Does the door latch lock when it goes into the wash cycle? Usually the door latch locks when it goes into the wash cycle and stays locked. So it filled up, the door latch should lock, then should go into wash cycle. Then you said few minutes later it stops. How did you get the door open? reason i ask is Usually i would see the clothes get stuck inside the washer because the door latch is still locked when it stops. Was the door unlocked when it stoped. If so maybe something going on with the communication from the board to the door latch maybe. Did you try operatin the drain?
Aug 01, 2009 | Frigidaire GLTF2940ES Front Load Washer
Washer will not reset
Depress "end of cycle" button for 3 seconds & wait for 2 minutes to try the door gently.
Mar 17, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore elite washer problem
sounds as if you have a drain issue, most common cause of fault is theres something stuck in the pump housing. remove the lower acess panel(3 screws along the bottom of the forn of unit) youll gain acess to the pump housing, remove the large cover to the "button trap" by uncscrewimg the cover, it will be righthin front of you in the center of machine when cover removed, im sure youll find your blockage within there
Oct 29, 2008 | Kenmore Elite 45986 Front Load Washer
Draining
if you select drain spin and you hear the pump running then check all the hoses for blockage if you dont hear the pump running then make sure your door is locking
Jan 19, 2008 | Maytag Neptune Washer
Washer flashing F then went to SUD
Drop the drain hose so that it is lower than the drain and let all the water run out of the machine. Open the door and remove all washing. Let machine go through rinse cycle with some milk mixed in with the water, (pour the milk into the soap container, about one cup) and make sure there are no soap suds left in the machine. Check that you are using washing powder which is recommended for front loaders.
Oct 30, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore 43142 Front Load Washer Logo
41 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
