Question about Zanussi ZHQ575 Electric Double Oven
Zanussi Electric Cooker and Hob don't work properly
My fiancee's mom and dad bought a new Zanussi Electric Cooker and Hob from B&Q on sunday, and today had an electrician fit it.
However, only the two right hand side rings work and out of the two elements for the grill only the inner element works.
The dedicated line feeding the old cooker is about 20 years old, but the electrcian stated that it was still okay and was carrying the correct power to use again. He used a cable splitter box (black circular), with 250v 30amp stamped on the back. He drew two lines off this, one to the cooker and one to the hob. He then placed the splitter box on top of the cooker housing with tape then slotted the cooker into place. He signed off the receipt saying both appliances were tested even though they didn't work properly, and charged them £98 for 2 hours work.
My question is, why are they not working properly?
With my limited knowledge of electrics, surely the 30amp power cable would feed both appliances once split with ease, beings they only require 15 amps each to operate?! Help!
  • 40 Answers
It will have nothing to do with the supply, although it does sound as though he could have done a better job. if the appliances are brand new get Zanussi out to it. shame on the guy for not checking that they worked as they should. hope this helps.
Posted on Apr 07, 2010
Glass door for top oven
Really bad but how we are supposed to help you? Find a shop where they sell parts for Zanussi ovens.
Most I can do for you is to provide you some websites selling parts for zanussi: ovens
Official Zanussi Site Parts Accessories for Appliances
Zanussi Cooker Oven Shop
Find Zanussi Spares and Accessories
Zanussi Cooker Oven Spares
Oct 25, 2015 | Zanussi ZDQ695 Electric Double Oven
Hi ive purchased a zanussi gas hob & electric grill and oven my installer wanted to knw what amp and wire to use to connect the oven nothing is stated in the manual model no ZOF35511XK
The necessary data for your installer is on
the rating plate. The rating plate is on the back side on oven and on the bottom side on hob. Never remove
the rating plate from the appliance cavity.
Make sure that the electrical information on
the rating plate agrees with the power
supply. If not, contact an electrician
All electrical connections should be made by
a qualified electrician.
The appliance must be earthed.
Dado
Sep 10, 2014 | Zanussi Ovens
Hi We have a zanussi ZCE 7550 double oven cooker. The bottom oven broke (with a flash and bang), so we replaced the element at the back as it was burnt out. The top grill and hob are still...
Hello starsevern!! Did you get your cooker fixed, what was the problem?
I have a Zanussi ZCE7550, but apart from that I'm in exactly the same predicament as you in the post you made on Sep 18, 2010...
Can anyone help with a suggestion please???
Sep 18, 2010 | Zanussi ZDQ495 Electric Double Oven
Zanussi zbf360 the glass on the top (HOOB)has
It depends on the make and model, that number you quoted is for your slot in oven,the hob is a seperate unit.They could cost more than the hob is worth but if you get the model number and relog the question maybe we can help.
Hope this helped.
Apr 28, 2010 | Zanussi ZBF360 Electric Single Oven
Zanussi 360 just tripped and now keeps tripping
You will probably find that it is the oven element that needs replacing, located at rear of oven compartment behind rear panel.
Please rate my solution.
Thanks.
Nov 11, 2009 | Zanussi ZBF360 Electric Single Oven
I need replacement control knobs for my hob-can
In your browser bar type in-------WWW.SERVICEFORCE.CO.UK.
Follow the links in the drop down menu, and you should be able to order the parts you require.
Thanks.
Nov 07, 2009 | Zanussi ZBF360 Electric Single Oven
PRIMA FAN ASSISTED COOKER - FAN WORKING BUT NO HEAT?
Hi.
You will need to check the oven element, it probably needs replacing.
Thanks.
Apr 27, 2009 | Bosch HBL 5032 Electric Single Oven
Fan oven on zanussi electric cooker does not heat up
From symptons, I would say the fan oven element is faulty, more so if the fan is working. Remove inner rear panel of oven and see if element gets warm, let it run for a minute, switch off and feel if element is warm, if not, then replace.the element.
Plz rate this solution.
Thanks.
Dec 26, 2008 | Zanussi ZHQ575 Electric Double Oven
Zanussi ZHQ575 Electric Double Oven Logo
672 people viewed this question
Top Zanussi Ovens Experts
ashburton
Charles T Nevin
Charles T Nevin
Are you a Zanussi Oven Expert? Answer questions, earn points and help others
