Question about Insignia IS-LCDTV32 32 in. Television
Plugged speaker into another outlet on woffer and it worked so how would the speaker be blown?? it seems to me that the plug that I plug the problem I have is with that plug at the back of my woffer how do I get that fixed??? granted I am a woman but I do know a little bit of what I'm doing
  • Insignia Master
  • 1,779 Answers
Please start from the beginning so I can get a grip on what the problem is?
Make and Model will help also!
Posted on Feb 19, 2009
Altec lansing acs33
the subwoofer plugs into the wall on a 110 volt outlet. then use mastervolume control.. RANDY
Apr 28, 2014 | Altec Lansing Multimedia Computer Speakers
I have the sub woffer only would like to use on my comp
No problem....just plug the subwoofer into your Green Port on the computer sound section. The Right and Left channel will merge into a monaural sound and come out of the speaker as if you were listening to music from a radio.
Dec 16, 2013 | Dell A525 Zylux Multimedia Computer Pc...
Sony Home Theater System Dav Hdz273 Green-plug speaker plugged into green outlet doesn't work. However, if green plug is plugged into one of the other color outlets, speaker works. If plug anot
Green outlet is the center channel which is not used in all surround modes. Make sure that you have a dvd in the unit, and make sure there is a prologic surround mode selected.
Jan 28, 2013 | Sony HOME THEATER SYSTEM System
Where should I plug in my sub woffer
There should be two jacks on the back that say SUBWOOFER in the "preout" section of the back panel that is directly above the speaker jacks. Either of these jacks should work for your sub hook-up. Also make sure that you set your front speakers to small in the speaker setup menu, otherwise there will be output to the subwoofer jacks.
Dec 27, 2012 | Pioneer Elite VSX-52
The speakers made a repetitive popping and buzzing sound that seemed to strobe as soon as I plugged the entire system in. After awhile the popping stopped and the speakers began to play music, the display...
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Mar 14, 2011 | Altec Lansing ADA 890 Computer Speakers
Speakers won't turn on
Make sure you are plugging in your speakers into a surge protector.
Try pluging in speakers to another (known) working outlet
If unit still does not power on, then unit is blown out.
Jul 13, 2010 | Altec Lansing ADA745 4 Speakers
Plugged into outlet. Spark. When powered up,
First, try plugging a lamp into the socket and see if that works. Next, plug the receiver into a different outlet and see if you have the same problem. Usually, when a receiver shuts down after a few seconds, the problem is a shorted output transistor causing the system to go into auto-protect. A blown transistor may be caused by speaker wires touching at either end. Just a stray strand of wire can be enough to cause real problems.
Feb 01, 2010 | Onkyo TX-SR705 Receiver
My cigarette lighter is not charging in my car what could it be?
You mean there seems to be no power to the vehicle's lighter unit outlet.
This lighter unit outlet is normally wired through its own fuse so check the fuse panel in the car for a blown fuse. If blown it must be replaced with a fuse of the correct amperage. The owner's manual will show you where the fuse is located.
Before you check the fuse just check the cigarette lighter outlet with another plug-in device if you have one such as a portable 12 volt tire compressor or a 12 volt plug-in auxiliary light. It could be that if you are using a charger from the outlet, the charger plug or wiring may be faulty rather than the car's power outlet itself. (These outlets don't usually give trouble unless the wiring has been messed with or the outlet itself has been damaged or abused).
If no device works from the lighter power outlet check the fuse as it may be blown.
Voluntary contributor.
Dec 27, 2009 | 2006 Ford Taurus
Altec Lansing BXR1121
I have same speakers, but only woffer is working, speakers doesnt work. i am really in big trouble.
Apr 24, 2009 | Audio Players & Recorders
Sound won't work
Most likely the audio output stage in the TV is blown!
You will have to bring the set in for service. Most likely they will have to change audio output IC and some support components.
Jerry G.
Apr 19, 2008 | Audiovox AVT-1475 13" TV
Insignia IS-LCDTV32 32 in. Television Logo
16 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
