Question about Danby DDR586R Dehumidifier
My danby ddr557he used it for 2 years and suddenly it stops dryin...any suggestion on how to fix the problem?
SOURCE: We lost the directions for
post a DDR557HE PDF manuel on Danby site.
Posted on Oct 19, 2008
  • 117 Answers
SOURCE: Danby Dehumidifier DDR557HE has never dehumidified
either lacks coolant or compressor bad
Posted on Jan 05, 2010
Testimonial: "Thank you, I didn't even know a dehumidifier had coolant. "
Sheikhtijani
  • 1284 Answers
SOURCE: Danby Dehumidifier Model # DDR557HE Serial #
If you are having problems with your dehumidifier freezing up them here are a few things that you can check and also a few things that may help you.
First check the ambient temperature of the room at the level of the dehumidifier. If it is below 65 degrees and you do not have a special low temperature dehumidifier then you are asking for trouble. Most units are only designed to work in temperature 65 or higher and will freeze if they are working at lower temperatures. Some even will not work well below 68 degrees F.
Many dehumidifiers will shut off when the coil starts to freeze to let them thaw, then they will restart when the coil is warm enough again. This can take an hour or so. Some will not shut down the compressor and when the dehumidifier coil starts to freeze it reduces the air flow and only compounds the problem.
Check the air flow over the coil. If the coil becomes dirty or the fan motor stops or even slows down a bit, you will get freezing. The dehumidifier is very dependent upon the proper amount of air going over the coil to keep the coil warm enough to not freeze. Any restriction will cause problems.
The final and worst thing that can happen is for your dehumidification unit is to develop a slight leak in the refrigeration system. This will cause the coils to run even colder then they would normally and this will create the same problems. If everything else check out then you may have to have the refrigeration system checked by a professional. The problem with this is that many of these units only cost a few hundred dollars and a service call can soon add up to more then the unit is worth.
Some things that you can do to help out a dehumidifier that is freezing up are:
Raise the temperature of the room and provide a bit of heat for the room as the dehumidifier is actually a very small A/C unit.
Raise the dehumidifier up off of the floor… the air is usually warmer when you go higher up in the room, hot air rises.
Clean the coils off so that the air can flow through them easier and keep them warmer.
Make sure that the fan motor bearings are oiled and that the fan is running freely. Even a tiny bit of resistance will slow the fan enough to make a difference.
By checking all these things out and making some small changes you maybe able to make your dehumidifier work much more effectively.
Take care
Posted on Jul 23, 2010
  • 4736 Answers
SOURCE: I need a manuel for
Unfortunately, the model number you listed has been discontinued. But is still supported thru the Danby Consumer help line: 800-263-2629. Contact them regarding your need for the Owner's Manual and they can email you one as an attachment.
I hope this helped you, Susan. Thanks for choosing FixYa.
Posted on Aug 03, 2011
Testimonial: "thank-you very much"
joeguest2
  • 2080 Answers
SOURCE: Need manual for danby Model
Here is a link to a generic Danby user's manual which should help out since they all use the same basic controls:
http://www.danby.com/cms/uploads/products/en_manual/DDR5009,_6009,_7009REE_EFOM.pdf
To view the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents.
You can download this free at WWW.ADOBE.COM if necessary.
Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, then follow the onscreen instructions to install the software on your computer.
I hope that was helpful to you, good luck and take care.
Joe.
Posted on Aug 28, 2011
We have a dandy dehumidifier ddr557he and have lost the manual. How do We get one online
I FOUND SEVERAL PLACES TO GET ANSWERS TO THIS QUESTION(S)
1. I LOGGED INTO DANBY.COM AND THERE IS A FAQ SECTION, YOU CAN DO THIS AS WELL.
2. FOR THE MANUAL I COULD LOCATE IT AT MANUALSDRIVE.COM
THEY HAVE YOUR SPECIFIC MANUAL.
Jan 02, 2015 | Dehumidifiers
My dehumidifier ddr557he will no longer defrost. How do I repair this?
well there are three things i know of that can cause this :
1st your filters are dirty needs cleaning .
2nd your humistat is set too low , unit runs too long with out a cool down period , 70% rh is a "normal" setting
3rd in older units that might be getting up there in years its possible that some of the cooling gas has leaked out and this causes freeze ups
Oct 26, 2014 | Danby DDR557 Dehumidifier
Need manual for danby Model # DDR557HE Seial # 0107040706556
Joe.
Aug 28, 2011 | Danby DDR557 Dehumidifier
I need a manuel for the danby dehumidifier model #DDR557HE. I dont know what the symbols mean
Aug 03, 2011 | Danby DDR557 Dehumidifier
We have Danby Model DDR557HE-7 and cannot locate our Manual. We need to disconnect hose and have excess water go to bucket. How is this done?? If we had copy of Manual we wld be able to search same...
All Danby dehumidifiers, regardless of the model number operate the same way.
The link below to a 50 pint model should provide all the info you need.
http://www.danby.ca/cms/uploads/products/en_manual/DDR5009%2C_6009%2C_7009REE_EFOM.pdf
However, I think you'll find that draining into a bucket is not an option. As the hose drain relies entirely on gravity to drain. So, it will not drain down and then up into a bucket. The hose drainage method, is designed to drain into a floor drain or a sump.
Hope this helps you.
Jul 19, 2011 | Danby DDR557 Dehumidifier
Looking for manual for DDR557HE
The Model Number you listed is either incorrect or has been discontinued. As it does not show up in my data base for Danby. Please check the number again and advise.
Thanks.
Jun 03, 2011 | Danby Dehumidifiers
Jan 04, 2010 | Dehumidifiers
We lost the directions for our Danby dehumidifier. The model number is DDR557HE. Serial. No. 0107050701350. Can you help me out. T. MacKay
I had the same problem but was able to find a link from "Danby's" website. Hope it helps!!
http://www.danby.ca/cms/uploads/products/en_manual/DDR557HE.PDF
Apr 11, 2008 | Danby DDR586R Dehumidifier - 58 Pints...
Danby Silhouette leaking
check that the removable bucket did not alter a water guide near the cooling fins
Jun 05, 2007 | Danby DDR600R Silhouette Dehumidifier
Danby DDR586R Dehumidifier Logo
503 people viewed this question
Top Danby Dehumidifiers Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
Colin Stickland
Colin Stickland
Are you a Danby Dehumidifier Expert? Answer questions, earn points and help others
