Question about Norelco 3605 X Electric Shaver
Proper cleaning of norelco 3605x
Blew hair out of shaver, when put back together it does not run. take plastic top off it runs. WHat is the proper way of cleaning this product. Help... have no idea, just a woman trying to help her son... lol
ButtFuzz
  • 463 Answers
SOURCE: old norelco 3605x electric shaver doesn't charge, doesn't run etc
Batteries are toast.
Posted on Mar 26, 2009
  • 3 Answers
SOURCE: Replacing Heads for 8140XL Norelco shaver
Same thing happened to my father's shaver. After working on it for about 30 mins, this is how I fixed it. You need to start with the top silver piece/cover. Turn it over so you see inside of it. Drop the 3 screens into the holes upside down (so they face out). You need to rotate the screens until they sit as low as possible. Now drop in the 3 blades, again sharp side down. There should be a triangular piece with 3 circles attached to it. One side is gray, and the other side has a black triangular piece. If you look closely each leg of the black piece has a tiny picture of a lock and an arrow. Rotate the black piece in the opposite direction of the arrow. Place the gray side down lining it up with the three blades. Now rotate the black piece, it will lock into position, and hold the blades in place! Finally, the silver head has a little hinge on one side. This hinge is flexiable. Bend it to a 90 degree angle, and slip it into the notch on the top part of the main body of the shaver. Close the head part, in my father's shaver I had to press a lever in the front to snap it into place.
Hope this helps!
Posted on May 13, 2009
brector3
  • 1614 Answers
SOURCE: Replace battery
It is a #8 torx screwdriver. if needed, you can purchase one from shaveroutlet.com. See link below
http://shaveroutlet.com/screwdriver-access-tool-for-norelco-shavers-and-some-braun-p-262.html
Posted on Mar 01, 2010
  • 10865 Answers
SOURCE: Using Norelco 3801XL shaver in Europe
hello. In order to use these devices in Europe you need a power adapter. Go to this link to learn all about it
http://goeurope.about.com/od/electricityineurope/tp/power_adapters.htm
Joe. Please rate my answer as very helpful. thank you
Posted on Mar 25, 2010
brector3
  • 1614 Answers
SOURCE: can I find a replacement battery for a 3605X
you will find this battery type available at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/shaver-replacement-battery-pack-fits-norelco-3605-others-p-277.html
Posted on Feb 07, 2011
Diagram for norelco 3605x Took apart to replace battery and red plastic item fell out and I do not know where it goes Help please.
The red piece is the voltage switch. It allows you to use your shaver to be used with 120V or 220V by moving it into the corresponding position.
This piece fits in at the bottom of the shaver with the notch showing out of the tiny 'window' at the bottom. The metal prongs will situated so that they make contact with the circuit board.
ShaverOutlet com The Ultimate Shaver Source
Mar 19, 2016 | Norelco Health & Beauty
Which shaver replaced the Norelco 3605x
philips norelco HQ56 replacement heads for electric shaver norelco 3605x blades replacement parts.
Nov 24, 2012 | Norelco 3605 X Electric Shaver
Wont run at all - gradually faded and then finally quit all together
It sounds as if the inside of the shver is full of old hair and the like. It needs a good cleaning. SOMETIMES this does not solve the problem and the brushes in the motor could be bad. it is cheaper to replace the shaver than fix one.
Oct 21, 2010 | Norelco 7610X Electric Shaver
Won't hold a charge
Most likely, the battery is dead. To change the battery on model 3605X, you need to remove the back cover by removing the 4 screws. You will need to extent the long hair trimmer to reveal 2 of them. Once back is removed, you can access the batteries. You may find it easier to work with if you remove the 'guts' by taking off the two clips that hold the motor to the shaver. You can then lift everything out.
Simply unsolder the old battery and solder in a new one. Reassemble in reverse order.
You will find this battery at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-battery-pack-fits-norelco-3605-others-p-277.html
Sep 18, 2010 | Norelco 3605 X Electric Shaver
Replace battery
Feb 27, 2010 | Norelco 3605 X Electric Shaver
My clippers are running and the blades are moving but they are not cutting the hair
make sure it is cleaned and before putting it back together put a drop of clean oil between the blades. Also make sure it it adjusted properly.
Aug 04, 2009 | Andis 01690 Hair Trimmer
Norelco 3605 X Electric Shaver Logo
Top Norelco Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Bruce Foote
Level 1 Expert
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Norelco Health and Beauty Expert? Answer questions, earn points and help others
