Question about PDP Systems Heavy Machinery
Pull cord stuck
The pull cord on my 6.5 chipper will not pull it feels like it is stuck was notr chopping when i turned off but after clearing shoot this happened
  • 181 Answers
Pull the spark plug and see if the cylinder is full of fuel.if it is the needle is in the open possition letting fuel into the cylinder.needle needs to be changed....
Posted on Feb 25, 2009
Stanley chipper shredder pull cord is stuck. It has a back-up electric start, which also won't work. The engine sounds frozen.
sounds like something may have jammed the engine! it may be worth taking the pull cord of and then trying to turn engine with a pair of plyers
Apr 08, 2017 | Electric Garden
How do fix a homelite mp88 portable chop saw that has been liquid locked
rey taking the spark plug out and turning it over with the cord a few times to remove the liquid from the chamber and sump
Feb 15, 2017 | Homelite Garden
Pull cord stuck out
clean the soot off of it take it apart recoil it and put new cord on ,dont be so lazy
Feb 11, 2013 | Toro Power Clear 621 R
Can't pull starter, the cord is stuck.
I have the same problem. Did you get any help?
Jul 29, 2010 | Yard Machines 24a 452g729 5.5 Hp Chipper...
Ho do I replace the pull cord on my snowblower? I've removed the housing, removintg the 4 rivets, replaced the cord,however the tension on the cord is not taut. any suggestions? Thanks Ed
take the rope out with the starter on the table turn counter clock wise about 6 to 7 turns. lining up the holes, stick a screw drive throw the holes to hold. feed the rope throw tie off pull the screw driver out let the starter pull the rope in tie to handle.
Oct 13, 2009 | Briggs & Stratton Heavy Machinery
10 hp Troy Built chipper pull start frozen
If a branch was already being chipped when it ran out of gas...you must clear the hopper of any chunks of wood in it. Pull the plug wire and use a metal pry bar to dislodge any pieces of wood. when the flywheel runs free, put the plug wire back on and the choke on. Try it now!!!
Jun 14, 2009 | Troy-Bilt® Briggs and Stratton Chipper
Can't start Chipper
Unplug the spark plug wire FIRST.  DO NOT SKIP THAT.  Then, WITH THE SPARK PLUG WIRE UNPLUGGED AND DISCONNECTED AND NOWHERE NEAR THE PLUG TIP, get a good sized stick, and try to turn the cutter wheel assembly in reverse.  I suspect you have a piece of wood stuck in there, and it won't come loose unless you turn the thing backwards.  You have to disconnect the spark plug because the engine could fire when you turn it.  Even if it doesn't start, one good kick could hurt you pretty seriously.  So, go unplug the spark plug and do your thing.
Apr 18, 2009 | Heavy Machinery
New MacKissic chipper, wont start
it sounds like it is jammed up, take off the plug wire and look inside discharge chute for any debris.
Apr 04, 2009 | Heavy Machinery
Heavy Machinery Logo
402 people viewed this question
Top PDP Systems Heavy Machinery Experts
Bill Boyd
Tom Chichester
ray gallant
Are you a PDP Systems Heavy Machinery Expert? Answer questions, earn points and help others
