Question about Ace Hardware ML250TPA Infra-Red Wall Mounted Panel Heater
My desa vent free propane heater's pilot light starts fine but when the thermostat kicks in it looks like the pilot flame gets sucked up into the heating flame. Once the heater shuts of the pilot light is out. Very frustrating in the greenhouse. Any idea? Thanks
  • musommers Feb 18, 2009
    I will try that, even though the heater is basically brand new, purchased in October. Can it get dirty that quickly? Thank you!
  • 51 Answers
I would turn your has off. Then take apart your pilot gas line, and clean out where the gas come out. There is a very small hole there that will get dirty.
Posted on Feb 17, 2009
  • Kent Guidry
    Kent Guidry Feb 18, 2009
    No it should not get dirty that fast. I was unaware that the unit was new.
The pilot light goes out when I turn the gas control know to on
Clean the flame sensor, thermocouple, or power pile located on the pilot with steel wool.
Nov 23, 2013 | Rinnai Desa Vent-Free Infrared Gas Heater:...
3rd thermacoupler in 1.5 months. I can get the pilot to light and heat a tank, but it will not recycle. Once the tank is hot the pilot goes out. Obviously not the thermacoupler unles strange odds that 2...
Your DESA/Vanguard Vent-free, Blue Flame Heater has a pilot assembly that is equipped with and Oxygen Depletion Sensor (ODS) . When this becomes clogged with dust, lint, spider web, etc, the pilot may light and burn for a few minutes, but will soon shut down. As the ODS senses that there is not enough oxygen for safe combustion. This mimics a faulty thermocouple. A good indication that the pilot is dirty, is when the pilot flame curls upward and looses contact with the thermocouple. Cleaning the pilot and it's ODS with canned air and a straw nozzle (like you clean your compute with) should solve the problem.
To further help you, I have included a link to the Owner's Manual for your Model, as well as a link to how to clean the pilot & ODS
http://www.desatech.com/manuals/Vent-Free%20Heaters/107884-01.pdf
Cleaning the burner & pilot demo: http://www.desatech.com/techDocs/Cleaning%20Demonstrations.pdf
I hope this helps you to further troubleshoot & solve the problem. Thanks for choosing FixYa.
Aug 15, 2011 | Desa International GWN30T 30,000BTU NatGas...
Pilot light too big, how do we adjust pilot light on a Vanguard KV1800?
There is no adjustment for a Pilot Flame's Length on a Vent-free Gas Appliance. However, if you're using Natural Gas and it's a Natural Gas Heater, the normal length of the pilot flame is 2 to 2 1/2".
If it's a Propane Gas Heater and the pilot flame is as long as previously stated, you probably have a pressure problem from your tank. Contact your Propane provider to have them check the pressure on their tank regulator.
Jan 31, 2011 | Vanguard Heating & Cooling
My propane fireplace pilot light wont stay lighted help
Most gas valves have a flame sensor, which is a metal bulb at the end of a wire. The pilot light heats this bulb, and the valve stays open because there's a flame. If the flame has been out, you'll need to hold down the pilot light button for as much as two minutes after lighting the flame to allow the flame to heat the flame sensor up enough to keep supplying gas when you release the button.
Mar 17, 2010 | Desa International CCL3018N 18KBTU VNTFRE...
My husband and I recently purchased a house that has a Comfort Glow Vent-free Propane/LP gas compact fireplace 14,000 to 26,000 BTU/Hr with Thermostat. Model CGCFTP We need to light the pilot light and it...
Remove the small copper colores tubing going from the gas valve to the pilot assembly. Take it to a good hardware store that sells heaters and ask them for a new one.It is called a thermocouple.
Nov 18, 2009 | Desa International Heating & Cooling
My vent free Desa natural log will run for a short
it is likely you have dirty O2sensor, it is incorporated into pilot assembly.turn unit off,use compressed air in a can and blow into spot where pilot flames comes from.this will fix it in most cases.in a small % of time entire pilot assembly needs to be taken apart and cleaned
Jun 25, 2009 | Desa International Unvented Gas Space...
Lighting a glo warm heater
Is this a new heater or have you had it awhile? If new, yuo may have air in the line that will need to be bled out. The heater has a gas valve with a pilot setting on it. Make sure the gas is turned on. Turn the knob to the pilot setting and depress the handle. Holding it down and at the same time, press down on the red button that sparks. You may have to repeat this a few times. Once the pilot lights, continue to hold down on the pilot knob for about 30 seconds. When uou release the knob, the flame should stay o. If it does not, replace the thermocouple. Once the pilot flame is steady, turn the gas valve knob to on.
Nov 29, 2007 | Rinnai Desa Vent-Free Infrared Gas Heater:...
Wont run
check the flame detector it may be a millivolt generator or a flame rod feeding to an electronic circuit.
Nov 16, 2007 | Rinnai Desa Vent-Free Infrared Gas Heater:...
Ace Hardware ML250TPA Infra-Red Wall Mounted Panel Heater Logo
278 people viewed this question
Top Ace Hardware Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Cris Sparks
Cris Sparks
Are you an Ace Hardware Heating and Cooling Expert? Answer questions, earn points and help others
