Question about Uniden BC60XLT Handheld Scanner
I have a scanner and a piece is broken. How do i fix it
    Problem Solver:
Well what part is broken
Posted on Mar 13, 2009
Scanner Error 22 Hp Laserjet M1213nf MFP printer
it is a physical broken piece that supports scanner mechanism. from what i can find. dont no if this has helped.
Jun 16, 2016 | HP Office Equipment & Supplies
Scanner lid hinge broken or missing
If you read through the posts, there are many ideas on what to do. The cheapest and easiest way I found to fix a broken hinge is to follow one the ideas in the posts. I wrote a detailed post step-by-step. In quick summary, I broke the other hinge and removed all the broken pieces to both, so the lid would lay flat again. Printer doesn't care if the hinges are not there. The manual is on line:http://h10025.www1.hp.com/ewfrf/wc/manualCategory?cc=us&lc=en&dlc=en&document=&product=3635378 Hope It's resolve all Your Printer Problem,
Or Still having Problem Then follow Us For
HP Support
Apr 01, 2014 | HP Officejet 6700 Premium E-All-In-One
Printer brand brother model DCP-J125. does not working properly, Close ink cover has appear the LCD monitor
The sensor for this is actually used for both the scanner cover and the ink cover,
there are two flags that both must sit into the sensor to reach a ready state.
If you examine the ink cover there's a small piece of plastic that paths into a hole on the machines frame. This piece of plastic pushes a small black plastic flag that tells the sensor the door is closed.
If it's constantly telling you to close the ink cover inspect both the cover itself to verify that piece of plastic isn't broken and is going into the hole; and look inside and verify the flag isn't broken or damaged (flashlight and a small eyeglass screwdriver help here)
Either can be fixed for cheap at any reputable printer repair shop, I would look for a brother warranty place even if it's out of warranty as they'll be more likely to have donor machines sitting around for spare parts.
Jun 01, 2011 | Brother Office Equipment & Supplies
The scanner glass is broken on my Cannon PIXMA MP460 - I want to have that replaced.. what would be cost
The Canon scanners are only one piece, you can only replace the entire scanner as no separate parts are available. The last one I replaced was $95.00 for the part.
Jan 09, 2010 | Canon PIXMA MP460 All-In-One InkJet...
Light flashes and it says the scanner door is open but everything is closed
More common reasons are paper jam, dust/dirt, or a faulty sensor.
So, check for even the smallest pieces of paper, especially in the scanner area, use compresser air if necessary and clean the scanner glass.
Your sensor could also be broken/faulty. Not certain if the sensor is a user-replaceable part.
Hope this helps.
Aug 10, 2009 | Canon DR-2580C Path-Through Scanner
Canoscan d1250 u2f red and green lines
Normaly Red Green or Blue lines appear because of Dust in the CCD or due to electronics Failure. If this problem had happened after some SW changes then Try connecting the Scanner to a different Machine.
May 31, 2009 | Canon CanoScan D1250U2F Flatbed Scanner
DS Mobile 600 scanner won't scan
Joel, I had the same problem as you. After reading design454's solution, I decided to open up the scanner and see what I could see. There are just 4 tiny screws to deal with, so separating the two halves is quite simple.
There's a system of 4 or 5 white plastic gears that revolve the roller. Within 10 seconds of playing with these, I noticed that one of the tiny plastic gear teeth had broken off and was jamming the gears. After I removed the broken tooth, the gears turned smoothly. Screwed the thing back together, and it worked like new! And all it cost me as a $2 precision screwdriver set.
Apr 16, 2009 | Pentax DSmobile Path-Through Scanner
Finding a speaker microphone
There are many sellers on eBay that sell lapel speakers for scanners.
Dec 19, 2008 | Uniden BC92XLT Handheld Scanner
Coolscan 4000
Well, I finally discovered the solution to my problem of not being able to scan...the scanner had several broken parts inside including pieces of plastic wheels and such as well as a spring jammed in the upper slide rail. So, it was not able to re-set or move into the proper position to begin a scan. I called the Nikon repair facility in Las Angles and they wanted $200 to check it out plus parts to fix it. So, instead, I purchased a Coolscan V and it works great! I still have the broken Coolscan IV and may try and have it fixed someday.
Nov 06, 2007 | Nikon Coolscan IV ED Film Scanner
Opening up the scanner.
is there a power line to scanner
Sep 01, 2006 | Symbol Cobra LS1902 Handheld
Uniden BC60XLT Handheld Scanner Logo
Top Uniden Radio Communications Experts
Jason
John
John
Greg Cann
Greg Cann
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
