I have an ongoing problem with my laptop. I have an NEC Versa M300 laptop, and as I have a USB2 Maxtor external storage device and a HP dc4000 DVD writer, I have also invested in a USB2 cardbus, as the laptop has only USB1.1. Anyway, whenever I plug either device into the USB2 card, it seems to work just fine, until the system freezes completely and my only option is to restart the machine. I have taken it to technicians to get it looked and and nobody has been able to tell me anything as to why the machine continues to crash. The freezings are random in nature - although they occur every time I am using the card.
If anyone has any suggestions I would be most appreciative. This problem has been driving me up the wall for almost three years now - I'd appreciate knowing something (even if it was worst case scenario!).
I finally found a solution with my Belkin USB 2.0 card and my Compaq Presario 1722 EA. Here it is:
click om the safely remove hardware on the taskbar but the keep the card connected to the laptop. Right click on My Computer --> Properties --> Hardware ----> Device Manager, under USB controllers click on PCI enhanced USB controller (which should have a yellow exclamation mark) right click it and click update driver.
Wizard shows up Choose Install from a list or specific location Then choose Don't search I will select a driver to install from the list I chose the Manufacturer's driver (Which in my case is Belkin) instead of the Windows Enhanced PCI **** (don't mind the rubbish of this driver's is not digitally signed) click next and wait for it to install then restart computer when it tells you and thats it.
One last thing: For the above method to work you should've installed the Card's Driver software prior to trying the above technique.
Solution #2
posted on Aug 01, 2007
Beresford - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
: I'm guessing that it is not a card-related issue - rather it may be : that having both USB1.1 drivers and USB2 drivers may be causing the : machine to "cross wires" and causing the system to crash. Does this : seem a sensible possibility?
Doubt it. My laptop has both USB1.1 and a PC Card add-on like you use to add USB2.0, and I've used both ports at the same time. My computer has never frozen up.
Andrew --
> To Email me remove "MYSHOES" from email address
Was this helpful?
Yes
No
Solution #3
Jimmy NY - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
Thanks for the responses! In answer to the questions posted on this thread:
- Both external devices are powered externally. The USB2 card is also powered externally.
- The USB2 card is a Belkin card.
Previously I had a 4-port USB2 card (no manufacturer) which was also powered externally - the freezing began with this card - so I then switched to a Belkin card, and the system freezes haven't been fixed.
I appreciate that people who post to these threads haven't had the chance to see the machine at work. I was merely wondering if anyone had had the same experience and had found a potential answer. I have been trawling these threads for a long time and am yet to see a similar problem to mine...
I'm guessing that it is not a card-related issue - rather it may be that having both USB1.1 drivers and USB2 drivers may be causing the machine to "cross wires" and causing the system to crash. Does this seem a sensible possibility?
Thanks,
Sam
Was this helpful?
Yes
No
Solution #4
Pasty - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
The question must be asked if the answer was not previously supplied by the OP. There are countless similar problems being posted to this and other groups wherein the posters incorrectly assume that on-board USB ports or the USB2 ports on PC-Cards are capable of supplying the required power for their removeable drives, especially external drives in enclosures. No one reading the OP has the benefit of having the computer available for inspection.
Q
Was this helpful?
Yes
No
Solution #5
Rank: Apprentice
Rating: 0%, 0 votes
: Hi everyone,
: I have an ongoing problem with my laptop. I have an NEC Versa M300 : laptop, and as I have a USB2 Maxtor external storage device and a HP : dc4000 DVD writer, I have also invested in a USB2 cardbus, as the : laptop has only USB1.1. Anyway, whenever I plug either device into the : USB2 card, it seems to work just fine, until the system freezes : completely and my only option is to restart the machine. I have taken : it to technicians to get it looked and and nobody has been able to tell : me anything as to why the machine continues to crash. The freezings are : random in nature - although they occur every time I am using the card.
: If anyone has any suggestions I would be most appreciative. This : problem has been driving me up the wall for almost three years now - : I'd appreciate knowing something (even if it was worst case scenario!).
You didn't mention the manufacturer of the USB2 card. Obviously, you could try another one, perhaps a card with a different chipset. The card you have now may simply have some sort of electrical problem and may always have had one.
Andrew --
Was this helpful?
Yes
No
Solution #6
Bomber - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
: : : : : : : : : : : : : : : : : : You do not mention how power is supplied to the devices. Both need : substantial power and the add-on card might not supply enough.
I'm guessing that both a DVD burner and an external hard drive are both self-powered, so power is probably not the issue here.
Andrew --
Was this helpful?
Yes
No
Solution #7
pawa - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
You do not mention how power is supplied to the devices. Both need substantial power and the add-on card might not supply enough.
I just upgraded to Win Vista Ultimate and cannot get the drivers for my hp movie writer dc4000 to...
(More)
I just upgraded to Win Vista Ultimate and cannot get the drivers for my hp movie writer dc4000 to load. Any suggestions? As far as I know there are no wista drivers available. Thanks ;)
Hi! I have a RDR-HX780 recorder and I'm suddenly having trouble with the recording from TV option....
(More)
Hi! I have a RDR-HX780 recorder and I'm suddenly having trouble with the recording from TV option. As recent as yesterday, I was able to scroll up or down to choose the channel to be recorded, but now I'm only getting a choice of channels 2 thru 6, then Line 1, Line 2, or Line 3. I have no idea what "Lines" are?? What did I do wrong?
No software was in the box. Think I need HP video Transfer Wizard, Arcsoft ShowBiz 2, Muvee Auto...
(More)
No software was in the box. Think I need HP video Transfer Wizard, Arcsoft ShowBiz 2, Muvee Auto Producer DVD Edition and Sonic RecordNow. Can you assist?
When I try to capture movie from my digital camera I get the error message: Device Initialization...
(More)
When I try to capture movie from my digital camera I get the error message: Device Initialization failed. Please check the device. What do I do?
The HP DC4000 movie maker has been working well for me for almost 2 years. However, one day, when I...
(More)
The HP DC4000 movie maker has been working well for me for almost 2 years. However, one day, when I was transfering a video to the DC4000, I encountered a problem, with the following message:
"Command_Name_Handler" Unknown Exception
Can anybody help me?
