Question about Acer Aspire 4520-5582 Notebook
My realtek digital output will not emit any sound.
I restarted the computer a few times, gave it some time, and it magically worked.
Posted on Feb 20, 2009
Just bought HDMI cable to be used on dv9700 got the picture on my tv, but no sound go to sound option but not able to see any HDMI sound output I got only 2 options on my sounds: 1. Speaker 2....
We might need to change the audio settings from Sound and Audio device properties window.
Open Control and double click on Sounds and Audio devices to access the window.
Change the audio output from analog to digital.
Make sure that HDMI audio is enabled in the sound device.
If the source device menu has adjustment for PCM frequency, set the frequency to 96khz or less than that.
Sep 01, 2010 | HP Pavilion dv9000z Notebook
No sound
Go into your sounds settings Control Panel> Hardware and Sound (on Xp its just sound)> sound> You should have 4 types of speakers available. I have Digital Output Device (HDMI) Speakers Realtek Digital Output Realtek HDMIOutput my default was the HDMI and i changed it to speakers and then my speakers worked.
Hope this helps ^^. Please don't forget to rate, Thanks
Feb 26, 2010 | E-Machines T3504 PC Desktop
No sound from the HDMI
This document pertains to HP or Compaq PCs with an HDMI (High-Definition Multimedia Interface) connector for connecting a monitor or TV. If you use HDMI to connect your display, you must activate HDMI sound by adjusting your Windows settings . If HDMI is not activated, you cannot hear any sound. Because of this, HP recommends that you connect analog speakers to the computer to hear sound during the initial setup of the computer. Use the following steps to activate HDMI sound on your computer: NOTE: If you ever perform an HP system recovery, you must repeat this procedure to activate sound for the HDMI connector.
  1. Right-click the Volume icon by the time in the lower-right corner.
  2. Click Playback Devices . The Sound window opens.
  3. On the Playback tab, click Digital Output Device (HDMI) if it is listed. If it is not listed, click Realtek HDMI Output . Figure 1: Digital Output Device (HDMI) selectionc01503048.gif Figure 2: Realtek HDMI Output selectionc01063625.gif
  4. Click Set Default .
  5. Click Apply .
    • If you used Digital Output Device (HDMI) , click OK to close the window. This completes the steps to activate HDMI sound.
    • If you used Realtek HDMI Output , continue with Step 6.
  6. Double-click Realtek HDMI Output . The Realtek Digital Output Properties window opens.
  7. Click the Supported Formats tab.
  8. Place a check in the 48.0 KHz check box, and make sure that there are no checks in the Dolby Digital check box and all other check boxes. Figure 3: Supported Formats settings in the Realtek Digital Output Properties windowc01503049.gif NOTE: For most TVs to play back audio, the sample rate must be 48.0 KHz.
  9. Click OK to close the window.
Nov 23, 2009 | HP Compaq Computer Speakers
Acer ax1700-u3793 doesn't display an hdmi sound output option
try to check if the audio cable(jack) is properly connected to your device or speaker
Aug 30, 2009 | Acer Aspire AX1700-U3793A PC Desktop
Realtek digital output no sound
hi..if you have a mother board installer try update the driver sound but 1st remove the old driver from your PC/unit..good luck..good day...^_^
Jun 10, 2009 | Acer Aspire 4520-5582 Notebook
Bose Companion 3 and Realtek HD Audio Card - No sound
Hi: I'm sure you checked the volume control of the Bose controller. Check where you plugged it in to the back of your computer. Mine has a veriable outpup and a fixed output. I hope this helps, Jeff
May 31, 2009 | Dell Computers & Internet
Can Realtek output to two ports?
line out to receiver to AMP
speaker out to receiver or mixer
depends also on your sound card , if it has more that one exit, some come with several channel out.
Mar 25, 2009 | Computers & Internet
i think your spund drivers are not updated as per your requirement and they are not working properly....
secondally it might b a problem in your volume controler or audio pin
Feb 22, 2009 | Creative Labs Computers & Internet
Sound problem
if you have motherboard installation driver cd.
load the sound card driver again.
or download it from i net.
hope it solves the issue.
go to control panel
sound and audio devices.
audio tab
sound playback
select correct audio device ie souncard rear output.
also on task bar vlume control make sure volume is not muted.
for master volume and wave .
make sure speakers are inserted in correct output jack.
May 18, 2008 | Computers & Internet
No sound if audio is set to realtek digital output
THe realtek Digital Output will only output sound if you have an optical cable attached. this allows you to connect your laptop a audio receiver via an optical cable. this is why you get no sound when it is set to digital output.
Apr 19, 2008 | Acer Aspire 4520-5582 Notebook
Acer Aspire 4520-5582 Notebook Logo
91 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
