Question about Maytag Performa PAV3200
My maytag performa PAV2300 stopped in mid cycle and I smelled something burning. Had the repair person out and he said it's the belt and the plastic top that houses the motor. He said that the entire motor needs to be replaced as you can take the plastic off. Is this true? His charge to replace the motor and belt is $200.00
  • 640 Answers
No 1 tech here can give advice on how much a repair will cost,,because repairs differ form city to city..onthejob,,,
Posted on Feb 17, 2009
Maytag Performa clothes washer. Model LAT2500AAE. Made screeching sounds during spin cycle also burned rubber smell. Turned off. Removed and replaced belts. One belt was shot. Ran a test run and still...
Check to see if your water pump is spinning. It could be seized up and the burning smell could be the belt spinning on the seized pulley. Good luck Friend.
Oct 10, 2017 | Maytag Washing Machines
MAYTAG PERFORMA MODEL# PAV2300AWW, REVISION#12, SERIAL#12296390ZM Washer filled but made loud grinding sound while agitating. I couldn't drain water on spin cycle. Now it has stopped working, I smelled...
hello you need to change drum rollers but if u remarked water dawn the washer and burn smell it could be the motor OR THE BELT because when the drum stop turning or turn slowly the motor turn fast on the belt when spin time it make this smell .
Sep 11, 2010 | Maytag Performa PAV3200
Maytag Performa, Noisey spin cycle, now does not work
the belt may be old and stretched/slipping...if it is stretched and slipping it will cause the squealing .............otherwise, check the pulley for the belt/motor to see if it is okay and the motor itself copuld be worn out if the belt looks careful, you can get zapped if you touch a wire and also if the motor is burned up it can cause a fire so watch carefully and you should be able to see which of these possibilities are the problem..............
Feb 13, 2010 | Maytag PAV2300 Top Load Washer
Maytag washer sounds like a jackhammer when rinsing - this is a new thing with all loads. Yesterday it shut down mid cycle while still full of water and we smelled a burning rubber smell. Any ideas?
There is only one belt on the machine (the burning rubber smell, probably). Sounds like something is wrong with the clutch /drive mechanism. Unless your an accomplished DIY'er, it sounds like a job for the Maytag Man.
Sep 15, 2009 | Maytag PAV2300 Top Load Washer
Maytag Performa washer stopped mid cycle
It will not be either , after emptying tub lean the unit back so you can see under it , remove the belt and turn each pulley/wheel with your hand , the pump is norm. on rear right corner and is usually the problem it will be hard to turn if bad , the pump is an easy fix, the pulley that is stuck is the component that is bad if not the pump. the large tub pulley should turn both ways with some effort , if not it could be the gear case causing this. Let me know if you have any questions.
Apr 11, 2009 | Washing Machines
Maytag Performa PAVT920AWW noise in wash cycle no agitation. Belt is not broken but in the wash cycle there is no agitation only a bad bearing sound.
Your main tub bearings need replacing at least a 200.00 repair. The parts alone are about 80.00 and a few hours labor.
Mar 29, 2009 | Maytag PAV2300 Top Load Washer
Stopped mid-cycle
I have the same problem.  Model: LAT2300AAE Serial: 30220055ZM
Maytag Performa - does anyone have any advise or should I just call the Maytag man?
Jun 05, 2008 | Maytag Performa PAV2200
Quit . Will not do anything. I checked the power to the machine.
see if you can turn by hand.. the transmission pully and pump pully.. sounds like one of them is bound up, the smell was probly the belt burning with nothing starting to spin
Sep 01, 2007 | Maytag PAV2300 Top Load Washer
Washing Machines Logo
163 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
