Question about Dyson DC17 Animal Bagless Upright Cyclonic Vacuum
My dyson DC17 will not turn on unless the handle is pulled back.(into the vacuuming position) The attachment hose will not work at all (0 suction thru it). I've checked the hose and made sure there is no obstruction. Any ideas?
  • Anonymous Feb 28, 2009
    the red start button doesn't turn anything on. The brush motor does but not the vac motor. I think the motor should have lasted longer. Any ideas?
    President:
  • 389 Answers
Not sure if I can help, but I'll try. The DC17 has two motors: the vacuum motor and a separate motor for the brush bar. It is normal that the brush motor works only when the handle is pulled back in the vacuuming position - that's the way it's made. So, when you say "my DC17 won't turn on", I'm not sure if you mean the vac motor, the brush motor, or both. If the vacuum motor won't turn on, then you've got a problem I can't help you with.
As for no suction through the hose, I have to ask... are you sure your vacuum motor is working at all? Even with the hose stored away, the machine still relies on suction through that hose. If you're sure the motor is working, then either you've got a blockage that you haven't yet found (there's at least one inspection port, a sort of U tube at bottom right of machine, that you need to check), or it could be that you've got a hole in the flexible hose (which opens only when the hose is extended).
Sorry if this is a bit garbled, but I'm puzzled by your problem. If you want to come back with more details I'll try again for you!
Posted on Feb 18, 2009
    New Friend:
I am having the same problem. Were you able to find a solution?
Posted on Sep 22, 2013
Dyson has no suction and hose doesn't work
Hi Brenna, it's Jack at Dyson.
I'm sorry to hear you're having difficulties with your DC17 Absolute. I can see that you've already checked for blockages, but the issues you've describe do strongly suggest that there's a blockage somewhere in the machine. You might want to follow the steps shown in our online Support guide, as this should help you locate any obstructions you may have missed:
http://content.dyson.com/support/help.asp?article=955&product=DC17-ANIMAL
If you aren't able to find a blockage, but continue to have difficulty with your vacuum, please email us so our experts can help further. You can reach us at askdysonUS@dyson.com.
Best wishes,
Jack
Dyson Online Customer Support
www.dyson.com
Jul 06, 2013 | Dyson DC17 Animal Bagless Upright Cyclonic...
Dyson dc17
If the brush roll is worn out or not working properly it will not pick up even light debris like hair and lint even if you have great suction. Check the brush roll first.
Sep 25, 2017 | Dyson DC17 Animal Bagless Upright Cyclonic...
Poor Suction
The flexible hose between the beater bar housing and the connection to the dust bin might have come loose or has a hole in it. Check this hose for your low suction problem.
May 15, 2010 | Dyson DC17 Animal Bagless Upright Cyclonic...
I don't get much suction from the hose on my DC17 All Floors. I don't see any obtacles in the hose. The suction when upright is fine.
The way your Dyson DC17 is designed, there is a suction divert mechanism that diverts the suction to floor when the vacuum cleaner head is pushed down, and then back to the hose when the vacuum is in the upright position. If you are getting suction from the hose when the vacuum is upright, but no suction after the handle is reclined, this is actually the normal function for the Dyson DC17.
You can check to see if the filter is dirty. The washable filter on your Dyson DC17 is located directly underneath of the dust bin of the vacuum cleaner. After removing the dust bin, lift straight up on the part the bottom of the dust bin rests on. This is where the pre-motor filter is located for the DC17 models. If this filter is not cleaned on a regular basis, then it can start getting clogged, and you'll notice a loss of suction on the vacuum cleaner.
If you have further questions, please visit the link below where you may download the instruction manual. There are some trouble shooting guides at the back of the manual that you may do to try and diagnosis this further.
Dyson DC17 All Floors Instruction Manual:
http://media.dyson.com/downloads/us/floorcare/manuals/dc17_opmanual_usa.pdf
If this was helpful, please be sure to rate the repair as helpful by clicking on the thumbs up icons on the top of the repair.
Thank you very much,
Chris Jones
GoVacuum
Mar 23, 2010 | Vacuums
Dyson DC17 Animal does not have enough suction from the wand handle to power the mini turbine head. The wand handle has very little suction.
Hi its Darran at Dyson.
It sounds as though your wand/hose assembly is blocked. Try following the blockage procedure in your user guide or visit our website's support section where you can use our self help guide to diagnose problems.
www.dyson.com
Kind regards
Darran
Dyson Customer Service
Mar 10, 2010 | Dyson DC17 Animal Bagless Upright Cyclonic...
My dyson dc17 animal will pick up via the hose attachment but there is no suction when you use the regular vaccuum on the floor - you can hear the difference in the suction once you put the floor part down...
Check that the brush control dial is in the centre position when upright and then moves forward when the head is released. If the brush bar is still not spinning when switched on in the vacuuming position, check the base for blockages and remove any threads or hairs from the brush bar as outlined in your user guide or on our website.
If you are still having difficulties, please contact our Helpline on 0800 298 0298 (UK) or 1866MYDYSON (US).
Kind regards
Darran
Jan 16, 2010 | Dyson DC17 Animal Bagless Upright Cyclonic...
My DC17 suction hose doesn't have any suction occasionally.
check the seal on the filter is not broken,And check for any blockage at the bottom of the pickup pipe.
Nov 18, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Suction from hose isnt strong enough. Vacuum
There is probably a clog on the U channel (little Gray tube that attaches to the Vac tubing). Pull it loose and look in side all the tubing.
Nov 16, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Can't get it to ****!!!
Worked on one with your same problem of poor suction and won't stand up. On the left side of the handle, near the bottom, the port cover isn't on correctly. Take it off, put the handle in the upright position then reinstall the cover.
Mar 29, 2008 | Dyson DC17 Animal Bagless Upright Cyclonic...
Dyson DC17 Animal Bagless Upright Cyclonic Vacuum Logo
1,517 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
