Question about Refrigerators
I have a Hotpoint RLA31 fridge which has just stopped working.
The fridge was working fine then just seemed to stop. Have checked fuse and socket, and have looked at fridge. There is no smell of burning or any other problem. Do you know if there are any internal fuses that may need checking, or what else the problem may be?
  • 51 Answers
Although I feel you have checked all the fuses associated with your unit, there are other things that would keep the voltage from the compressor. When your refrigerator starts, power is applied to the start windings of the compressor via a starting relay. Once the compressor is started the relay switches to the run windings. In series of the start relay is an overload device preventing too much current draw. It may be possible that either your relay is broken, or your overload is not closing for some reason. You can buy these starting components for fairly cheap. So to answer your question, no there aren't any more fuses, but there is the overload.
Posted on Feb 18, 2009
Fridge part of fridge freezer stopped working
Please add the make and model of your fridge. Is it frost free or not?
Jan 06, 2014 | Beko Refrigerators
Hotpoint rla31 motor constantly running/freezing at the back
Your fridge is cooled by the freezer, the thermostat is within the Fridge to tell it to shut off, you might have a bad fan or a build up of frost where the air is sent to the fridge, check where air goes to the fridge when it's running, if you don't feel air flow then something is up, best thing you can do is take everything out and allow the fridge to defrost, at leat 24hrs. then see what happens, if you don't feel air flow after the defrost then you fan is shot and you'll need to replace it.
Aug 04, 2012 | Hotpoint RLA31 Compact Refrigerator
Hotpoint Mistral Fridge freezer no Power Issue
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} . Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay.
How to check stuff>
Dec 11, 2009 | Hotpoint FFA80 Bottom Freezer Refrigerator
The fridge has completely stopped. There seems to be no power. Is this maybe a fuse thing?
hope your food isn t spoiled ,first of all grab a lamp and plug it into the same socket and if it doesn t light check your breaker second if you know which outlet does work get an extension cord and run that over to fridge and plug it in and see what happens could also be a breaker be careful electricity if the fridge starts your doin good
if not bad fridge sorrry
Aug 10, 2009 | Fisher and Paykel Refrigerators
Hotpoint FFA71 fridge and freezer suddenly stopped working
Sounds as though the compressor has stopped working. It feeds both compartments with control from a printed circuit above the top door.Where all your red lights are ablaze! (This can be replaced by removing the 2 screws and "clicking" out the small panel) Check that the compressor is running at the bottom rear of the fridge/freezer before anything else.
Jun 30, 2009 | Hotpoint FFA70 Bottom Freezer Refrigerator
Hotpoint WD64 No power - help please !
hi from n/west uk from the symptoms you describe ? that you have no lights on machine? this is most definately total power loss to machine so if you are certain? the fuse is ok? next is has the wire/lead from plug chaffed or damaged breaking the supply? this next possibility may sound odd but the socket you plug machine into ? may be faulty ie the damp location at rear of machine could have caused deteriation of socket terminals or wires even the wire may have broken/come loose? have had this happen in homes and caused by wires not secured properly and eventually arcing/ resulting in power fail at socket ? may i suggest try another elec appliance ie lamp/hoover/ iron? to check if socket is operating just to eliminate? also if the socket is a fused type? make sure this fuse is ok too? finally have you checked consumer unit for possible seperately fused/trip out for the machine use socket ? hope this helps find fault best wishes
Oct 26, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpoint FFA47 no power
If the evaporator fan is not working the refrigerator will not run.
Jul 07, 2017 | Refrigerators
Refrigerators Logo
187 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
