Question about Motorola Mobility H500 Wireless Headset
Need to connect bluetooth to new cell phone and cant
I have the motorola h500 bluetooth and i need to connect it to my new evny 2 how do i connect them
  • Anonymous Feb 18, 2009
    cant connect 0000 doesnt work what other codes r there
  • Anonymous Feb 23, 2009
    need to connect bluetooth to new cell phone and cannot
Try 1234.
Posted on Feb 19, 2009
Can not connect H500 bluetooth with Nokia 2680 slide cell phone. Need Motarola instructions.
Here are the steps to connect your Motorola H500 to your Nokia 2680 phone:
1. Switch off your H500 by pressing the main button for few seconds. 2. Put the H500 in discovery mode. To do this, press and HOLD the main button till it glows a solid blue light (no blinking). 3. Open bluetooth in nokia phone. Go to Menu, settings, Connectivity, Bluetooth. 4. Select "Add a new Device" and search for H500 5. Click on the name select pair. 6. it will ask for pairing code. Enter "0000"
You are done. Revert in case you have any problem
Jun 09, 2011 | Cell Phones
Unable to use new h500 headset
The H500 is a monaural headset, thus good for phone calls only, not for listening to stereo music. You haven't specified which Motorola phone you own. Check in its user guide if it is able to handle stereo bluetooth headsets (i.e. if it bears the A2DP and AVRCP bluetooth profiles), which are suitable for music streams. If your phone is able to handle them, go to the mall (or store, or even online), buy one set which suits you better, pair them with your phone and enjoy!
Just my 2 cents... Carlos
May 23, 2010 | Motorola Mobility H500 Wireless Headset
Pair motorola H500 to samsung eternity SGH-A867
I have had this problem too. Here is what worked for me.
1) With the Motorola H500 OFF, press and hold the talk key until you see a steady, non-blinking blue light.
2) Keeping that button pressed, turn on the bluetooth on the samsung eternity.
3) It should now find the H500, click on it and select connect.
4) Put in a pass key (I just put in 0000) and your done.
Mar 06, 2009 | Cell Phones
Cant Pair my Motorola H500 to my LG Rumor
turn bluetooth on your phone on. then on your bluetooth headset hold the power button for about 10 seconds or until you see the bluelight on steady. next on your phone in the bluetooth section klick ok on the search for device option, when you found the bluetooth with your phone it will ask if you want to use that device, klick yes, and it might ask you for a code, enter four zeros "0000" and that should connect automatic.
Feb 28, 2009 | Motorola Mobility H500 Wireless Headset
Connect LG CU515 to Motorola H500 Bluetooth
here is the manual for the lg CU515: http://www.wireless.att.com/support_static_files/manuals/LG_CU515.pdf
however, you should just be able to go to the bluetooth menu, select "search new device" (looking for "Motorola H500"), then press "add" - the passcode should be "0000" (without the quotes)
Feb 03, 2009 | LG CU515 Cellular Phone
I have a Motorola H500 BlueTooth headset. I'm trying to setup the headset to turn on and I'm trying to follow the instructions on how to turn on the device by holding the Call button to for 6-7 seconds but...
1.Press and hold the Multifunction button in the middle of a boom headset while the headset is closed. The light will glow blue.2.Open the boom microphone and the blue light should remain on. If not, repeat step 1.
3.On the cell phone, press Menu > Settings > Connection > Bluetooth > Handsfree > New Device
4.Select H500 once a connection is detected.
5.The passkey "0000" is now entered to confirm the connection has been made.
6.The cell phone screen will now read "Bluetooth Connection".
Tips:
1.Provided you set the Bluetooth power to "On" after the initial connection has been made, the phone will automatically re-connect to the headset.
2.To set the Bluetooth power on - Press Menu, Select Settings, then Connections, then Bluetooth link, scroll to Setup and select that. Scroll to Power and chose Change. Scroll to On and press Select. The screen should now read "Changed: Power On".
3.Test Your Connection: Close the headset and watch for cell phone to say "Disconnected". Re-open the headset and the phone should be connected automatically and will now display "Bluetooth Connected".
please give good rating if the solution works.
Thanks for using FixYa.
Dec 11, 2008 | Motorola Mobility H500 Wireless Headset
Motorola H500 and a motorola v3x phone searches and finds headset but won't connect
Tips:
Nov 02, 2008 | Motorola Mobility H350 Wireless Headset
Bluetooth H500
when it asked for the pincode to paired the bluetooth headset enter the code 0000
Jan 02, 2008 | Motorola Mobility RAZR V3
H500 bluetooth
AFTER CHARGING headset hold down big button in center of headset until BLUE INDICATOR LIGHT REMAINS SOLID BLUE
tHEN TURN THE BLUETOOTH OPTION ON YOU CELL ON
GO IN TO MENU UNDER BLUETOOTH OR CONNECTIONS SELECT ADD DEVICE YOUR CELL WILL SARCH FOR DEVICE WHEN IT FINDS IT THE NAME OF THE BLUETOOTH WILL APPEAR ON DISPLAY CELL WILL THIS ASK CONNECT OR BOND WITH DEVICE SELECT YES IT CELL WILL ASK FOR PASSCODE PUT IN 0000 THEN AFTER THIS BLUETOOTH HEADSET SHOULD START FLASHING INDICATING HEASET HAS CONNECTED
Dec 31, 2007 | Motorola Mobility H500 Headset
Problems With Pairing H500 and Motorola V190
4.Select H500once a connection is detected.
Tips:
Dec 24, 2007 | Motorola Mobility H500 Wireless Headset
Motorola Mobility H500 Wireless Headset Logo
67 people viewed this question
Top Motorola Mobility Radio Communications Experts
Coss
Lawrence Oravetz
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
