Question about Kenmore 84052 Dryer
How to find fuse box for kenmore dryer
Need to know how i can find fuse box for kenmore dryer model no 86983110
5 Suggested Answers
  • 1122 Answers
SOURCE: No heat from Kenmore dryer
you can also check the heater box fuse,let me know if that is it-mike
Posted on Oct 26, 2008
TMurdock
  • 93 Answers
SOURCE: Kenmore Electric Dryer will not Heat
Define checked everything. Usually when your dryer is not heating but blowing air its one of three things...
1. Thermal fuse in dryer
2. Thermistor in the dryer
3. Heating element in dryer
You need a signal meter with continuity check to accurately test all three componets. Normally the fuse and thermistor are in a set and cost less than 25 bucks. They are easy to replace if you are good with taking things apart. If the element is bad then you need to make sure your lint trap and exhaust hose are clean and kept clean. That is the main cause of the element burning up when it gets lint collected inside the dryer cavity.
In a pinch if the element is bad you can simply find where the metal has broken and try bending the rod so that it touches. The element has to be one solid piece so if there is breaks try and connect them back together until a new one can be purchased.
Please unplug the dryer before doing anything mentioned above.
Hope this helps
TankMurdock
Posted on Apr 27, 2009
heatman101
  • 43501 Answers
SOURCE: Dryer is BROKEN
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Posted on May 03, 2010
hunter19_46m
  • 7482 Answers
SOURCE: Hello. I'm looking for
Hi dswooldridge...
Give a phone call to this parts house, they may have what you need.
www. partselect.com
1-888-895-1535
You can also go to the sears website and they have a phone number there, and also a parts search:
http://www.searspartsdirect.com/partsdirect/contactus.pd
Please take time to rate me
Posted on Sep 03, 2011
Kenmore dryer model #110.80754001 NOT HEATING
you checked the element so you know how to use a meter good,go in the back again,look at the duct that the lint filter goes into down low and to the right you'll see a white part with two wires going to it,that's the thermal fuse,pull at least one of the wires off and check for continuity,if you haven't cleaned out the dryer and vent line this usually pops,if the dryer can't move air from lint blocking the air flow the fuse will pop because the dryer is running to hot,if the fuse is good check the t-stats on the heater box for continuity.common things to go thermal fuse or t-stats on heater box,all has to do with dryer running to hot.thermal fuse is part WP3399849,you can go here to see all parts in machine
https://www.searspartsdirect.com/model-number/11080754001/0582/0152000.html?searchType=modelSearch&q=110.80754001&searchTerm=110.80754001
go here put model number in
Jan 25, 2018 | Kenmore Dryers
86983110 dryer kenmore
There is a moisture sensor in the unit that tells the timer to advance. IT is not working. This could be a control board issue or bad connection.
Jul 08, 2013 | Dryers
Hello. I'm looking for a part. I have a Kenmore Model 86983110 Clothes Dryer. I need the plastic part that covers the internal light. It's approximately 6" long by 1-3/4" wide and...
Hi dswooldridge...
www. partselect.com
1-888-895-1535
Sep 03, 2011 | Kenmore 800 6983 Electric Dryer
Kenmore model 417-how to get to fuses in control panel. 03 model
unplug remove the back and you will see one fuse on the left side of heater box,and the other on the blower box(white)
May 06, 2010 | Kenmore 73952 Gas Dryer
Kenmore dryer 417.84052500 needs a fuse. The manual says it has two house fuses. How do you access these fuses in this model??
the house fuses are in your house fuse box,did you check with a meter to see if you have power at the outlet?
Apr 18, 2010 | Kenmore 63942 Dryer
Dryer exhaust was packed full of lint now the dryer runs but does not heat
send model number?need to know if it's gas or electric?you can check the thermal fuse located on the blower wheel housing,if that's good check the thermostats on the heater box
Mar 19, 2010 | Kenmore Dryers
Front loading kenmore 86983110 makes loud noise when turned on. Think that there is a problem with the belt. I am tryng to take it apart now and do not know how to find the belt
The belt is located at the back of the appliance.
To remove belt you have to remove a panel at the back, on some model you remove top panel first.
The belt does not make loud noise. Loud noise when spinning is usually caused by bad drum bearing, located at the back of the drum.
Regards.
Jul 13, 2009 | Kenmore Dryers
Dryer won't heat
I know you said the fuse box is fine but check and see if you have 220 volts at the dryer cord we need to start there let me know what you find
bill
Jan 10, 2009 | Dryers
Kenmore Ultra Care Dryer- Electric
Your dryer doesnt have a fuse. Your home breaker panel is the only protection it has..Check your circuit breaker box for a tripped breaker.
Oct 22, 2008 | Kenmore 62602 Electric Dryer
Kenmore 84052 Dryer Logo
748 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
