Question about Casio FX-115MS Plus Calculator
I'm trying to calculate base number equation
For example:
I'm trying to work out 5 * 5 to the power of 3 - don't know how to write that properly with my computer. The problem is that the instructions aren't as clear as i'd hoped and it gives examples of Octal and hexadecimal calcuations, but none of the straight decimal variety
  • Casio Master
  • 8,064 Answers
You are victim of a confusion between terms. Base-n calculations are calculations using various numeration systems (bases) : binary (2), octal(8) hexadecimal (16) and decimal (10). What you want is how to calculate powers, logarithms, exponentials and these have also the notion of base; Log in base 10 is the common log, whereas natural logarithms, are logarithms in base e.
Back to your exemple: 5 times 5 and raise the whole to power 3?
In that case [(] 5 [x] 5 [)] [^] 3 or [X to the 3] if you have such key or
25 [^] 3, because 5x5 = 25
5 times (5 raised to power 3)
5[x] [( ] 5 [^] 3 [)] or 5 [^] 4 because of the rules about products of powers with the same base.
Hope it helps.
Posted on Sep 18, 2009
What causes a Syncmaster 2253LW monitor to start ok and immediately fade.
The monitor may be failing. Here's some tricks I would try...
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or orange or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
7. Also, you could try your monitor on a friend's computer. If it doesn't work, your monitor probably needs replaced. If it works properly on your friends computer, the problem may be with your computers video output port, motherboard video chip (or video card, if you have one), or drivers.
Good luck.
Aug 01, 2014 | Samsung SyncMaster 2253LW Monitor
Why going off after 5-10 min black screen
7. Also, you could try your display on a friend's computer. If it doesn't work, your monitor probably needs replaced. If it works properly on your friends computer, the problem may be with your computers video output port, motherboard video chip (or video card, if you have one), or drivers. Good luck.
Jul 04, 2014 | Gateway 24" Widescreen Flat Panel TFT LCD...
Benq t902hda
6. If the power light is on and yellow or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
Mar 11, 2014 | Computers & Internet
When i try to put anything with in prentice the prentice don't display
If you're referring to parenthesis, this is correct. They don't display. They merely alter the order of operations. For example, if you press
5 * 3 + 4 = the calculator will produce 16, which is (5*3)+4. If you press
5 * ( 3 + 4 = the calculator will produce 35, which is 5*(3+4).
Nov 12, 2012 | Texas Instruments BA-II Plus Calculator
Mercedes cd changer stuck
There may be a CD that did not completely return to its slot in the magazine, for example if power was turned off before the return was completed. Don't know how to fix it. You might power up and try a load-unload cycle to get back to normal.
Sep 12, 2012 | Blaupunkt IDC-A09 5-Disc CD Changer
My Dell AIO 924 printer will not feed paper.
1.Check inside the printer to see if you have the ink properly installed.
2.Make sure you don't you re-use papers that you have already used.
3.All papers have to be perfectly allined.
4.Check the connection wires between the computer and the printer.
5.Scan your computer with a security system to catch and eliminate viruses,tracking cookies etc.
If all else fails I don't know what to say
Jun 24, 2012 | Dell 924 All-in-One InkJet Printer
It wont turn on
It look that you have problems with the power supply. Try to remove the power cable, and the press the power button for 10 seconds. Then connect the power cable again and try to power up finally. If this doesn't work you should replace it with a working one, or take your pc desktop to a service center. Regards, MaTi_FleSh
Jul 02, 2011 | eMachines Desktop / AMD Athlon Processor /...
I am trying to get my cousins acer x1200 going he put a new hard drive in it because he thought his old one stopped working it wouldn?t boot up into window it would boot up until it got to windows then...
Error Stop 0x0000007B can be related to viruses,hardware failure or a device driver issue.
Lets try this :--
Step 1- Insert windows XP disk and try to get into recovery console.(Can follow instruction displayed on the
screen)
Step2 - Once you login to recovery console, run chkdsk /p followed by chkdsk /r.
Exit the command prompt after chkdsk /r completes and restart your computer and see if that works,.
Step 3 - If it doesnt, try running a repair installation with windows XP.
Step 4 - Insert the windows XP disk, press enter to continue setup followed by press R for repair.
Step 5 - Let repair installation complete and restart your machine to check status of your computer.
Hope it helps !
Thanks
Oct 06, 2009 | Acer Aspire X1200-B1601A PC Desktop
SCSI and IDE HDs, can they work together?
This next solution is viable in win 98, and I don?t see any reason why it shouldn?t work for you too. If you know of anything I?m missing you should consult someone else. The solution is slightly complex, so I hope I can explain it properly: 1. Create a startup disk so you can format and install windows. 2. Set the new HD as master and connect it to Primary IDE. 3. Disconnect the SCSI and remove it. 4. Restart the computer with the disk you created (with the new HD connected). 5. Go to the Bios settings in order to make sure that the computer does recognize the new HD as the primary drive in the first IDE. 6. Now, FDisk the new HD, set the partitions, restart and format it. Install the OS and make sure it is working properly. 7. Insert the SCSI and restart again. 8. At this stage the computer would reboot into the IDE and see the SCSI/ You may have to change something in the OS settings for that, but I don?t know where. Good luck.
Feb 22, 2006 | Adaptec SCSI 29160 POWERDOMAIN MAC KIT...
Casio FX-115MS Plus Calculator Logo
266 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Piyal Perera
Piyal Perera
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
