Question about Philips DVDR3440H DVD Recorder/HDD Recorder
Playback of dvds shows a predominatley blue tint to the screen
Got a philips dvdr 3440h dvd recorder and every time we play dvds the colour on the screen has a predominately blue/green tint to it. have i connected it up wrongly or do i need to do something else, or go into menu screen and do something? can anyone help?
  • 476 Answers
SOURCE: philips dvdr 3380/05
Go to www.p4c.philips.com
After setting you language/country options, enter the model number and search.
From the list select the model with your country code after the "/"
EG dvdr3380/05
Click on "User Manuals", then select the relevant file to download from the right hand window.
The manual can be downloded
Posted on Feb 16, 2008
jaffa012001
  • 376 Answers
SOURCE: philips dvdr 3320 v DVD Player Unlock region codes
In DVD mode, press System Menu
Go down to the "Lock " icon
While lock is highlighed press zero "0" for 7 times ( i.e 0,0,0,0,0,0,0)
There will be pop-up window that asks you confirm. Press "OK"
Posted on Aug 12, 2008
SOURCE: dvdr 3480/05 user manual
Try the philips website for the user manual.
Posted on Jan 04, 2009
mixelcores
  • 10 Answers
SOURCE: Code for remote control of
Also need to know what is the make and model of the universal remote you are using. Codes vary from one to the next.
If by chance your remote is Philips, the code for Philips DVDR's is one of the following:
0599, 0699, 1211
I have a Philips URC US2-PH5DSS and I use the code 0599 to control my Philips 3355 DVDR.
Posted on Jan 21, 2009
  • 4 Answers
SOURCE: Replace/Upgrade Hard Drive in Philips
email this person at krystle913@yahoo.com for a replacement hard drive for the philips DVDR3575H OR DVDR3575H/37
also can replace hard drive in the philips DVDR3455H OR DVDR3455H/37
Posted on Jan 24, 2009
Philips DVD recorder, records dvds but won't play them
possible playback head damaged
Please rate my help++++Thanks for using Fixya
May 29, 2010 | GPX D108S DVD Player
I can't play dvds but I can play copied dvds
Most copied DVD-Videos for home playback use a CSS crack to strip the region code i.e. to Region 0 to they will work in all DVD players.
However most standalone DVD Players can have this restriction lifted using a sequence of codes.
First check your current firmware version to see if you need to upgrade:
1. When TV shows Philips wallpaper, close disc tray with no disc.
2. Press <0>, <0>, <0>, <9>, <OK> on the Remote Control.
Note: In case the firmware version does not appear on the screen, eject and close the disc tray to reset, and try again.
In this case region is 2 (UK) and the firmware is “Feb 23 2007” this is the latest for this DVD VR.
There are other codes that can be used to set this DVD to region 0 it might be a good idea for you do to the same with yours.
Nov 22, 2009 | Philips DVDR3380/05 DVD Recorder
Which blank dvds work best with phillips dvd recorder 3440h?
dvd-r are more universal if you plan on giving the copy to somebody. they are more lickley to play on older dvd players. they are not rewriable though one time record. also do not purchase spindles the bottom of the stack usually gives you problems when finalizing
Jun 03, 2009 | Philips DVDR3440H DVD Recorder/HDD...
Can't play recorded DVD's(from philips 3505) on other dvd players
Hi I am Vortash It very much sounds like you are not finalizing your disks .. any dvd recorder that makes a disc from computer dvd's to free standing unit s work on the same software principle , however the programs do differ slightly and finalisation stanard izes the disc to run on any player, without it another recorder will either not recognize the disk or the language it is written in . Read that message at the end and you will see the option to finalize or it will say do you wish to be able to play this on another dvd or it will do it automatically if you set it to do so in the menu on some sets .
if your player isnt doing this it is not set to do so in the menu settings disks can be finalized at any time after recording providing they are not over filled as the finalization process will take up at least 10-12 mb some do it in more some might do it in less depending on the software hope this helps Regards vortash
May 17, 2009 | Philips DVDR3505/37 DVD Recorder
I have a dvdr3380 lately when i put in disc it says disc unrecord
Test the created DVD with TMPGEnc v4.0 Xpress here is the free trial link It has a read source function that will fail if the DVDR has not been authored correctly.
If this works and scans in the full DVDR then I suggested that you buy a branded DVD+R like Philips who created the format, if this still fails I think you DVDR 3380 will need a service.
LOL
Mar 15, 2009 | Philips DVDR3380/05 DVD Recorder
1}DVDR 3480 playback on many Dvds widescreen insteadof 4.3 as set. 2) my Vcr. has 3pin phono. Dvdr scart to Phono .Xt2 says nosignal. Phono tophono (cam socket) no signal .cannot copt tape to DVD. 3)B W...
1) The 4:3 / 16:9 option only optimises playback for that particular type of TV. The 4:3 setting also allows you to set the output between:
  • 4:3 PS - expands the picture vertically and horizontally which gets rid of the black bars, but you also lose the left and right edges of the picture.
  • 4:3 LB - Letterbox format, displays the full picture from the disc, with black bars top and bottom.
The PS option loses the bars on 16:9 widescreen DVDs, but may still leave bars on true cinema widescreen DVDs, which are 21.7:9
This is normal.
  • 16:9 - Optimises the picture for a widescreen TV. Again True cinema widescreen DVDs will still have black bars.
2) All of the external inputs will show "No signal" until there is actually a signal playing into them.
EG to copy VHS to DVD, you will need to select the relevant scart or phono input, and press play before the recorder will register a signal and allow recording.
Some bought VHS videos have copy protection, and may cause problems when copying to DVD.
3) Greenish playback maybe caused by colour setting on TV being too high. Also check Hue or Tint settings on the TV, if it has them.
4) For some reason, in their infinite wisdom, Philips omitted the Video Plus facility from this model.
Apr 28, 2008 | Televison & Video
Code required please
hello .
try this region codes for the region codes . for philips dvdr 3380.
riz.
Feb 09, 2008 | RCA DRC8295 DVD Recorder/VCR Combo
Can't record from hdd to recordable dvd
Had the same problem on my 6month old 3440H, its the degradation of the cheap Asatech Chinese DVD drive that is the source of the problem. . My 3440H HDD to DVD transfer sequentially degraded, It stopped recording DVD+ and -R's then on RW's it sometimes performed and some not.I gave up using cheap DVD's then with higher quality disks  it would frequently report task completed but then would not plaback or freeze in the way you describe. I bought the DVDR from the CO-OP Xmas 2006. Co-op no longer support electricals so when it went wrong Co-op gave me a service centre to take it to. Long story short Philips dont recognise the service centre and they declared my warrany void. Tried to re-engage with Philips but they basically were not interested in supporting their product..
Not an elegant fix but since Phillips were useless,  I opened the box nothing ....to lose ..I now run it on a bare external Sony DVD drive using extended ribbon and power cables as its a bit tricky to find space in the box to mount the drive.
Regards
Murray
Oct 13, 2007 | Philips DVDR3440H DVD Recorder/HDD...
Philips dvdr3480 picture problem
swap the scart inputs around. See if that solves it
Sep 02, 2007 | Toshiba DVD Recorder
Philips dvdr 3320v picture freezing
Be sure there is plenty of space around the DVD player. I place mine on top of the cabinet without anything on top if it. Being enclosed seem to affect some DVD players. Also, dust frequently...
Jan 09, 2007 | Philips DVDR3320 DVD Recorder/VCR
Philips DVDR3440H DVD Recorder/HDD Recorder Logo
164 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
