Question about Whirlpool GEW9250 Electric Dryer
I have a cable box called the box that has stooped receiving.
  • 3 Answers
Are you saying that your cable box won't let stuff show on your TV? Or do you have a problem with your Dryer? You should never mount a TV in the laundry room if there is a chance the TV could get wet, or that you could become fixated by the TV and never finish your laundry. I'm just saying...
Posted on Feb 25, 2009
After power surges have had 20 DCT6200 receivers that do not power up. Have replaced power supplies but only half the receivers work again. The other ones will not power up even after a new PS. Where is...
I think the transformer for the dct6200 is in the cable box... thats why there is no "box" on the power cord...
sadley that means the damage may be in the cable box and much harder to replace than if the transformer had been on the cord.
can you call the cable company and have them replace them?
Apr 11, 2011 | Arris DCT6200 DTV Receiver
I have the guide but no picture for 3 hours now. keeps telling me should get picture shortly ref s0a00?????
you lost your cable signal....
the guide is saved in the box, thats why you still see it
that temp off air message is also generated by your box because its not recieving anything from your cable provider.
make certain all cables from wall to cable box are tight then call your provider
good luck
Jan 18, 2011 | Arris DCT700 DTV Receiver
I am trying to setup my receiver with my TV and Comcast cable box using HDMI cables (TV-OUT and HDMI-1) but for some reason I don't get any sound from non-HD channels. Am I missing something?? I've read...
I'm thinking there might be a setting in the cable box that may be sending the wrong bit rate for PCM 2-channel audio but usually the receiver decodes that stuff fine. Just the same, I'd give Comcast a call.
I run the video from my cable box directly to the TV (HDMI) and the coaxial digital audio to my receiver so each one can do what it does best with the best possible un-modified source data.
Dec 25, 2010 | Sony STRDH810
Constant buzz from the speaker-- unit transmits but does not receive
Mine was doing this recently, i pulled it apart and found there was a small square box, about 5mm square with a plastic circle that can be turned by a screw driver, gently turn this until the unit stoops buzzing and receives.
BE CAREFUL! i was doing this to mine but i turned it too far out, it is not designed to be completely unscrewed, just adjusted slightly. (there is a coil on the inside and this snapped of the connecters below) i don't know what this pare is called but if somebody knows the name let me knowbongbosh@gmail.com
Oct 21, 2010 | Cobra LI6050-2WXVP Two Way Radio
TV will not communicate with DirecTV receiver. Tried rebooting, switching cables. Notification on TV reads that it cannot receive signal.
Ur Direct tv box have problems,call Direct tv customer service for sevice.U reboot the box,signal cables change right,same problems.The box is a rental,u have right to exchange for another one.
May 15, 2010 | InFocus ScreenPlay 61" Rear Projection...
Connecting cable to receiver
Do you mean 5 RCA audio outputs marked as FrontLeft, FrontRight, RearLeft, RearRight, Center? Unfortunately this receiver doesn't have discrete 5ch inputs (as yamaha calls it on its webpage).
But the cable box should have also digital audio SPDIF output - that is either optical (square connector) or coax (RCA usually orange). You can use this for connecting to receiver.
Mar 07, 2010 | Yamaha Rx-v365 A/V Home Theater Receiver
Picture sound blackout (blink) when cable box/receiver HDMI used
Onkyo service told me, the second timethat I called them, that there is a known HDMI handshake issue with Motorola and Atlanta Scientific cable boxes. The only solution, and it was a solution, is to connect the box through the HDMI 1 port ONLY. All the other (2,3,4) result in blinking/dropping of signal. I did this, changed the cable/satelilte setting to HDMI 1 and all is well.
Apr 12, 2009 | Onkyo TX-SR705 Receiver
I am tryingto hook up an older model receiver
does the receiver and the cable box have rca cable plugs on them if so try that first but leave the hdmi plugged in
Mar 16, 2009 | Technics Audio Players & Recorders
E 68 message on Receiver
Try emailing Motorola https://broadband.custhelp.com/cgi-bin/broadband.cfg/php/enduser/ask.php
Jun 09, 2007 | Arris DCT6200 DTV Receiver
Whirlpool GEW9250 Electric Dryer Logo
47 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
