Question about Amana ASD 2624 Side by Side Refrigerator
We have an Amana side by side that is only cold on the bottom in both the freezer and fridge. Also the top shelf of the fridge is hot from the light, which does not seem to go off when the door is shut. The freezer fan wasn't working, but when we took off the back panel, it started to kick in. When we put the panel back, it stopped working again. What do you think?
  • rickandsam Apr 20, 2010
    were is the evaporator coil???
  • 410 Answers
Amana runs power to the fan thru the defrost sensor that is mounted on the evaporator coil. these sensors will get moisture inside of them and short out causing intermittent fan operation. replace then sensor and your frig will return to normal. thanks for using FixYa peyton
Posted on Feb 18, 2009
Ice maker not working at all top part of freezer and fridge not cold
HI JAMES.well i would try to get them both working properly first.again defrost for 24 to 48 hours first and try.u might get lucky.ALI
Jun 30, 2013 | Amana 22.6 cu. ft. Side-By-Side...
Have the bootom freezer. what is happening is the freezer works and the top part quits cooling and the fan quits working. we took everythinhg out and transfered to the outside frig. we unplugged the...
if you can hear the fan still blowing but no cold air coming up to fridge section a common problem with bottom mount freezers is the door gets left open and the air ducts freeze up and the air can't blow up to the top.turn the control off in the freezer.remove the top shelf and the door,check to see if there are any screws one on each side of the slide arms,if there are remove them and lift the door up and out,with a hair dryer melt out the ice by blowing the hot air up each side of the back wall,also if the back inside wall of the freezer is covered with ice or like snow then you have a defrost problem but if there's no ice on back wall do what i said and blow the air up the sides of the back wall through the vents until no more water is seen dripping through the vent holes,then turn the freezer back on and check to see if you feel cold air blowing in through the vents in the fridge section,if you feel cold air then you're all set,if not keep blowing the hot air up the sides until it's melted out.let me know what you find,you'll know if the door was left open,ice will be on the ceiling near the light switch and sometimes on the top of the freezer door.
However if fan has quit totally then it will have to be replaced since it is responsible for cooling the upper part of the fridge
Dec 28, 2010 | Amana ABB1927DE Bottom Freezer...
No air blowing into fridge, although we can hear blower. Freezer is working
Oct 25, 2010 | Amana ABB1927DE Bottom Freezer...
Top shelf of freezer and ice maker not cold and top shelf of fridge not cold. everything else on bottom shelves is frozen and cold .GE model GSS22JEMA
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 17, 2010 | GE GSS22JEM Side by Side Refrigerator
The freezer side does not freeze on the top shelf. The refrigerator freezes everything in the bottom but reads 47 degrees and doesn't cool the top shelves. The fan under the fridge runs fine.
Behind the back wall of the freezer about halfway down, probably behind the light bulb (if there is one there) there is a fan. My guess is that the fan isn't working, or is slow. To test, open the freezer door, then hold the door switch closed and listen for the fan.
This fan should be blowing air up the back of the freezer, and send some of the cold air through a vent at the top of the freezer into the fridge. The air then descends through the fridge and reenters the freezer through a vent at the bottom. If the fan is broken, or if the upper vent is somehow blocked or broken, the cold air will enter (rather than exit) the fridge side at the bottom vent. Because cold air tends to descend and warm air rises, the cold air will freeze the stuff at the bottom of the fridge, and the thermostat (at the top of the fridge) will say it is warm.
Dec 04, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Items in frig freeze
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Here's a diagram of your fridge controls and parts.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5177055&diagram_id=1347585#d1347585
Oct 20, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Kitchen aid top shelf warm
  1. check gasket
  2. check the light switch on top of the refrig. section. If then pushed the switch turns the light off, but the light is still on with the fridge door closed - door needs adjustment.
Oct 13, 2009 | KitchenAid KSS48QM 48" Built-In...
Whirlpool side by side freezer not working fridge is fine
Pull out the fridge and unplug. Remove the back cover. Clean the condenser coils and fan. If they're difficult to get to, use compressed air to blow out. (you can get a can from walmart). That should fix the problem. If that doesn't work, then write back.
Doug
Jan 05, 2009 | Whirlpool GC5SHEXNS Side by Side...
Bottom of freezer/fridge only getting cold.
Thre is a fan inside the freezer which circulates the cold air around both the fridge and the freezer compartments.
You should be able to feel cold air blowing around the inside, particularly at the top of the freezer.
If the defrost thermostat fails open, the internal fan (depending on freezer) will stop and this can be the cause of the freezer being warm at the top and no ice.
You say the bottom of the freezer is blowing cold, but are you sure its blowing, as it can feel like a cold blow. Of course the fan could have failed or may be the defrost heater itself.
Have a look at this site for some useful trouble shooting
And a good site for troubleshooting and general info
Refrigeration Help Section, Fridges, refrigerators, not cold enough, frost free problems and how to test, noisy fan motors, clicking on and off compressors, door gaskets
Nige
Sep 26, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Amana side by side
call a technician, you need a freon recharge.
Jul 27, 2008 | Amana SXD524VW Side by Side Refrigerator
Amana ASD 2624 Side by Side Refrigerator Logo
222 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
