Question about Sharp 25N-S100 25" TV
Remote won't work and power switch pushed inside the television
My son turned on the television a while back and the power switch fell into the television. We didn't worry too much because we could still turn on the tv with the remote but a couple days ago the remote stopped working and now we cannot turn the tv on. We bought a jensen JR400 universal remote but to programme it you have to turn on the television. Can we programme the remote without turning on the tv? The codes on the manual for the sharp tv are 0093 & 0688. My tv is a sharp 25 " (25NS100) Can you help?
  • Anonymous Mar 01, 2009
    Same problem...my toddler pushed the button in and now I can't turn on the TV.
    Now ithe universal remote doesn't work either because the code has been reset and I haven't been able to reset because I have to turn the TV on and off to reprogram the television.
    Please help. I don't have the original remote and this is becoming a MAJOR problem.
    Habit-Forming:
  • 146 Answers
Follow instructions on new remote. use code suggested in remote info. use the manual set up procedure,one code ata timetill the tv comes on when you hit on button after each code entry.
Posted on May 15, 2017
    Master:
  • Sharp Master
  • 923 Answers
No, sorry, not from this distance. But if I were actually there, I would try to put the switch back where it belonged, IF it was not broken!
  • 1694 Answers
SOURCE: SYSTEMLINK 3 RCA UNIVERSAL REMOTE CODE 4 A MAGNOVOX TV
www.remotecodelist.com ......................................T.
Posted on Mar 28, 2008
Maanita
  • 1142 Answers
SOURCE: Universal Remote control code on Sharp 13H-M60
Try this
complete guide to your remote solution
Posted on May 20, 2008
pgh_pa_guy
  • 2992 Answers
SOURCE: the power button on the tv is broken and i lost the remote
You can just try programming the remote with the Sharp codes they list in the instructions until you find the one that works. Follow the procedure for entering a code and try it. When you find the right one it will turn the set on when you hit the power button. The remote's instructions tell you to turn the set on to make finding the code easier (when the set shuts off you know you found the right one), but you can work without it.
Posted on Apr 27, 2009
SOURCE: reprogramming my sharp 25k-s100 with universal remote
Try 173
Posted on May 07, 2009
  • 4090 Answers
SOURCE: i have a toshiba tv with a broken power button
Generally the power button has to be on first to put the TV in standby mode. If you cant do this no remote can ever work. Remotes are not capable of turning on a set that has no power mechanically turned off. and that is what the master switch does. once that standby light is off it is not live and consuming power and not under the control of a remote anymore
please rate our help++++Y=Thanks for using FIXYA
Posted on Sep 25, 2009
Tv won't turn on
Have you checked whether the power outlet is ok? Have you tried connecting the TV to another power outlet? If so, there is a defect inside and should be handled only by a qualified service technician.
Aug 13, 2012 | Sony KDL-52W5100 TV
Mitsubishi tv won't turn on
did you try new batteries in the remote? if the tv has buttons on the side and one of them being power di you try to push that? did you push tv power or cable power holding the buttons longer? those things might work.
Jun 05, 2012 | Mitsubishi WS-55909 55" Rear Projection...
I have a akai 61 inch dlp tv, my son turned it off went back 1 hour later tv would not come on with remote or by push button on front, checked to make sure power was in cord to back of tv, any ideas what...
I'm assuming that no lights are blinking on the front of the tv and the bulb is in god working order - it has been replaced recently. In that case the tv will have to be opened and the voltages on the power source tested, starting with the ones on the main switching transistor, followed by the ones on the output rails - a good voltmeter will have to be used. If all are there then check the voltage going to the
Jul 29, 2011 | Akai PT61DL34 Television
Television wont turn on
Goog day sir, We need to replace first the bad switch, need to unsolder it, find the replacement one and solder it back. You may need to open the back, remove the main board, and replace the bad switch. reassemble the tv and test. Sad to say this but you may do the repairs or hire a person to do it. check you remote batteries they may be almost dead. hope this helps let now your progress.
Aug 10, 2009 | Sharp 27J-S260 TV
Controls
the sensor for remote has fallen off its usually connected to a 8 inch wire which fell back into system pull the sensor wire forward the way to get into tv 3 ways front pannel pops off sensor is set at front
there the back of tv
then theres threw the
Mar 19, 2008 | Apex Digital GB5108 51" Rear Projection...
Won`t turn on
Try leaving it unplugged for longer period of time. Look on the remote for any possible reset function. Try power button without the remote. If any ot these doesn't work there is a power supply module inside that malfunctioned. If under warranty contact where you purchased it. If not under warranty if you can get the module it is a simple plug up procedure.
Dec 31, 2007 | LG 42LC7D-UB Television
Remote will not power tv on
Do the other remote functions work once the TV is powered on? If so you probably have a problem with the film switch inside the remote. If your really talented you can delaminate the film clean the switch with a pencil eraser and put it back together. If not very talented with tight work like that just get another remote.
Another possibility is that your remote is actually set to another function. Try pushing the TV button on the remote before pushing the on button.
Nov 28, 2007 | RCA T19408 19 in. TV/VCR Combo
Sharp 25N-S100 25" TV Logo
209 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
