Question about T-Mobile Sidekick® 3 Cellular Phone
Tmobile sidekick3 wont charge
Where the charger and the phone connect is loose or something. it has to be propped with something. but now it wont charge. how do i fix it and what is the parts called
    President:
  • 625 Answers
It's called the sidekick 3 charging port and they are known to go bad a lot.
You can check out cellulardr for the repair. It runs about 75 dollars or you can get a external battery charger cradel and charge the battery outside the phone.
Posted on Mar 02, 2009
Wont' stay on and wont' charge
If your telephone wont stay on and wont charge, then you need to carry out some test to know where the fault is from. First, test your battery if it is working by inserting it in another phone then charging it for about 3 hours then power on the phone to see if it will come on, if it does, then it means the battery is alright. But if it does not come on, then you know the battery is bad and needs to be replaced.
Now test the phone by inserting a well tested battery inside the phone then power it on, if it comes on, then the phone is alright, but if it does not come up, try to prop the battery so it will connect tightly with the terminal of the phone, then power it on, if it comes on, then it means the battery was loose and just need some propping, but if it still does not come on, then there is a problem with the phones power panel.
Test the charger also, by trying to charge another phone with it to see if it will work, if it charges, then it means the charger is alright and if it does not charge, then it means the charger is bad and need to be replaced.
After carying out these tests, you will be able to tell which component is faulty and needs replacement.
Take care and good luck
Dec 29, 2010 | Cell Phones
Nokia 6500 wont charge
Where you connect your charger there is a loose connection there,what i can tell you for your phone to stay alive is just buy an universal charger it is not expensive,you put your battery in then after charging replace it in your phone and the problem is solve .
Feb 09, 2010 | Nokia 6500 Classic Cellular Phone
My katana lx wont charge. It took awhile to connect and charge last time, but now nothing.
I am going to assume that when you say it took you a while to get it to charge last time, you had to wiggle the charger around and then get it in just the right spot to get the phone to charge, if this is the case there are only 2 solutions try another charger if that works you just have a bad charger, if that fails than something in the port on the phone is bent loose or broken and it will need to be repaired in your providers repair center, if u have insurance u might need to file a claim.
Dec 03, 2009 | Sanyo Katana LX Cell Phone
Rokr e8 won't charge
when the phone discharges completly, it can olny be charged via the charger that plugs into a wall outlet.
Aug 04, 2009 | Motorola Mobility ROKR E8 Cellular Phone
My enV will not charge!
Hey i think i just figured out the problem to all the port charging issues for the envy and envy 2 phones with verizon. its not the phones, its the charger cord! the part that goes into the phone. it gets pulled out over time from pulling the cord out of the phone all the time. get a pair of pliers. grab the end and push the metal end of the cord against somthing hard, push it back in so it is at the appropriate depth. this should make it charge properly again!
Jul 17, 2008 | LG enV VX9900 Cellular Phone
Sidekick3
had the same problem before...when i had firsst got the phone.
i just looked around the house for and cables that could plug in the outlets and that fit the sidekick 3 ...charger hole.
i know that a nokia charger that fits the sidekick charges it.
good luckk!! =)
Jun 20, 2008 | T-Mobile Sidekick® 3 Cellular Phone
My sidekick wont work
It seems your charger port is broken, it hapfens often on cellphones, wear and tear. Check to see if its under warranty, and it can be replaced. Check my profile if you need more help.
Jan 24, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Sidekick problem
It looks like it's a battery related problem . You should get a new battery. Good luck!
Dec 12, 2007 | T-Mobile Sidekick® 3 Cellular Phone
My problem is with the sidekick III, it wont charge, What should I Do?
dnt drain the batteries of your phones...if that happens pls buy multicharger or battery shock,remove the battery..... charge it for about 5min or shock the battery if ur using battery shock...be sure u positioned it ryt....den put it back on ur phone then charge it or continue the charging on the multicharger until its full !!!!im pretty sure of it....im encountering the same prob as urs before and thats what i did and it work!!!!
Jun 09, 2007 | T-Mobile Sidekick II
T-Mobile Sidekick® 3 Cellular Phone Logo
70 people viewed this question
Top T-Mobile Cell Phones Experts
Starnley Johnwells
Starnley Johnwells
Computer Repairing
Computer Repairing
Are you a T-Mobile Cell Phone Expert? Answer questions, earn points and help others
