Question about IBM SpaceSaver Keyboard
Old Keyboard on New Computer
My handy IBM SpaceSaver 2 keyboard (Part #28L3644) works well on my ThinkCentre M50 (Windows XP). But it's having trouble on my new ThinkCentre M58p (Windows Vista Business). I was able to use keystrokes (no trackpoint movements) to guide the new computer through its initial ("factory installation") startup, but then all response to the keyboard disappeared. I was able to shut down after I plugged in an Microsoft USB mouse independently.
What would help? Settings? Drivers? PS/2 to USB plug adapters? Magic pixie dust?
IBM spacesaver II windows 7 64
if you have a ps/2 connection and you love that type of kb than all means buy and use it,
Jan 23, 2014 | IBM SpaceSaver II Keyboard
Will IBM Spacesaver II Keyboard work windows 7 64?.
just plug in ps/2 and the plug will take control of the controller
and you would disable bluetooth or turn it off
go into control panel, look for device manager
go down to bluetooth right click and select disable or remove driver
reboot everything should run fine
Windows Natural MultiMedia Keyboard 1.0A not working with Win 7
you have to buy a new keyboard they have no update drivers at this point for win7
Jun 25, 2010 | Microsoft Natural Multimedia Keyboard &...
Need a driver for an old IBM keyboard for windows XP
Attach the device and see that it works or not.
If yes OK, if no, then visit the IBM's website and search for the product's drivers.
Mar 27, 2010 | IBM (1390131) Keyboard
Just got a new computer with Windows 7. Old one was running XP. It doesn't appear that there are drivers for the Kensington Wireless Keyboard 64355 on Windows 7. Any suggestions?
try and see if you can install the drivers in xp compatibility mode, if windows 7 even has that. vista did. a lot of drivers from xp didnt work on vista either. thats the sole reason i havent switched from xp to the new versions of windows. good luck and hope it will work for you
Jan 15, 2010 | Kensington Comfort Type Wireless Optical...
Dell SK-8115 USB keyboard on non Dell PC
This model keyboard has an internal USB hub and Windows only sees the hub when booting. The solution is to get a generic USB keyboard and boot into Windows. Once Windows has loaded the HID drivers for the sk-8115 keyboard then this Dell keyboard will work from then on.
Jan 16, 2009 | Dell Spacesaver USB Keyboard J4624 SK-8115...
I have an unused new Memorex Keyboard which is several years old The boz is marked TS 1000 Windows 95/98 My computer has Windows XP Will this keyboard work in my cmputer?
as long as it has a PS/2 plug or adapter you should be fine.
* a PS/2 plug is the small round keyboard and mouse connector
Dec 04, 2008 | Computers & Internet
Dell keyboard SK-8115
(That is the the Num Lock indicator, nothing to worry about.) If it is not working it is likely because USB keyboards can time some time to be recognized by windows, let the computer boot up with the keyboard connected and let sit for up to ten minutes.
Sometimes if other hardware is detected at the same time which requires drivers to be installed, windows will never proceed to installing your keyboard, however you cannot install the other drivers until you have a working keyboard. To solve this, you will need to use an older style PS/2 keyboard to get everything installed and working as they do not need to be detected.
Nov 11, 2008 | Dell Spacesaver USB Keyboard J4624 SK-8115...
The Keyboard not working, MS Wireless, laser, desktop 5000
i don't like the sound of you taking the hard drive out of a old computer and loading it in your new one without reinstalling windows especially with windows XP your choice i guess.
Did you try and couple the keyboard and receiver by pressing and holding the button on the keyboard for a while?
Dec 08, 2007 | Microsoft Wireless Laser Desktop 4000...
Keyboard problems.
1. Restart the PC. 2. Hit F12 key repeatedly as soon as the PC turns ON. This will bring up the Boot Menu. 3. Select DELL Diagnostics. 4. Select the Complete / Full from the list of options. 5. Let the tests run which may take about an hour. Make sure you are there in front of the PC for the first 10-15 minutes, because it would need your inputs. 6. This will test the keyboard and USB ports too. 7. This will also verify for you whether the keyboard works when Windows hasn't started. 8. If all the tests pass and your keyboard is still working after sometime, you have issues with Windows: Start you computer in Safe Mode and check the USB drivers and the keyboard drivers. 9. Now, if you continue having issues even when you are running the diagnostics, you need to check your hardware viz. keyboard (try installing another keyboard if you have one) and the USB port. PLEASE REVERT BACK WITH THE RESULTS. I WOULD LOVE TO HELP YOU FURTHER ON THIS, IF THE ISSUE CONTINUES.
Mar 08, 2007 | Dell Spacesaver USB Keyboard J4624 SK-8115...
IBM SpaceSaver Keyboard Logo
152 people viewed this question
Top IBM Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
