Question about Intermatic & Self-Adjusting Wall Switch Timer
Need instructions on how to set timer
I have an intermatic model 32C and I need to program the timer to come on and off. I do not have instructions to do this. Can you help? Thanks, Rebecca
  • MohinderSing Feb 24, 2009
    I need user manual for programming Noma Wall switch timer
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 86 Answers
Here's a link to Intermatic manuals on-line:
http://www.intermatic.com/Default.asp?action=cat&cid=91
Posted on Mar 01, 2009
Do not know how to open door of the intermatic wall time switch Do not know howto set timer--I want timer to go on at 7 PM and turn off at 7 AM
Question posted under ET104 timer.
This timer arrives with default voltage set for 240Volts.
Move voltage selector to select 120Volts as per instruction manual:
http://waterheatertimer.org/pdf/Intermatic-et104c.pdf
You can add a comment any time for more specific help with this timer.
1) If this is a plastic enclosure, then push inward to unlatch enclosure door.
See illustration: http://waterheatertimer.org/images/IMG_9431-Open-enclosure-400.jpg
2) Model number of timer and wiring diagram and programming appear on inside of timer door.
Add a comment with timer number if different from below.
3) How to program ET104 timer:
http://waterheatertimer.org/pdf/How-to-program-Intermatic-ET104-timer.pdf
-Read instructions.
-Set current time.
-Set program 1 for 7pm
-Set program 2 for 7am
-Not necessary to use programs 3 4 5 6 7 8
4) More resources
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#ET100
Sep 22, 2011 | Intermatic INC ET104CPD82 24 HOUR...
We've lost the instruction manual for our light switch timer so don't know how to reprogram it. Directions, please!! We've just replaced the battery.What buttons do we press in what order to...
Question posted under Intermatic timer:
Open following link to identify timer and download possible manual:
IF Intermatic timer stopped working because battery failed, then all that's needed is to reprogram current time, because the original timer programs you set are stored inside timer forever until timer is manually reset using reset button.
If you have Intermatic ST01C timer, then open following page for ez instructions:
http://waterheatertimer.org/ST01C-program.html
If you need help programming specific timer, then get as far along in manual as possible, and then add a comment.
If you have different brand timer, than each brand has link that shows on Intermatic page.
Aug 10, 2011 | Intermatic Hardware & Accessories
I had a timer model EJ341C many years ago, it was broken down. I went a store and the salesman said the new model EJ351C is the substitute. My questions to you is (1) Are these two models pretty much the...
Hi Henry,
Intermatic EJ351 is sold today to replace earlier models.
EJ351 is very popular 24-hour ez-set timer with simple wiring.
http://www.intermatic.com/products/timers/consumer%20indoor%20timers/in-wall%20timers.aspx
Instruction manual:
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/ej351c%20-%20english.ashx
Connect wires inside box to either timer wire.
Red indicator light is helpful when setting timer program.
Add a comment if instructions are confusing, and say what part of manual does not make sense.
Apr 19, 2011 | Intermatic Inc. ST01C Digital In-Wall...
I have an ET104CP and cannot read the instructions, therefore I need an instruction manual or the step to program one-(1) event both on and off.
Thank you for including model number of product.
-One confusing part of ET104CP 24-hour timer is that event1 is ON and event2 is OFF and event3 is ON, and event4 is OFF etc.
-Another confusing part is that on-line manual says: "Refer to programming instructions on time switch door."
-So if timer door has gotten wet or paper has aged, then key instructions are missing unless you have new timer in front of you.
-Last confusing part can be selector switches.
To program timer, selectors are set to Manual and RUN
To operate timer programs, selectors are set to AUTO and RUN
1) Manual for product appears below:
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/et104c%20-%20english.ashx
2) According to manual, you put timer in Manual and RUN and then press and hold reset button, and then event1 will display.
Guessing at this point, press hour and minute button to set event1 ON
Press event button again to display event2, and then press hour and minute
Make sure events do not conflict with each other or timer will not operate
3) If instructions in #2 above are not correct, then add a comment and write out what is printed on your timer door, I can work alongside you to help decipher
4) If timer instructions on door panel have gotten wet and are unreadable, then contact Intermatic directly.
http://www.intermatic.com/customer%20service.aspx
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 15, 2011 | Intermatic INC ET104CPD82 24 HOUR...
Need a copy of manual
You can get the manual on the link below.
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/et8215c%20-%20english.ashx
Good Luck please rate 4 thumbs up and please leave a testimonial
Oct 25, 2010 | Intermatic ET8215C- 7-Day Electronic...
I have digital programmable timers (Model DT121 and Model DT11) that will accept programs, but won't turn the attached lamps on and off at the programed times. The batterys are new and I've had them...
DT121 Manual
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/dt121c%20-%20english.ashx
All Intermatic manuals
http://www.intermatic.com/customer%20service/instruction%20manuals.aspx
Intermatic does not show DT11
Intermatic shows the DT121 is no longer available
If the display shows and you can set programs, then the battery is good.
Does the manual override work? This indicates whether the timer on-off switch operates.
If manual override does not work, then I discovered that timers are no longer any good
Programming:
Set present time
Then set ON time for program 1
Set OFF time for program 1
Then set ON time for program 2
Set OFF time for program 2
Most timers will not function if there is a conflict in programming > for example Program 1 says ON at 6 and OFF at 7 and Program 2 says opposite or has overlapping times
When events are set, press SET once > this will put timer in RUN mode
If manual override works, and you set programming correctly, but timer does not carry out instructions, I guess the timer is no good.
Intermatic has 24 hour timers with 2 on-off per day
http://www.intermatic.com/products/timers/consumer%20indoor%20timers/lamp%20%20appliance%20timers.aspx
Intermatic has 7-day digital timers (all digital timers today are 7 day where you select the day that each program works)
http://www.intermatic.com/products/timers/consumer%20indoor%20timers/digital%20timers.aspx
Oct 12, 2010 | Intermatic Hardware & Accessories
Need instructions to program Intermatic Model #E140C wall switch timer.
Do you mean Intermatic E104C box-type timer? Intermatic does not make E140C
Manual says "refer to programming instructions on time switch door"
Manual says timer has 8 events per 24-hour day ... 4 'on' events and 4 'off' events. Normal operations, selectors are set to AUTO and RUN.
Using sketchy info from manual about programming:
Set sliders to MANUAL & TIME/SET
Press EVENT for event 1 ... set hour and minute using HOUR & MIN buttons ... this will be 'on' time
Press EVENT for event 2 ... set hour and minute ... this will be 'off' time
Set all 8 events ... 4 'on' and 4 'off'
Move sliders to AUTO & RUN for timer operation
Sep 15, 2010 | Hardware & Accessories
Lost setting instructions for Intermatic timer model: HB800RCL. Need help..
I have located a site which has the instructions for your timer.
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/hb800r.ashx
I located this while searching for an image of your model timer
Jan 30, 2010 | Intermatic & Indoor/Outdoor Rain Tight...
Intermatic & Self-Adjusting Wall Switch Timer  Logo
729 people viewed this question
Top Intermatic Hardware & Accessories Experts
Craig Butler
Craig Butler
Gene Haynes
Jay Finke
Jay Finke
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
