I am looking for information on or an Owner's Manual for Mod. 110 29962 891 Ser CJ3708533 Type 111 - I can't understand the water temperature settings - goes from ice cold to boiling hot but seldom on combination to provide warm water.
  • 640 Answers
Sorry i fond no automatic temperature control for this unit..bot with this unit it makes the temp,,for you ,,but doewn load the mantal from,,searspartsdirect.com onthejob
Posted on Feb 17, 2009
The water pump
Any possibility the unit froze this past winter? They do have to be winterized.
May 05, 2010 | Honda Karcher G2400HH-R Pressure Washer
Want an owner manual for an old Kenmore 70 series washing machine havy duty super capacity plus mod. # 110 22722101 ser. # CL4432583
Go to managemylife.com and type in the model number you provided under the "Manuals" link. Your owner's manual is listed in a .pdf (Adobe) format that you can download or print for FREE. I hope this helps you.
Mar 07, 2010 | Kenmore Washing Machines
Model 238322100 ser cm4768086 type 111
Check the following.
1. Clogged drain line or water pump
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
Jun 22, 2009 | Kenmore Washing Machines
Kenmore washer wontt spin or empty. i laid machine on its side
Adjust the motor mount so the pulleys are aligned.
Brute force may be necessary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Apr 10, 2009 | Kenmore 24032\24036 Top Load Washer
All funcions of the washer work except the drain at the end
is your drain hose kinked near the back of the washer. try to look behind the washer without moving it. if the hose is not kinked its probably the pump..
Feb 03, 2009 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
102 people viewed this question
Top Washing Machines Experts
