Question about Canon imageRUNNER C3200 Copier
Minolta ep4000 sorter bin is stuck. code is
Minolta ep4000 sorter bin is stuck. code is C0b63. can you help
How to solve cob60 error in minolita 3000
Posted on Mar 02, 2009
It says error code C0b63 what does it mean
All Cob codes on this series of Minolta copiers pertain to the sorter. Most all of the time you can simply open and close the sorter to reset the code. By open and then close I mean that the sorter must be pulled away from the copier then closed back.
Make sure there is nothing interfering with the movement of the sorter bins.
If opening/closing does not reset the code or if the code comes right back after resetting then the sorter will need service as dis-assembly/repair/re-assembly will be required. You can also unplug the large connector going from the sorter to the machine and use the copier without the sorter. If you have a 10 bin sorter that "hangs" from the side of the machine then you can leave the sorter attached and it will work fine unplugged. If you have the 20 bin sorter that sits on the floor then the sorter will have to be moved away from the copier if unplugged to prevent the machine from jamming. If you unplug the sorter be sure to turn the copiers power off before disconnecting the sorter.
Good Luck and Thank You for using Fixya.
WheatlandService
Nov 11, 2010 | Minolta EP4000/5000 CS/PRO Copier
I ahve an error code c0b63
It is on sorter stapler error.Disconnect the sorter unit and is OK.
May 24, 2010 | Minolta EP4000/5000 CS/PRO Copier
Guest Konica CSPro-EP4000 Error code is COB63
All COB codes no matter the number are sorter error codes. You must open then close the sorter in order to clear this code. By opening and closing I mean you need to pull the sorter away from the copier then close it back.
Apr 29, 2010 | Minolta EP4000/5000 CS/PRO Copier
What does this code mean COB63 or C0B63?
Sorter error code. Almost always this code will reset. You must pull the sorter away from the copier then close it back to reset this code. The normal open/close the front door will not work.
The stipler and sorter does not work can u give me the solution?
I can not give you a solution if you can not tell me which sorter you have. I asked wether you had a 10 bin sorter or 20 bin sorter. See previous question.
Jan 10, 2010 | Minolta EP4000/5000 CS/PRO Copier
Minolta Copier's sorter bin won't close properly.
This 20 bin sorter uses an interlock switch and actuator to show that the sorter is properly attached to the machine. Pull the sorter away from the machine and look at the rear side of the copier that faces the sorter. There should be what looks like a spike mounted to the copier. That spike goes into a hole in the sorter which then actuals the switch. Make sure the spike is not broken or loose. Make sure the tray that the sorter sits on is not bent. Correct any issues with these 2 and you should be good to go.
Jan 07, 2010 | Minolta EP4000/5000 CS/PRO Copier
Minolta EP 5000 error code c0b63
Hello sir; that code means sortr bins problem, I belived when you moved hit somewhere soter bin out of track( not line up).
Mar 22, 2009 | Minolta EP4000/5000 CS/PRO Copier
Minolta EP4000 Error C0b62
Hello sir;that's sorter bin problem, check the sorter bins see anyone out of track not move otherwise shift motor defect.
Jan 08, 2009 | Minolta EP4000/5000 CS/PRO Copier
Error code C0B63
All C0b** codes are related to the sorter. A C0b63 is a malfunction of the bin lower limit position sensor PC2. Most likely it is a broken bin.
Nov 19, 2008 | Minolta EP4000/5000 CS/PRO Copier
MINOLTA EP5000 CS/PRO
Code COb31 means that the sorter didn't reset after a job. If you try doing a reset by opening the sorter as if there was a paper jam and it doesn't reset, it means that you have a problem with the sensors by the motor that turns the bins to open and clause as the paper passes. Give it a good blow with air. GOOD LUCK.
Nov 05, 2008 | Minolta EP4000/5000 CS/PRO Copier
Canon imageRUNNER C3200 Copier Logo
83 people viewed this question
old marine
old marine
