Question about Cuisinart CBK-200 Bread Maker
The machine stops kneading in the middle of the program
I've had my Cuisinart bread maker for over a year, it worked GREAT until a few days ago. Now it stops kneading after 5 minutes into the program, but the program itself goes on (the arrow is still on "Knead", the time keeps ticking down and the mix-ins function beeps after a while, as if everything was working fine).
I've found that the program resumes when I press the pause button and then start again, but I have to keep my ear out and make sure the machine hasn't stopped kneading again...
  • idupuisi Feb 17, 2009
    I meant "I've found that the KNEADING resumes when I press the pause button and
    then start again"... Otherwise the program keeps running without kneading.
  • Anonymous May 21, 2009
    I have the same problem. Stops in the kneeding cycle after about 5 minutes or so, and will resume when I press the pause and start buttons.
    Problem Solver:
  • 18 Answers
Even Replacement May Not Help for Long.
After my six month old CBK200 had the same stop and start malfunction I was sent a brand new replacement by the company. Three months later the new unit started doing the same thing. I am putting up with it for now, but as soon as I have a little more time, I will go back to the authorized repair depot and request another replacement and hope for the best.
Posted on Aug 17, 2009
2 Suggested Answers
  • 1739 Answers
SOURCE: My Toastmaster TBR2 bread machine does not knead
Make sure you are programming your machine correctly.
The Instruction Manual indicates three possible problems, none of which would seem to be your problem. Not plugged in, error message or kneading blade missing.
Suggest you review the Instruction Manual for programming your bread maker. Unplug your machine to reset and then plug in and program as directed.
TRB2 Instruction Manual:
http://dl.owneriq.net/4/4ae504be-4834-4845-a8f8-7a6df62c1033.pdf
Posted on Mar 01, 2011
Cuisinart bread oven menu will not change
Plug your machine in and push the menu button again and again are the numbers changing from program to program? If not push the start/stop button with no ingredients in it and if it starts kneading wait a few seconds then push the start/stop button again UNTIL IT BEEPS AND STOPS. Unplug the machine and plug it in again and the program 1 should show again, just push the Menu button until you see the number 9 program. Did that work?
Dec 21, 2012 | Cuisinart CBK-100 2-lb. Bread Maker with...
Bread maker won't mix, it just clicks. I removed two screws on the bottom to see if the belt had slipped off. it was fine so I called Cuisinart to see if they could help. They said removing even one...
Some bread machines warm up before the kneading process begins especially on whole wheat cycles. If your machine hasn't started kneading after about 1/2 hour then you do have a problem but, give it time before you give up on it....
Aug 24, 2011 | Cuisinart CBK-200 Bread Maker
Our bread maker doesn't heat at all, it will make the bread then just turns off. We've had it for about a year, we've made 10 loafs, maybe. Those were some expensive loafs of bread :( Any...
Contact customerservice@cuisinart.com for a service center near you.
Otherwise, try to reboot your breadmaker's computer by plugging it in then pressing and holding the Stop/Pause button down for at least 3 seconds.
Hope this helped. ;)
Jun 10, 2011 | Cuisinart CBK-200 Bread Maker
Clicking noise when on the knead cycle and the kneading paddle doesn't turn at all. I have only had the machine for 1 year and no longer have any receipts.
I am having the same problem. I just purchased my machine last week. I made regular white bread last week and it worked great, but today I tried to make whole wheat bread and it froze. Any solutions for this?
Jan 19, 2011 | Cuisinart CBK-200 Bread Maker
I put all ingredients in the machine and turn it on it shows 5.00 but nothing else it's not warming or kneading or anything. Please let me know what's the problem
push the "stop" button until it beeps..........then unplug your machine....then plug it back in...... and push the select button again and again until the program you want appears in the read out then push "start" your paddle should start kneading slowly unless you choose whole wheat, then it might take about 1/2 hour until it starts kneading.... If you choose program 1 or basic it should start kneading right away.... please let me know if this works....
Oct 25, 2010 | Panasonic SD-YD205 Bread Maker
Used the breadman successfully 6 days ago. today; nothing happens. Window states "knead" but nothing happens at all.
Are you making a different kind of bread than you did the first time?. If so some machine programs have a delay before they start kneading such as the whole wheat cycle. Also some machines delay the kneading process while they warm up the ingredients. If it is colder where you live now than itw was 6 days ago that could be a factor.
Oct 12, 2010 | Breadman TR845 Bread Maker
I bought my Cuisinart Bread Maker in February 2007 and it worked well until now. Yesterday I started to make Dough cycle. First 2 minutes machine kneaded the dough correctly as usual but suddenly...
check the underside of the basket. I have had problems with the lock washer, causing the wing nut to slip and not providing any turn to the shaft and paddle.
Sep 22, 2010 | Cuisinart CBK-200 Bread Maker
The Cuisinart CBK-200C stopped in the middle of a dough cycle
Please check your shaft and bushing on the bottom of your bread pan . What is happening is the bushing is dirty and binding , your drive motor is heating and resetting or stopping , I just fixed this by pulling out the shaft and lubricating it with loive oil . It works so good now , better than new !
Jul 22, 2007 | Cuisinart CBK-200 Bread Maker
Cuisinart CBK-200 Bread Maker Logo
547 people viewed this question
Top Cuisinart Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dale Anderson
Dale Anderson
Level 1 Expert
Tom Chichester
Are you a Cuisinart Kitchen Appliances - Other Expert? Answer questions, earn points and help others
