Question about Brother IntelliFAX 5750e Laser Fax
My Brother Intellifax 5750 was just purchased November 2007, and it is making a horrible clicking noise when faxes come in or I fill the paper tray. I changed the imaging drum, but that didn't do anything. It clicks like the rollers are trying to spin but can't.
  • Anonymous Mar 17, 2009
    so what should I check first?
    Problem Solver:
  • 10 Answers
Could be a gear on the toner cart or some type of debris in the fuser
Posted on Mar 17, 2009
Why is my Brother Intellifax 4100e error says check paper size?
your paper error message means you probably received a document that wasn't the size of paper in the paper tray ,try legal sized paper,to dump the job stuck in your faxes memory ,this
problem happens a lot, theres reall nothing wrong with the fax/printer
Aug 13, 2014 | Brother IntelliFax-4100e Fax
My brother faz 5750 e keeps coming up with a offline open cover I do that and it does not fix the problem HELP
Was there a paper jam or something happen just prior to the code? Was it moved bumped or dropped?
Make sure all your doors have the acuator fingers still prtruding, one may be broken and not closing the safety interlock.
Let me knw
Jan 09, 2011 | Brother IntelliFAX 5750e Laser Fax
When I go to print or copy the machine makes a loud clicking noise and then says paper jam. Brother MFC - 8460 N
The loud clicking noise is either the toner cartridge or the paper feed. If the jam occurs in the drum and toner cartridge then I recommend changing the toner.
If the paper is not being fed at all then you need to have the paper feed kit replaced.
Thanks,
Pat
May 11, 2010 | Brother IntelliFax-2820 Laser Fax
Just replaced drum unit in our brother 4750e intellifax, now makes horrible squealing sound when printing. Ideas how to fix?
the drum is not set good please remove the drum and install it again something you do wrong.
Check do the drum is`set good.
Jul 15, 2009 | Brother IntelliFAX 4750 Plain Paper Laser...
PAPER JAM
If you pull the drum out of the machine. Close front cover. is the noise still there. If it is then you have a broken fuser gear. If noise is not there remove the toner cart. from drum reinstall the drum unit in machine see if noise is there. if noise is there then it will be the drum. If not reinstall the toner try that if noise comes back then it is your toner cart.
Apr 11, 2009 | Brother IntelliFAX 4100 Laser Fax
My brother intellifax 5750 has a paper jam and it wont clear.
make sure no paper is in unit then turn off and unplug for 5 minutes then plug back in and turn on
Mar 06, 2009 | Brother IntelliFAX 5750e Laser Fax
Brother 4100 intellifax
Check the blue tab on the inside of paper tray and make sure it is on correct paper size.
Fax machine is very sensitive so try not to put too much paper in it.
Jul 01, 2008 | Brother IntelliFAX 4100 Laser Fax
Outgoing fax makes loud clicking noise
2 different problems here. 1st is with document feed and 2 is with paper feed.
1st prob seems to be with the paper feed roller not meshing at the gear. Probably a broken piece on the lower document tray assembly. No real fix for this unless you can strip it out and haywire it.
2nd prob is probably a poorly meshing drum unit. Examine the gear teeth on both the drum and the machine. As you have replaced the drum already (presumably with a brand new one) You might possibly find a missing or badly worn tooth on the messhing gear in the machine.
Oct 02, 2007 | Brother IntelliFAX 2800 Laser Fax
Brother Intellifax 1270e
Make sure ribbon is installed correctly. Also check inside the tray area to see if the rubber roller and or the rubber separator pad is dislodged. Obviously not worth repairing unless under warranty.
Jul 09, 2007 | Brother IntelliFAX 1270E Plain Paper Fax
Brother IntelliFAX 5750e Laser Fax Logo
114 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
