Question about HP PSC 2210 All-In-One InkJet Printer
I don't know how to open the machine to remove print cartridges
Machine message is to remove/check both the print cartridges.
What printer do u have?
Posted on Feb 17, 2009
Error B200
Get steps to Fix Canon Printer Error Code B200 instantly. Watch below video to learn how to fix Error Code B200 on PIXMA Printer Call now +44-8000465291 for instant Printer help.
For 4+ Cartridge Printers:
Step1:-Remove All Printer Cartridges.
Do remove the individual ink cartridges from your printer. This will be opening the lid of your printer and waiting for the cartridge cradle to be placed in the correct position.
Step2:-Remove the Print-head.
This is can be done by lifting the orange or gray locking lever on the side of the cartridge cradle and then gently lifting the print-head from the printer.
Get full Step by click below link
How to Fix Error Code B200 on Canon PIXMA Printers 44 8000465291
Feb 01, 2016 | Office Equipment & Supplies
Black cartridge error
First, check to see that a toner cartridge is in fact installed.
Open the toner access panel and remove the cartridge.
Check to see if it is indicating that it is empty. If so, replace the toner cartridge and wait for the error message to clear as the machine prepares the new cartridge for printing.
Dec 20, 2012 | Lexmark X4650 InkJet Printer
C4480 74xl
>Remove print cartridges, >Switch off the machine..>Remove power socket>Wait 10 to 15 mts, >Clean the cartridge & printer contacts. >Switch on the machine wait till message appears for the cartridges>Insert mono cartridge close the access door, check for the message>Insert color cartridge close the access door, check for the message> no error message.. diagnoses end> any error during the cartridge loading replace particular cartridge
Dec 27, 2011 | HP Photosmart C4480 All-In-One InkJet...
I have to get a letter typed and don't know how to open the machine to change the ink????
  1. Open the cartridge access door. Figure 4: Open the cartridge access doorc00127636.gif
  2. Raise the cartridge latches for both cartridges. Figure 5: Raise cartridge latchesc00127637.gif
  3. Remove the protective tape from the end of the cartridges. Figure 6: Remove tapec00127639.gif
  4. Insert the cartridges into the carriage. Figure 7: Insert cartridgec00127642.gif
  5. Close the latches, and then close the cartridge access door. Figure 8: Close latchc00127644.gif The control panel displays a message prompting you to align the cartridges.
  6. Press the Enter button to start the cartridge alignment. Wait until the alignment completes before continuing.
Jun 24, 2011 | HP PSC 750 All-In-One InkJet Printer
It wont print,it says it's out of alignment
If these are new cartridges Please try the old cartridge and see if you get the same problem
If you don't then the new cartridge is defective and should be returned and exchanged for another
If it does give you the same problem please try the following
Remove all the ink cartridges from the machine
Then clean the contacts on the cartridges as well as inside the machine itself
Do this with a small amount of warm water on a cotton swab until no ink comes off on the swab
If any of the other cartridges are low, empty, leaking or bulging replace them
Then turn off the machine and unplug it for 70 seconds
Plug it back it and wait for the insert cartridges message
Insert the cartridges and check to see if the problem is still there
If it is it means the print head has failed
In order to fix this the print head inside the printer needs to be replaced
The print head is the part of the printer that puts ink from the cartridges onto the page
Unfortunately this can sometimes cost more to replace then the machine itself
The print head has seperate nozzles for each cartridge so it can print black for example and the color print blank even if the print head has failed.
It also works the same way with the detection of the cartridges.
May be you also need to find "Alignment" procedure button in driver properties and carefully follow the on-screen instructions.
Apr 18, 2011 | Lexmark X5495 Printer
I am getting the following error message: "0x07d54dd6 2005: lib_barracu". How do I fix it?
Can you turn the machine on and lift the print-carriage access door, this should (hopefully bring the cartridges to the right side where you can remove them) If this is possible, remove the cartridges and then turn the unit off, if the cartridges stay in the same location where you can access them then place the cartridges back into slots and turn the printer back on.
If the cartridges are not accessable then turn the printer on and open the print-carriage door, and insert cartridges.
Please let me know! Thanks!
regards Abhilash
Sep 20, 2010 | Office Equipment & Supplies
How open in laser toner catridge make-xerox model-phaser 3100
Replace the toner: Always use the smart card provided with the new Print Cartridge when replacing the cartridge. The smart card contains the information necessary to reset the level of Toner. Replacing the cartridge without using the smart card may result in the consumable management system being inaccurate.
  1. Insert the smart card provided with the new Print Cartridge into the smart card reader. A "Change Toner?" message will be displayed.
  2. Press the [OK] button. An "Open Front Cover Replace Toner" message will be displayed.
  3. Push on the left and right side of the Front Cover and simultaneously lower the cover.
  4. Grasp the handle on the Print Cartridge, and then raise and remove the cartridge from the machine.
  5. Unpack the new cartridge, and then insert the cartridge into the machine.
  6. Close the Front Cover. A "Have You Changed the Toner?" message will be displayed.
  7. Press the [OK] button. A "Please Wait" message will be displayed while the machine reads the smart card, and then a "New Toner Remove Card" message will be displayed.
  8. Remove the smart card from the reader and dispose of the card as normal office waste.
    NOTE: If the smart card has been used with a previous installation of a Print Cartridge, a "Remove Card Already Used" message will be displayed. The smart card can only be used once. Make sure to use the card that came with the new cartridge.
Aug 30, 2010 | Office Equipment & Supplies
Phaser 4510 replace toner message won't print until new toner installed - new toner installed and still has the replace toner message
  • This product can be configured to use a metered or non-metered Toner / Print Cartridge. A non-metered machine requires a non-metered cartridge be installed to operate, while a metered machine can accept both a metered or non-metered cartridge to operate.
  • Make sure the correct cartridge is used for the machine. If you are receiving metered print cartridges but the machine will not accept them, contact your reseller or supplier to ensure that your machine is properly set up as a metered machine, and that the metered PIN has been entered
  • Make sure you don´t have any stickers on the toner box.
  • If you sure all paper and stickers are out then reset the nvm values from the device in order to reset the printer information.
Aug 27, 2010 | Xerox - PRINTERS - PHASER 4510 (N) LASERPR...
Replace toner cartridge message still on after replacing
lets start with the easiest and work our way up.
1, If you haven't already, remove the replaced cartridges, MAKE SURE the doors that open when the cartridge are inserted are closed, use a cloth to cover the doors and shake the cartridges. Make sure there is no tape or seal on the openings. Re install those cartridges with the machine powered OFF, reinstall them with the power off, then power the machine back on forcing it to initialize and look at the cartridges fresh.
2. Clean the machine internally with a soft cloth, or if you have a very well filtered vacuum with hoses, vacuum the interior of the machine, carefully. Some ink may have spilled on some sensors.
Please, when you remove and shake the cartridges to be certain the small door is closed and you have them covered so you don;t make a mess.
3. If needed look for a dealer service provider in your area and place a call. Dealer service is much less expensive then Xerox direct.
Let me know if this helps.
You can also go to and click on support and drivers, in the search box, enter phaser 780, then click on support data base and enter replace toner and follow the steps there.
Hope this works. And Cheer up, take care.
Feb 19, 2008 | Xerox Phaser 780 Laser Printer
"printer error - check paper" after cartridge replacement
First remove all paper from fax machine and unplug fax machine from the wall socket for 12 seconds then replug fax machine into wall socket replace paper and try printing
Oct 03, 2007 | Sharp UX B700 Plain Paper Inkjet Fax
HP PSC 2210 All-In-One InkJet Printer Logo
22 people viewed this question
Ben Johnson
