Question about Jacuzzi Cyget In Ground Pool Pumps
One out of 5 jacuzzi outlet works with force, the other do not even when the air flow is totally open.
  • Rod Kidman
    Rod Kidman May 11, 2010
    did it ever work? sounds like there is not enough water flow to get the the last jet.
  • 125 Answers
Try turning off the 5 previous jets in order to see if there is enough water flow to get to the last jet.
Posted on Feb 24, 2009
How is the best and faster way to remove the air of inflatable jacuzzi
Check Amazon for inflator/deflator pumps. You might have to block the inflation nozzle open to get a full flow.
Aug 29, 2017 | Jacuzzi Home
How to adjust air flow on jacuzzi vectra II
Yes you can, there should be air induction knobs: Adjusts air flow from off to maximum.
Turn it down.
It looks like this...
Jun 15, 2014 | Jacuzzi Pool & Spa
I would like to know the noise level of a jacuzzi magnum pump 1.00 hp in decibels.
This is not possible as it completely depends on the amount of total dynamic head the pump is connected to as well as the voltage level that is being applied.
Mar 29, 2011 | JACUZZI MAGNUM FORCE POOL PUMP TWO SPEED...
My tub does not want to stay running when i press the button, you have to hold the button down for it to work
the buttons on most of the tubes are pressurized air when u push it sounds like a bad button or hose it could even be the little air sylenoid that clicks on and of when the air is forced against it when u press the button 1st check the hoses for leaks 2nd remove hose and verify the button works
Jan 14, 2011 | Whirlpool Jacuzzi Jacuzzi Bath Fuzion EF50...
My bathtub jacuzzi wont work. I reset the circuit breakers but nothing. I filled the tub but nothing comes out of the jets
make sure you have power to outlet that motor is plugged into,if so try pushing jet button in tub about ten times in a row quickly then on tenth push use as much force as possible and hold.if this does not work,air hose from back of button to pump motor may be disconnected.
Sep 30, 2009 | Maax URBAN 6032 HYDROFEEL AEROFEEL BATHTUB...
Jacuzzi Magnum Force Pump not working
The number one problem is air leaks.......check all connections to see that they are tight, and rubber seals. The intake side would give you trouble with air leaks. If you dont find any leaks then I would pull the pump cover and check the impellor. Pool stores have parts and lots of knowledge.
Jun 09, 2009 | Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED...
"Jacuzzi j-400 series" hot tub- F1 code flashes on control panel
Your circulation pump isn't working you should see the flow awitch closing if you have the visible model and hear the pump running.. If its the smaller circulation pump model it needs replacing
May 18, 2009 | Jacuzzi Bath Nova H530 917 Black Soaking...
GE toploader Washing Machine pumping problems
Sounds like the water is syphoning away due to the drain outlet hose being too low..Raise the hose higher, and this should solve the poroblem.
Oct 31, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
Jacuzzi Cyget In Ground Pool Pumps Logo
221 people viewed this question
Top Jacuzzi Pool & Spa Experts
Jay Finke
Jay Finke
Mike
john h
Are you a Jacuzzi Pool and Spa Expert? Answer questions, earn points and help others
