Question about Frigidare FGB24S5DC Gas Single Oven
Need to adjust Oven door to shut tight - Frigidare FGB24S5DC Gas Single Oven
  • 121 Answers
Adjust on screws on door hinge
Posted on Feb 17, 2009
3 Suggested Answers
barkencoa
  • 3463 Answers
SOURCE: Oven door isn't closed tightly on both sides.
If it is a door that lifts up and down, then the only solution is to replace both door hinges, as they are not normally adjustable, it is the springs that are weak.
Plz rate my solution.
Thanks.
Posted on Jan 06, 2009
barkencoa
  • 3463 Answers
SOURCE: oven door won't stay tightly shut
Oven door hinges are not adjustable, assuming you have fitted the door back correctly, and it is still not closing properly, then the only solution is to replace the door hinges.
Posted on Jan 20, 2010
Oven door kleenmaid wont shut tight enough
Some are made where you just pull up on it and some you actually have to remove the bolts and stuff
Jul 29, 2012 | Ovens
Door will not shut tight. Can it be adjusted?
No adjustment is possible, normally the only solution is to replace both oven door hinges
Dec 26, 2010 | Whirlpool RBS305PDS Electric Single Oven
We just purchased a home that was built in 2003. It has a stainless steel double oven. The doors don't close tight. Is there a way to adjust them so they do? Thanks
I have the same problem on my AOCS3040 oven....door will not shut tightly so it loses heat and is about 25 degrees off plus the escaped heat makes the control panel get very hot during cooking.
Oct 21, 2010 | Amana AOCS3040 Electric Single Oven
Oven door won't stay tightly shut
Jan 20, 2010 | Whirlpool RBS275PD Electric Single Oven
Oven door not shut tightly. how do i adjust it ?
if the door does not have a door catch, then you will have to replace the oven door hinges.
.If it does have a door catch, then you will have to replace the door catch.
Please rate my solutionb
Thanks.
Oct 05, 2009 | Frigidaire Ovens
The main oven door will not shut tightly, how do you adjust it?
if its a pull down door the hinges are prob worn and need replacing.
Sep 27, 2009 | Belling XOU492 Electric Double Oven
My oven door will not shut tightly
Hi, I take it that this a whirlpool oven? Single or double oven? If it is a double your in luck! Your door hinges need replacing along with the inserts that are located inside the oven cavity. You can exchange the hinges and inserts from the oven doors and hinges if you have a double oven. If not get some new ones and fit them in! Easy job you will just need a little guidence as some models do differ..
Get back to me if this is usefull.....
Dec 30, 2008 | Whirlpool Ovens
Bosch HBL745A Oven door
My husband just figured this out.
- Follow Door removal instruction from the manual.
- There is a screw at the end of the hinge that can be adjusted.
- Adjust the screw to desired height.
- Secure lock nut.
Nov 14, 2007 | Bosch HBL 742 / HBL 746 Electric Single...
Frigidare FGB24S5DC Gas Single Oven Logo
257 people viewed this question
Top Frigidare Ovens Experts
Dan Webster
Dan Webster
bobalix
Are you a Frigidare Oven Expert? Answer questions, earn points and help others
