Question about HP LaserJet 2430dtn Printer
HP laserjet 2430 dtn little typed letters print on the left side
I have a HP laserjet 2430 dtn. I am so frustrated!!! I have replaced the toner and drum several times. I can't seem to find why it prints letters in a row on the left side of the page. It like there are letters on a roller somewhere. Can you help?
mary
  • mary Chavez
    mary Chavez Feb 17, 2009
    what is a fuser and where is it located? Is it something I could do?
    Genius:
  • 2,120 Answers
Probably a bad FUSER. The teflon is probably worn off.
Also take out the toner and move the drum cover aside to look at the drum..It should be clean.
Posted on Feb 17, 2009
HP Laser jet 4350 dtn printer gets 59.40 error. I
Print Cartridge Motor Error.
Try removing then re-installing the cartridge. If that does not work then you will need to try a different toner cartridge as the toner cartridge is "locked up". These are the most common solutions. If none of these work then you have a cartridge drive problem and will need to contact a service center.
Jan 05, 2010 | HP LaserJet 4350dtn Printer
The right side of the printable portion of each doc prints light
You just need to remove the toner and reach in with a dry rag and wipe the little inch wide window that is above where the toner goes. This window gets covered with toner dust and makes prints lighter...It runs all the way from right to left above the toner and drum.
Nov 03, 2009 | HP LaserJet 4100tn Printer
Hp laser jet 2430 dtn prints lines on left side of paper
Hi Karent503:
It sounds like you fuser assembly is worn. The part on the fuser assembly that you are having a problem with is the heat roller assembly located in the fuser. You can have a technician replace that for you at you local HP repair center, Her is the part number for the fuser assembly.
Fuser, 110-127 V RM1-1401-000CN
Apr 02, 2009 | HP LaserJet 2430dtn Printer
HP LaserJet 2430 prints vertical grey bands
It is a bad Toner Cartridge or Fuser. Most likey a bad toner cart.
Mar 07, 2009 | HP LaserJet 2430n Printer
2430 printing 1/2 inch marks down left side of page
Did you change the Toner cartridge? If that did not fix it :
Then the Fuser needs replacing. If you take the Fuser out from the rear, and rotate the drum in it, you will see the marks. You can try to clean it but experience shows that you will have to replace it.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Oct 13, 2008 | HP LaserJet 2430dtn Printer
HP laserjet 4350 DTN Folding corners
teflon coating on heat roller in fuser is coming apart. replace the fuser. also check to make sure the paper tray is set to the correct size. this means pull the tray out, remove all paper, look inside to make sure the arrow is pointing directly at the correct media size you are using i.e. letter or legal or whatever you are using. Good Luck! please rate this carefully.
Oct 09, 2008 | HP LaserJet 4350dtn Printer
LJ 2430 Printing Blank Pages
HI there have you tried the toner cartridge as this could also cause this problem? Also change the transfer roller and are the bands going from left to right or from up to down. If the bands are left to right change both if up to down more likely to be the toner cartridge.
Hope this helps you
Thanks J
Jan 11, 2008 | HP LaserJet 2420 Printer
Ink problem
The previous toner cartrige may have been leaking toner in the printer. Even though you changed the toner, there might be leftover toner leakage in the printer. If you can clean that up, it might help the problem. Try running the cleaning mode on the printer if it has one. If there is more than one toner in the printer (if it's a color printer) then it might be one of the other toners. We usually use an electronics vacuum to clean up these messes. If you don't mind making a mess, you can use canned air to blow it out.
Nov 07, 2007 | HP LaserJet 2430dtn Printer
Laser cartridges with chips
you need to replace the chips so it will read the amount of pages printed by the toner cartridge.This chip is only for measuring how many pages printed.
Mar 30, 2007 | HP Q2613A OEM Genuine Black Laser Toner...
HP LaserJet 2430dtn Printer Logo
379 people viewed this question
Seeker5211
Seeker5211
