Question about Apple iPod touch
Ipod touch stuck at unlock screen
My ipod touch will let me slide to unlock it but wont let me type in my acess code to fully unlock it wont be syncd to computer and wont charge please help
5 Suggested Answers
  • 82 Answers
SOURCE: Can't unlock my iPod Touch!!!!
u r screwed up. get help from mac people.they have utility to bust it
Posted on Jul 13, 2009
dalegough
  • 12 Answers
SOURCE: cant slide to Unlock
try holding down the "power" and "home"buton untill you i pod shows the apple logo then try again it will take about 1 too 3 mins to restart
hope this helps
dale gough
Posted on Aug 11, 2009
  • 5 Answers
SOURCE: iPod Touch, 1st gen, "slide to unlock" broken
If you jailbreak (quickpwn.com) there is an app on cydia that will change it to tap to unlock rather than slide so it should be more sensitive.
Posted on Aug 31, 2009
SOURCE: my iphone is not responding to touch
That maybe a hardware issue, mate. If you've tried the most common troubleshooting steps ppl usually do and it didn't work, consult a specialist or get it back to the apple store if you got one nearby, better take it back to the same store u purchased it from and they're ought to dispatch you a new one if needed "If this one is hopeless"
Troubleshooting available for that:
1- Press and hold on the HOme button with the Power button altogether untill the iPhone goes off, then turn it back on.
2- Double tab the screen with 3 fingers same time, this actually enlarges the icons, then do the same once mroe to get'em back to normal.
3- If that did not work, restore your iPhone in recovery mode to the factory settings, you can do that by switching off the iPhone completely - open itunes then press and hold on the home button on your iPhone before plugging it with the USB cord and then plug it in and keep holding, don't release the home button untill you get a pop-up message on your itunes as "iPhone detected in recovery mode, restore "YES"".
4- If that didn't make it, duuuude get it back to the store to do a maintenance check with your warranty.
Regards, Milo
Posted on Nov 04, 2009
  • 39 Answers
SOURCE: slide to unlock on my ipod touch wont move
That sounds like your digitizer (the part that tracks your finger) has gone bad. If you are still under warranty you should be able to get apple to swap it out. If not you can get new digitzers (the whole glass face and the electronics attached for $15 to $40 and there are a lot of youtube videos showing you how to remove the old one and install the replacement
Posted on Aug 10, 2010
Itouch disabled
When your iPod Touch displays a message telling you to connect it to iTunes, it may be in recovery mode, or have been disconnected in the middle of an update.
To get rid of the screen, you must reset your device. If in passcode mode, an iPod Touch must be manually unlocked or fully restored to get back to the home screen.Forcing a Reboot
When your iPod Touch is stuck on a screen that is instructing you to connect with iTunes, a normal restart will probably not work, as the hard drive has become frozen.
You can still, however force the iPod to reboot using a process called resetting.
To reset an iPod Touch, hold down the "Sleep/Wake" and "Home" buttons at the same time until an Apple logo appears, indicating that the device is rebooting.
When an iPod Touch reboots, it always goes back to the lock screen. Passcode mode will still be enabled.
Unlocking With the Passcode
If you know the passcode for your iPod Touch, slide the "Slide to Unlock" arrow and then enter your code on the next screen.
Upon entering your password, you will be directed to the device's home screen. If you enter the wrong password too many times, it will become disabled temporarily.
The iPod Touch can also be set to erase all content after 10 incorrect passcode attempts if you previously enabled this feature, don't attempt more than 9 entries.
Unlocking Without Passcode If you have forgotten the passcode to your iPod Touch, the only way to unlock the device is by restoring it.
Restoring an iPod Touch returns it to the factory settings, meaning that any settings, applications or music you added to the iPod are removed.
Once the device is restored, you can re-add your downloads and other information using the backup copies in your computer iTunes program.
The passcode setting will be disabled unless you manually enable it again.
Consideration
If you don't have a backup of your music and applications in iTunes on your computer, you can also download another copy from the iTunes Store or App Store on your device after a restore.
Any photos that are deleted during restore, however, will be lost forever if a backup does not exist.
Always back up your information via sync on a regular basis to avoid this problem.
Nov 05, 2013 | Audio Players & Recorders
How to unlock an ipod
Apple's iPod touch, a portable music player with a touchscreen display, is powered by a built-in rechargeable battery that provides up to 40 hours of audio playback and up to seven hours of video playback when fully charged. To conserve power, the iPod touch locks by default after a minute of not being used. If you want to use your iPod touch after it locks, you will need to unlock it. You might need to type a password, depending on how you've configured the device.
Press the "Home" button, located below the screen, or press the silver "Sleep/Wake" switch located at the top of the device. Swipe a finger across the "Slide to Unlock" slider on the screen. The iPod touch unlocks. Press the "Home" button or press the "Sleep/Wake" switch when you have enabled passcode protection on your iPod, then swipe a finger across the "Slide to Unlock" slider on the screen. The "Enter a Passcode" message appears. Type in your passcode, and then tap "OK." The iPod touch unlocks. Forgot Your Password b> Connect the iPod Touch to your computer using the USB cable. Wait for iTunes to open and sync with your computer. Eject your iPod Touch from the computer by clicking the "Eject" icon beside the iPod's entry in the "Devices" section of iTunes. Disconnect your iPod Touch from the USB cable. Your iPod Touch will be turned on and will be unlocked. Tap the "General" menu on the iPod Touch. Tap "Passcode Lock," and then tap either "Turn Passcode Off" or "Change Passcode." If you tap "Change Passcode," you can then enter a new passcode.
Mar 04, 2013 | Apple iPod touch
How do i unlock my ipod touch
Hope it helps
Jan 23, 2013 | Apple iPod Touch Fifth-Generation
Every time i try to slide to unlock it wont slide. and if it will slide when i tried to put in my code the buttons wont work
your touch screen is broken you need to either send it in to apple to get it fixed or buy a new touch
Aug 29, 2009 | Apple iPod touch
Wont unlock.
hmm I've never heard of this, it sounds like your touch screen still works so I don't know.
try talking to apple 00800-7666-7666 (off the top of my head i think)
Aug 22, 2009 | Apple iPod touch
Won't let me slide to unlock my itouch
Allow the iPods battery to completely die and then fully recharge it. If it wont unlock then your displays touch sensitivity is not working and you may need to replace the display or it may be cheaper just to replace the iPod Touch
Jul 21, 2009 | Apple iPhone Smartphone
Apple iPod touch Logo
Top Apple Audio Players & Recorders Experts
Sean Cole
Sean Cole
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
